Old 03-16-2002, 03:10 AM   #1
Default Bulb discharger
i'm building a bulb discharger...how many bulbs do i need to make a 20 or 30 amp discharger....bulb specs are 12v 25w(i knoe i have to use #1157 but there no number to this bulb that i bought)......does it draw more amp when using with a 7.2v than a 4.8v pack??anyone please help me...i'm not electrically inclined so i dont know what to use for my 7.2v and my 4.8 vpack ....thanks all for looking and replying
MX3 is offline   Reply With Quote
Old 03-16-2002, 03:22 AM   #2
blueboy's Avatar
If your racing stock motors then you need to discharge at 20 amps; that's 10 blulbs.
If you race modified then you should discharge at 30 amps; so you need 15 bulbs.
blueboy is offline   Reply With Quote
Old 03-16-2002, 05:01 AM   #3
Lightbulb Discharger CHEAP!
I used 3157 bulbs. They have 2 filaments, and are the newer 1157. They have wires you can bend out. I bent out all thewires there are 2 on each side. Bend them so they stick perpendicular to the bulb. I them put the bulbs in a circle. They just fit. Solder all the wires on one side and all the wires on the other side. Hook a heavy wire to each group of wires. It comes out to 10 amps.
Each bulb should look like thisl _0_
Works great, no jig needed or holder when it is finished.
I paid $7.00 for the box of bulbs.
My packs are performing much better since I started using this.
David Root
David Root is offline   Reply With Quote
Old 03-16-2002, 08:31 AM   #4
Regional Moderator
daniz24's Avatar
I heard that Bulbs are not good for NiMH...
daniz24 is offline   Reply With Quote
Old 03-16-2002, 08:36 AM   #5
Jack Smash's Avatar
Trader Rating: 28 (100%+)
Just remove the bulbs from the battery before they fully go out for NIMH packs.
Jack Smash is offline   Reply With Quote
Old 03-16-2002, 09:44 AM   #6
about 10
rctc3 is offline   Reply With Quote
Old 03-17-2002, 04:17 AM   #7
Trader Rating: 62 (100%+)
i suggest installing a battery cutoff device (i use a deans black box 2) to prevent over-discharging your batteries. i have a homemade discharger with 10 pcs 12v automotive bulbs, plus the black box.
marvi is offline   Reply With Quote
bulb discharger minnesh R/C Items: Wanted to Buy 2 10-08-2007 05:45 PM
Pls help with bulb discharger Blackwrench™ Australian Racing 7 09-25-2006 08:56 AM
Bulb Discharger Jimmy Morris Electric On-Road 12 08-23-2005 03:12 AM
bulb discharger question Evilpete Rookie Zone 4 03-02-2005 07:20 PM
wtb bulb discharger fly442 R/C Items: Wanted to Buy 0 12-28-2004 03:57 PM
SEO by vBSEO 3.5.0
