Exotek Chassis??
#16
I think everyone is missing the point. I was over with LW stuff. A lot of people don't run LW stuff, my only issue with it was that its heavy to the battery side in some cases and it would be nice if the weights were more configurable. Even the guy that created these chassis said it was something he was going to look into. Esp for countries that run an even lower weight.
FWIW, I run a T3 now, with the stock chassis and no problems balancing it and I am well below weight.
It would be nice if he does different weights for balance at different weights, but for the current ROAR weight of 1420 its perfect
#18
..anyway, I believe the answer to the OP's quesiton is that Exotek does great work
#20
Im not 100% sure if he still is. When I talked to him at indoor champs, he seemed like he liked it (even with the stock servo location), and was looking forward to running them at the KO GP(he didnt have one for his 13.5 car yet). Christer Andersson (AE Factory Europe driver) runs it as well.
#21
#22
the only reason i check my cars weight is to make sure its legal, after that, who cares. but thats a topic for another thread as this one was about the chassis
#23
Balancing Technique
What technique are you using to balance your car? Hudy style balance stands? I.R.S. balance buttons? Digital scales? The Hudy style balance stands and the I.R.S. balance buttons both require holes centered at each end of the chassis which the Exotek chassis already has, so you should be good if you are using either method. Digital scales under the wheels/tires cannot differentiate between balance and tweak if not done correctly. I've seen people trying to use 4 digital scales pull their hair out when trying to balance the car because they are measuring tweak as much as balance.
#24
#25
#26
Hi guys, does anyone on here know of a number that i can get in contact with the people at Exotek?
I tried e-mails and pm`s, but still no answer.
Reason i`m trying is, i need a chassis for my T3 and the chassis they are making looks pretty slick.
And i also heard great things about the exotek conversion for the 009.
So i really wanna try their chassis.
Thanks guys.
Thanks guys.
#27
Thanks guys.
Thanks guys.
otherwise he's on here also, maybe a PM?
he sells a great product so i dont doubt thats the reason why he takes awhile to answer.
#30
Hello all, I just wanted to say that I love the Exotek chassis. I run it in myTC5R. With all the different battery positions, it is well balanced (depending on what battery you use).
