X-EVO Chariot 2.0 conversion kit for M03/M04/M05
#46
Well this kit was purchased from RCmart, which Is the only shop I've ever seen it at.
The manual included with the kit shows the older colour on all the annodising, but from what I've looked into, and having built the kit i'd say it's as it should be.
If you look at the "teams" cars from titc they are the same shade of annodising...
Maybe the newer kits are the different colours or lack the XEVO stamp on them? Just guessing!
#47
When I was talking to the Xevo guys, they mentioned that the newest version of the kits were to be released with the larger holes to fit the M05 sized bearings and to take the M05 Ball Diff as well.
#49
Has anyone tried the Hitec HS-77BB servo on the x-evo? I am debating on buying one. They seem good enough for Mini racing.
#51
Low profile, I just ordered the Hitec HS-77BB @$25. It seems like it will work very nice from people I've talked to. I did not like the setup for the Standard servo, the battery is too vulnerable.
#53
Also the Xevo lettering is on some kits and not on others. Probably a production run difference.
#54
Where can we order spare parts? I already broke the FRP bumper plate and front body mounts. Also, the plastic bumper below the bulkhead as well
#55
#57
hi ..... i recently got a xevo ..... almost finished building and im just quite not sure on where the bearing/spacers go for the ball diff? .....
is it supposed to be from the inside beside the ball diff or from the outside of the bulkhead where the joint cups are sticking in? .....
any tips on how to reduce the droop on the front also? .... i installed tamiya 55mm length shocks with short springs ..... when planted on the surface ride height is ok .... its just that when you lift the car up theres so much droop?
any tips????
thanks in advance
any tips????
thanks in advance
#58
Washers/spacers on the shock shaft, inside the shock body under the piston. They'll stop the shock extending and limits the droop.
#59
Have you guys seen the new 'ISS' shock mount system for the Xevo (http://www.rctech.net/forum/electric...ooper-826.html, post #12390 at the bottom of the page)?
I ordered a parts kit from 'Official' on the forum ($35 USD + shipping), and have now fitted it. You don't get any installation instructions, but I got a few extra pictures from Official of the kit fitted to his Xevo, and managed to get it all to fit, it is a tight squeeze though. I won't get to try the car until the end of the week, and even though my Xevo handles very well with the standard front suspension setup, I'm interested to see how the car handles with this setup. The only concern I have is how strong the point is where the pivot-connection link mounts onto the wishbone (pic 4). You have to cut a few mm off this mount so that the connector can fit next to the c-hub, and now theres only around 3mm of plastic now holding the mount onto the wishbone. I guess only time will tell...
Official is a Xevo parts distributor from Singapore, but he shipped to the UK no problem. He also said that he has the v2 front bulkheads with the larger bearing mounts, and the front adjustable upper link set for sale, so if anyone is interested, PM him for more details. I need to see if he can get Xevo spares, as I have broken the FRP bumper plate & front body post mount plate (which is currently held together with glue & a modified 3Racing m-chassis graphite body post stiffener ).
#60
im interested in the adjustable droop parts for the xevo (front and rear) ..... i saw it posted somewhere .....
where can i order these? ..... any official distributor? contact person?
thanks
thanks
