Old 04-05-2004, 07:20 PM   #1
lee82gx's Avatar
Default tweak vs ride height adjustements
Hello,
I have some questions regarding the tweak vs ride height.
1.Which do you set first?
2.Do you set for equal ride height left/right?I mean it's like NO static tweak.
3.If yes for no.2,then when u lift the car to see / adjust the tweak , wouldn't it already affect the balance L/R?
Is there something i'm missing here?
lee82gx is offline   Reply With Quote
Old 04-05-2004, 07:22 PM   #2
Tek Nickal's Avatar
I would think to set all the preloads the same, check for tweak, then set ride height.
Tek Nickal is offline   Reply With Quote
Old 04-05-2004, 10:12 PM   #3
Speedie's Avatar
I think ride height should be set first. Idealy if ride heights are perfect tweak will be also but we are not in a perfect world. I set ride height and then test it on the track first before I even check tweak. 99% of the time its perfect.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 04-05-2004, 10:54 PM   #4
I have always done it droop ride height then tweak.
shortygy is offline   Reply With Quote
Old 04-05-2004, 10:56 PM   #5
new92's Avatar
Same way here. It may be wrong but it seems to work for me.
new92 is offline   Reply With Quote
Old 04-05-2004, 11:31 PM   #6
Send a message via AIM to A-Ko
Usually you set droop, height then tweak in that order.
If you end up preloading one shock to get the right height or fighting a tweak, you might need to rebuild your shocks, assuming you checked the chassis for the tweak...
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 04-05-2004, 11:49 PM   #7
Try setting your ride height on an MIP tweak station.
Gives the best of both worlds.
Bob The Builder is offline   Reply With Quote
Old 04-06-2004, 01:40 AM   #8
Cole Trickle's Avatar
With a tweak station, you can actually risk that the car is tweaked in opposite corners, in a way so they equal each other on the tweak board.... So you wont see the tweak on the board !The knife method is better and cheaper ! Lift one end at the time with a knife and ensure that both wheels lift off at the same time. Best done with setup wheels.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-06-2004, 04:03 AM   #9
Rick Worth's Avatar
What if one of your shocks or mounts has some slop. When you lift it up one could lift a wheel off the ground before the other side and have nothing to do with tweak or your droop screws aren't set the same. Use a tweak board. You are checking for pressure on each wheel not lift.
Rick Worth is offline   Reply With Quote
Old 04-06-2004, 05:24 AM   #10
lee82gx's Avatar
ok,here's the problem I'm having(yokomo SD).
I set the ride height first.I make it equal 5mm left/rear and right/rear.then the left/front 4.5mm and right/front 4.5mm.
Right now,both the left sides of the shocks have more preload since the battery is on the left and it's heavier than the motor+ESC+receiver.
Droop has already been preset to 3mm via downstops even earlier.
Now if i lift up one end of the car,say rear-
i find that the car is a little tweak-1.5mm.This is mainly becos the left front spring has more preload(earlier mentioned),making the right rear wheel lower.
I can now reduce the preload in the left-front shock to set the tweak back.but this will result in a changed ride height in the front ,especially on the right side,correct?
That's my dillemma.
Old 04-06-2004, 09:25 AM   #11
Speedie's Avatar
I think the first thing you have to do is balance your chassis. Get scales or a scale and make sure it is balanced left to right. You wouldnt put a 10 pound weight on top of your foot and wonder why that foot seemed heavier would you. In full scale racing you would never even think about racing a car that you didnt set on scales.
I also think that a touring car cannot have the tweak set using the knife method. The wheels downtravel is limited by the droop screws or limiters. If either of these are uneven even a little it will affect tweak. I set droop last, and set it as downtravel, then I use a gague and make sure its even side to side.
Old 04-06-2004, 11:21 AM   #12
popsracer's Avatar
Default Chassis adjustments
Guys;
You MUST start with the Ride Height settings first. Then adjust Droop, then check and adjust Tweak.
If ride height is altered enough to matter after a Tweak adjustment. Just make an adjustment on the opposite side to keep the relationship of the Shocks the same.
When I am compensating for Tweak via the Shock Collars. If I need more than 1/2 turn difference on one side, then I go back to the Chassis and look for a problem there. If everything is straight and true the adjustment needed at the Shocks should be minimal.
popsracer is offline   Reply With Quote
Tweak and ride height question. RandomTask Electric On-Road 9 06-12-2006 09:27 AM
Integy Set up station, MVP Tweak board, ride height guage ($70 shipped) Travis S R/C Items: For Sale/Trade 6 06-23-2005 08:42 AM
Tweak good, Ride height bad donoman Electric On-Road 12 09-21-2004 05:39 AM
MIP Tweak board, Hudy Ride height, droop guages Peter Busch R/C Items: For Sale/Trade 0 09-29-2003 05:16 PM
ride height nitroblade Nitro On-Road 7 04-17-2003 01:25 PM
