Old 04-10-2004, 10:51 PM   #16
Tek Nickal's Avatar
Originally posted by dontfeelcold
How many runs can you get with rubber tires (sorex) until they start to put out slower laptimes.
This is the only issue I have with rubber tires, but everytime i ask this question i never get an answer. This is the main reason I like to run foam tires on asphalt, same laptimes for the entire life of the tire.
Most tracks don't allow foam tires on asphalt. . . especialy stock. . .
Tek Nickal is offline   Reply With Quote
Old 04-11-2004, 01:35 AM   #17
fatdoggy's Avatar
R/C Tech Charter Subscriber
AzNDRAGster - On the east coast, md/va/pa foam for stock and mod is the standard for indoor and outdoor.
fatdoggy is offline   Reply With Quote
Old 04-11-2004, 02:45 AM   #18
Andrew_XXXs's Avatar
He's in Aus... where foam is probably the preference and allowed for most races (except Victoria).
Run 'em till the canvas I say...
Andrew_XXXs is offline   Reply With Quote
Old 04-11-2004, 06:08 AM   #19
dontfeelcold's Avatar
Trader Rating: 20 (100%+)
i can get 12runs out of foams, all producing near identicle laptimes (about 1tenth due to being human)
Rubbers last the longest on brushed concrete.
Best case senario is polished concrete with a cordial and metho mix sprayed on it. True your foams down so there is about 1mm of foam left on it and get ready to traction roll.
dontfeelcold is offline   Reply With Quote
Old 04-11-2004, 10:02 AM   #20
MartinSorlie's Avatar
If you're a really serious racer, Sorex 36 will have ultimate performance for maximum 2 packs...
If you're a real economy guy, I know tricks to make them last for at least 100 runs with ok performance...
I'm one of the serious racers, and yes, my tire budget is extreme at big races....
Martin Sørlie, 1985, R/C since 1995.
TLR - Spektrum
MartinSorlie is offline   Reply With Quote
Old 04-11-2004, 10:05 AM   #21
popsracer's Avatar
Default Tires, tires, tires
I have found the 'Take-Off' tires work very well in most all conditions and surfaces. Where they really shine in on Concrete. Nothing I have tried works better.
The pre-mounts are somewhat prone to grooving because of the soft inserts provided. A firmer insert will help here.
'Sorex' tires also work very well on Asphalt, especially smooth or sealed Asphalt. What I really like about Sorex's, is they work in a much in a much wider temperature range than most other brands of tires.
They are also one of the easiest Tires to mount and Glue. It is always a joy to build up a set.
popsracer is offline   Reply With Quote
Rubber tire life? CREWMAN Electric On-Road 23 04-10-2008 01:05 AM
RUBBER TIRE LIFE ASPHALT VS CARPET RED-LINE M03 Electric On-Road 5 07-12-2007 10:48 AM
Practices to extend the competative life of a rubber tire on carpet BlackKat Electric On-Road 10 08-18-2005 02:26 PM
CS long life/Reedy plutonium/LRP long life brushes...which is the best? Tbevofreak Electric On-Road 15 03-18-2005 05:26 PM
Tire Life TRF-Powered Electric On-Road 18 08-28-2001 03:43 PM
SEO by vBSEO 3.5.0
