Old 03-31-2004, 07:17 PM   #1
Exclamation Electronics Change and problems
Hey Woohoo my first post, anyway I got new Radio gear for my FTTC3 and is there anything you need to do to the camber caster servo esc etc.... Also my car moves from side to side and wiggles all over the road what could vbe the problem?
TC3_MaN is offline   Reply With Quote
Old 03-31-2004, 07:19 PM   #2
Send a message via AIM to True R/C Racing
make sure setup is correct. Camber and Caster Are both the same. On the radio make sure everything is good. the wiggling can be tires
True R/C Racing is offline   Reply With Quote
Old 03-31-2004, 08:03 PM   #3
Tek Nickal's Avatar
Sounds like uneven steering links. . . .the ones that go to the front hub-carriers, check them to see if their the same length. Loose wheels could also be the problem. Even if you have un-even camber, it shouldn't be a problem.
Tek Nickal is offline   Reply With Quote
Old 03-31-2004, 11:51 PM   #4
Sixpack's Avatar
try Team AE webbie for decent setup example. Get the correct tyre insert combo info from ppl running at your track.
Approach them for help.
Sixpack is offline   Reply With Quote
Change or Stay? DirtyDezPirate Nitro Off-Road 3 06-12-2007 02:43 PM
when to change brushes? noobie Electric On-Road 12 03-21-2006 10:35 AM
what do you change up first. Fantomcat Electric On-Road 7 01-30-2006 06:37 PM
Bearing change alltech Rookie Zone 3 04-18-2005 05:17 PM
How can i change me name? Brett.w R/C Tech Site Forum 6 09-28-2004 01:45 AM
SEO by vBSEO 3.5.0
