Ko Propo VFS-1 and Li-Po
Good to know.
Software v2.4 for safe Li-Po cut off.
That is the most vague post ever!
Is this for brushed ESC or brushless? I hope it's for brushed, but I'm sure it isn't...Where do we get it? Once we get it, how do I install it? Do you have a link? NO info on KO Propo USA. WTF? I'm so confused...
What is this????? Anew update for 1s?
I was in contact with KO USA and here is the scoop. This is an updated version of the ICS computer software only. It can be downloaded from the link provided above. The only change is that it allows you to set the "Power Save" feature to a higher voltage (as high as 6.0v) to protect lipo batteries under load.
Here is the catch. It only works with the ICS software. Those of us with handheld programmers are out of luck...
KO USA told me you can send your ESCs to them and they will set the power-save function to your desired value. It will only cost the price of return shipping. The bad news is that the next time you try to change any settings with your handheld programmer, it will overwrite their lipo-save setting. So if you don't ever mess with your ESC settings, this is a good/cheap option for you...
Now I have an ICS USB adapter and it won't work damn'it!
