Tc3 Chassis Drawing..
Registered User
Someone got a pdf or gif or something similar with all messures on the chassies .. Want it to make me a carbon chassi for meself .. Nothing to sell just want to have it and print and cut out on a bit of carbon ..
Thanks to whoever helps me ..
//JonteJsson
//JonteJsson
Here's a quick one. Dimensions should be within .010", but no gaurantees.
Registered User
Thanks..
Thanks alot .. Just one hour of translation to centimetres ..
wow
Let me know if any of those dimensions are off. I used a Mitutoyo CD-6"CS Digital Caliper to grab those dimensions right off of a chassis, so test with a scrap piece of wood like 1/4" Medium Density Fiberboard (MDF) before cutting expensive Carbon Fiber with those dimensions. Which, by the way, the 1/4" MDF ends up around .200" thick and actually makes a fairly decent practice chassis in a pinch.
Im doing the same thing for a buddy at work too. And you saved me alot of time! I do it the same way, calipers and the chassis..... But the cool thing about my set up at work is I run a laser on top of the other machines(waterjet,cnc router,cnc mill) and to make sure everything is lining up I just throw in a piece of 1/16th plex and laser it out. It SUPER quick so I'm able to see if its off or on in a matter of a minute or two.
Hey what CAM package are you guys using, Stumper? If you want, I could send you the IGES solid model so it would be easier to program the CNC. In turn, let me know how it fits so I can update the dimensions on the drawing.
Originally posted by True R/C Racing
Sammy is the Next BMI or Warpspeed Designing his own stuff
Oh ok, EnRoute allows DXF import so you could have used this file instead of spending the time making it in Corel!
Sorry. Try this...
didnt work for me
