Old 02-18-2010, 09:12 PM   #1
CFR's Avatar
Default GT10 Foams Jaco & BSR
were do the Spec Tyres fit in the list from both brands?
insert them in the lists in red please
Front 2102 Green (medium) standard
Front 2124 Pink (med-soft) low wear
Front 2125 Purple (med-firm) low wear
Front 2128 Gray (med) high bite carpet
Front 2129 Black (firm) high bite carpet
Rear 2105 Green (medium) standard
Rear 2107 Aqua (med-soft) standard
Rear 2142 Pink (med-soft) low wear high traction
Rear 2143 Purple (firm) ultra-low wear high traction
Rear 2144 White (med) high bite carpet
Rear 2145 Gray (med) high bite carpet
Front F1000 Med Blue
Front F1001 *Firm Blue
Front F1003 *Green
Front F1029 Pearl White
Front F1005 White
Front F1007 Gray
Front F1031 Black
Front F1037 Black/Silver
Front F1011 Gray/Silver 70/30
Front F1011 Gray/Silver 50/50
Front F1013 *Silver
Front F1015 Pink
Front F1017 XX Pink
Front F1019 Purple
Front F1033 Team Purple
Front F1021 XX Purple
Front F1025 Purple/Orange
Rear F1004 *Green
Rear F1030 Pearl White
Rear F1006 White
Rear F1012 Gray/White
Rear F1008 Gray
Rear F1032 Black
Rear F1010 *Gold
Rear F1014 Silver
Rear F1016 Pink
Rear F1018 XX Pink
Rear F1022 Purple
Rear F1034 Team Purple
Rear F1024 XX Purple
CFR is offline   Reply With Quote
Old 02-18-2010, 11:12 PM   #2
odpurple's Avatar
The spec tires are Lilac compund for WGT , there are no spec compunds for GT10 to my knowledge. It is the same rubber family as Purple, a little softer and therefore a little more bite.
You can't really just insert them into the lists you posted. There are different rubber families in those lists and therefore different bite characteristics.
For carpet the lilac compound works great for WGT. They wear like iron and have just the right amount of traction.
At any rate, if you are required to use the spec tires at your track you don't need to worry about where they fit in, just use them!
odpurple is offline   Reply With Quote
Old 02-19-2010, 06:01 AM   #3
If you don't need to use the spec tires why worry with them.I've never used them myself and I've raced once on carpet. There are several other tire companies I've used- RCfor less and Corally .both work very good on both carpet and asphalt. Basically Purple fronts and Pink rears.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products GForce and RJSpeed.
WGT-R, GT Racing USA (17.5 foam),RJSpeed- Legends &Spec Mod, MudBoss and 386 RaceWay.
BullFrog is offline   Reply With Quote
SEO by vBSEO 3.5.0
