    Hide Wikipost
Old 10-11-2017, 10:25 AM   -   Wikipost
R/C Tech Forums Thread Wiki: 1/12 forum
Last edit by: DesertRat
This is a place to share knowledge related to 1/12th scale racing. It is not to be used for conversations.
KITS:
Click links to go to manufacturer product page. If any are missing please add them!
TIRES:
Pre-mounted tires readily available in the US:
Pre-mounted tires readily available in the Europe:
  • Hot Race ??
Gluing your own donuts:
https://www.youtube.com/watch?v=hm7z1rz-74s - Special thanks to Edward Pickering!
Truing tires:
https://www.youtube.com/watch?v=8wqHOLWq6Uc - Special thanks to Edward Pickering!
The following information came from HERE, with some editing and information added. Thanks Christian!
THIS MAY NEED UPDATING FOR THE NEW BLACK CRC CARPET
Brands:
BSR, CRC, Jaco:
Pro One is no longer selling to the public, but it and the brands above are all mounted by BSR and use the same foam. The nomenclature of the BSR vs Jaco/CRC is a little different in a few instances but is otherwise the same. The BSR foam consists of three families, and can be identifed as synthetics, naturals, and blends.
Synthetics - The old school, light weight, easy to true "dry feeling" tires. These include tires like CRC/Jaco Yellow (BSR White), Black, Gray, etc. These tires offer the highest wear rate and lowest grip. Many racers continue to use these nder high bite conditions.
Naturals - These tires are usually the best alternative for low bite and asphalt. They include Pink, Magenta, Double Pink, Lilac (BSR Team Purple), Purple, and other tires. These tires provide a ton of grip, but tend to get sticky in high bite conditions. This rubber does not wear as easily, and the cars will pick up gunk and fibers from the carpet under most high bite conditions. This is especially bad if the humidity is high.
Blends - These are the tires most people run today. They were initially called "JFT foam" by some, as it was believed that the tires were the same as the JFT tires. We can divide the blends further into two groups: high rubber and low rubber content. The high rubber would be the new rear Orange and Red from the BSR family, and the low rubber would be the Green and Blue varieties. When, asked about the difference, John Foister from BSR Tires said they came from the same "family" of foam, but they offered different grip. According to John, the Green/Blue has more bite than Orange/Red, but from track testing Oranges offer more bite than Green (being equivalent to in hardness) when the grip is high and absolutely no grip when it is lower. The Orange foam has a denser pore structure and the tire is not as prone to chunking. It is also important to note is that BSR Blue rears are not the same as the BSR Blue fronts!
JFT:
JFT stands for Japan Foam Tire. They started the new wave of foam tires we are all using now (Blue/Blu, Green/Greene, Dbl Blue, etc). These tires are a little different than the BSR tire family, but work in very similar conditions. They offers four varieties A (asphalt), C (carpet), S (???), and R (???). This does not mean that those types only work on that surface, but this is what they recommend.
JFT uses the same foam for fronts and rears if the color is the same.
A: Used on asphalt, considered close to the natural rubber variety and are named consistently with other natural tires.
C: Used on carpet, considered a blend.
S: Used on carpet?, tires are ???
R: Used on carpet?, tires are ???
For setup, the JFT foam seem to generate more bite than the BSR, therefore the car tends to be a little more aggressive.
Ulti:
Ulti is another Japanese brand that offers an array of compounds. They have their own way of rating tires, and are difficult to equate to other brands. They have 4 different varieties, each in varying degrees of hardness.
J: High rubber content tire, similar to Pink/ Magenta. Soft would be close to a pink. These offer the most bite and are great for asphalt/carpet front tire. (J hard being very popular)
X: "Balanced" blend, similar to JFT Blue/ Green. Soft is equivalent to Green, medium to Blue in hardness. Great for carpet!
Y: High synthetic blend with lower grip, and is not a very popular variety.
Z: A very expensive "special" foam that is supposed to be magic on asphalt. Only make it in soft shore.
European tires:
There are many great European foam tire brands that use their own types of foam, as well as traditional foams. Someone with more knowledge about them will need to fill this in!
Tire Diameter:
If you are racing on carpet, you have to evaluate how much grip your track has. If your track is low to medium grip, you can run bigger tires. If you are on higher bite you have to cut them smaller, there is simply no way around it. Bigger tires are needed for asphalt, especially in the rear. The larger tires provide much needed lateral bite.
Carpet (mm):
Low - Medium Bite
Front: 42.0 - 42.5
Rear: 42.5 - 43.00
Medium - High Bite
Front: 40.5 - 41.0
Rear: 41.5 - 42.0
Big Race
Front: 39.5 - 40.0
Rear: 40.5 - 41.0
Asphalt (mm):
Parking Lot
Front: 43.0 - 44.0
Rear: 44.0 - 45.0
Prepped High Bite
Front: 42.0 - 43.0
Rear: 43.0 - 44.0
Tire Saucing:
Most facilities have moved towards odorless traction additives such as SXT. Some of additives evaporate very quickly and some do not. This seems to be something that is also dependent on tire compound and ambient temperature. For example, saucing a Green compound seems like it never dries, especially when tjhe temperature is lower. We have found that wiping the tires off 15 minutes before we go run allows the sauce to cure, which makes the car come in much quicker with Green rears. Blue compounds on the other hand, do fine when wiped off right before hitting the track.
Saucing half front and full rear is a good initial starting point. If the front of the car is too agressive you can sauce les than half, or for a shorter amount of time. On black carpet the car may be numb to sauce changes, either a long or short sauce can produce very similar handling.
Tire Fuzzing:
In conditions of increasing grip, foam tires will somewtimes get sticky and pick up fuzz and debris from the track. This is highly dependent on the rubber sedan tire that is being run at your local track and the compound/ type of foam you are running on you car. The softer the sedan tire and the harder/higher rubber content in your foam tire, trouble with fuzzing seems more likely to occur.
There are ways to get around fuzzing under most conditions, and usually involves the selection of the correct foam compound. The more fuzz you get, the softer/lower rubber content you want to run.
Examples:
Problem: Car fuzzes with Lilac/Team Purple fronts and car starts pushing.
Solution: Use a softer front tire and or different family of foam. Replace it with Blue or Double Blue front. Alternatively you can sauce the front tires harder and tune the car for less front end bite.
Problem: Car loses rear bite 6 minutes into the run. Blue rear tires look almost clean but have small carpet hairs.
Solution: Use Green rear tires. The softer compound wears instead of getting sticky, minimizing fuzz. Possibly a longer sauce will prevent fuzzing.
Alternatively, mild tire fuzzing can be remedied with longer sauce soak times, particularly if you are using SXT3 as your house sauce.
Tire Selection:
Starting out, pick 2 tire compounds for the front and rear. The following should have you covered 99% of the time.
Rear - Green and Blue (BSR) or Green and Light Blue (JFT)
Front - Blue and Double Blue (BSR) or Blue and Dark Blue (JFT)
You may wonder about other compounds out there and if they might be better, trust me, they probably won't be. Even if there are other tires that can be as fast, the synthetic family wears out really fast and the high natural rubber will probably fuzz on you over an 8 minute run. The blends family seems to be the most versatile foam type available today. They last awhile, and sticking to them will make your process of tire selection simpler.
Tire Charts:
BSR/CRC/Jaco
Contact
Corally
JFT (Japan Foam Tire)
Ulti
Enneti (Xceed)
ELECTRONICS:
ESC:
As of now, ROAR is staying 1S (3.7V nominal; 4.2V fully charged) for 1/12. There are many 1S ESC's with a built in BEC so nothing else is required to power the receiver and servo.
If you don't want to lock yourself into a 1S specific ESC, you do have other options! It is possible to use your 2S ESC without a booster or receiver pack, and the ESC simply supplies the lower voltage. If that does not appeal to you, you will need to use an Rx pack or booster. The Rx pack and booster will both supply the receiver with a higher voltage than the 1S pack.
If you decide to use an Rx pack, MAKE SURE TO REMOVE THE RED WIRE FROM THE ESC PLUG THAT GOES INTO THE RECEIVER!!!
If you choose to use a voltage booster, it works exactly how it sounds. Instead of plugging the ESC into the receiver, it plugs into the booster, and the booster plug goes to the ESC, supplying the higher voltage.
1S ESC:
If there are any missing please add them!!
If anyone would like a need for a chart comparing the ESC's specs PM fenton06 and I'll get one made and put in here!
DISCONTINUED 1S ESC:
Voltage Boosters:
Servos:
BODIES:
Black Art (CRC - US Dist):
  • Audi R8C - BA002 - .020 Thick
  • Black Market (Mohawk 12) - BA005 - .020
  • Lola B10 - BA006 - .020 thick
  • Toyota TS030 - BA008 - .020 thick
    Lola - black/red, TS030 - green/pink
PROTOForm:
Reflex Racing/RSD:
PAN CAR TUNING:
Pan Car Front Suspension Tuning:
DISCLAIMER : The following tuning advice was written based on the tuning experience of the author and may not hold true for all cars, drivers, or surfaces. In the end the best tuning advice is to experiment and make changes one at a time so you can track your changes and find the car balance that works best for your driving style. One real world test is worth a million ‘expert’ opinions.
Front End Type:
All popular modern pan car front suspensions are very similar, with a few exceptions such as Speedmerchant New School but most of the info in this wiki applies to them as well. For the most part, they consist of a rigid bottom arm, an upper A-arm, and a kingpin with a spring. There are different flavors of this general design, such as the CRC Dynamic Strut that uses a threaded kingpin and upper pivot ball instead of the Associated style that uses a kingpin that goes through the entire steering knuckle assembly, but their operation is the same with the rigid lower arm and the upper arm controlling the arc of movement as the suspension is compressed.
Assembly:
More so than in almost any other part of the car, the front suspension of your 1/12 car must move absolutely free. Reamers and hobby knives are important here, as any binding will cause the car to corner unpredictably. A little play in the suspension is a good thing, and racers will often find that ‘worn in’ suspension pieces function a little better than new.
Springs:
Besides tires, spring rate is the most important part of deciding how your car will handle through corners, but are somewhat complicated. As a general rule of thumb, a very hard front spring will have somewhat less steering grip than a softer spring with the same suspension setup and tires, but not as much as in other classes such as touring or offroad. On carpet, springs of different tension can be used to tune how your car will maintain or lose energy through corners with the following general rule of thumb:
Hard Spring (0.55mm or harder): Less overall steering, quick reaction to driver input, less on power steering, harder turn-in with potentially lazy mid-corner and exit.
Soft Spring (.45mm): More overall steering especially at low speed, slightly slower reaction to driver input, more on-power steering, less aggressive turn-in but can ‘hook’ and give better mid-corner and exit.
It is worth noting that front springs from different suppliers are often very different, in both height, wire thickness, and coils for a given spring height meaning that a “medium” spring from one manufacturer may be the “hard” spring for another. To make accurate changes you may want to use one spring maker and stick with their line.
Another aspect to pan car springs is that they can get “blown out” and collapse, no longer as stiff or as tall as they were. These should be replaced with fresh springs to ensure consistent handling.
Dampening:
This is generally a minor adjustment, but adding dampening tube fluid to the front kingpins of a 1/12 car can give it a little more initial steering. Often unusual compounds see use here, such as Losi Smart Diff Grease or Associated Green Slime being a popular front kingpin lube.
Caster and Reactive Caster:
Caster is the angle of the kingpin, almost always angling back to the rear of the car, with a typical range from 0-10 degrees. Increasing your caster will typically result in less turn-in but a little more control, more steering exiting the corner, and somewhat increased straight-line stability with less tendency to wander because a wheel running caster will tend to straighten itself. Less caster will usually give you more off-power steering, but often with correspondingly less on-power when accelerating out of the corner.
Running reactive caster attempts to use both of these aspects to increase overall steering: when the car loads up on the outside front tire, the caster angle decreases, increasing the front end ‘hook’ as you enter the corner and then giving you the high caster on-power steering as you exit and weight is transferred off the front end. More reactive caster means more overall steering, but can mean you may have to adjust your driving style to drive more ‘ahead of the car’, needing to predict where the front end will grip.
As grip increases, less reactive caster is the normal tuning change made to keep the front end of the car from gripping too hard and oversteering and prevent traction roll. Static caster adjustments are still used to change the cars on power / off power steering balance.
Reactive Camber and Front Roll Center:
Reactive camber or camber gain is how much camber is added the front wheels as the suspension compresses. This can be increased or decreased by changing the angle and length of the top arm. Short, angled arm = more. Long, flat arm = less. More reactive camber will typically cause the car to “roll up” on the outer front wheel, transferring more weight in a turn and give more steering up to the point at which the tire is overloaded. This is generally more front grip and weight transfer than wanted on carpet, and as a result most cars run a flatter longer front arm.
Roll Center is the point on which the car will twist laterally or ‘roll’ during cornering. This can be raised or lowered by changing the angle and length of the top arm, with a short angled arm raising is slightly and a long flat arm lowering it. From what I have calculated most modern 1/12 cars meant for carpet have a roll center somewhere around the height of the chassis plate or just below it, but due to the lower arms being rigid and flat the roll center cannot be under the bottom of the tires like it often is on a touring car.
These two are inexorably linked in pan cars. Top arm length can be changed by the top arm mount in or out using shims or a CRC Long Arm kit, but is generally a minor tuning choice. Tuning of roll center with shims is usually a minor tuning choice in a pan car with a rigid bottom arm due to how the car cannot gain extra mechanical advantage on the lower arm as you can in a touring car, while reactive camber can be a significant driver of the car’s performance. In a modern car running on carpet the kit setup is usually perfectly fine.
Front End Alignment:
Static camber is the angle of your front wheels at rest, typically somewhere from 0 to 1.5 degrees on a pan car depending on surface, tire choice, and other factors, but a good starting point is usually somewhere around 0.5 degrees. More camber will typically give more steering, but many racers use static camber to ensure that their tires wear flat even if that means not having exactly equal camber on both sides of the car. This is adjusted by threading in and out the upper turnbuckle or pivot ball.
It is also worth noting that when running on high grip the flex and deformation of your chassis, suspension parts, and front wheels can become significant and cause uneven front tire wear. Some troubleshooting of the right combination of static camber, camber gain, caster, and tire/rim choice may be necessary to ensure even front tire wear.
Toe-In:
The front toe is one of the more easily adjusted aspects of the car and can have a significant effect on the attitude of the car due to it being a quick way to moderately adjust Ackerman without making significant other changes. With nothing else being adjusted, going from zero toe to toe-in will give a car a harder turn-in and will tend to scrub speed with the front end as opposed to using drag brake. This can be necessary when racing in Super Stock or higher power classes and will allow you to drive more aggressively, and can help the car track straighter under power. Toe-out will tend to make the car coast more through corners due to reducing the steering angle of the outer front tire. If a car has too much off-power steering but is otherwise stable, adding toe-out can calm the car but may the car to wander on the straights especially if the front end setup is very soft.
Ackerman:
Ackerman is the difference in steering angle between the two front tires during a turn. It is the result of how during a turn the inside of the car experiences a tighter circle and needs correspondingly more steering angle, but is also an important tuning tool. More Ackerman means having more inside wheel steering angle relative to the outer wheel, less means that the difference in steering angle is smaller.
To add or remove Ackerman, using a servo horn that spaces the links further apart (such as a Kimbrough Small Servo Saver, the outer holes on a Tamiya or Xray servo saver) will have more Ackerman than a servo that puts the links close together (Kimbrough Medium inner holes, Tamiya or Xray inner holes.) The rule of thumb is that a servo that puts the ball studs close together but spaced away from the servo horn will have less Ackerman than one that spaces them far apart and close to the servo horn. Ackerman changes will have the same effect as changing toe with more Ackerman being effectively toeing the wheels out and less toeing them in, but will not affect the straight-line attitude of the car.
Turning Circle / Steering Angle:
In offroad or even touring car you can set up the car to use the full angle of the steering 100% of the time. You will almost certainly not be able to do this in 1/12 scale. It goes without saying that as you turn up your steering angle you will gain steering often to the point of the car being undriveable. The quickest way to set the steering correctly is to set the sub-trim in your radio such that the car tracks straight and the servo horn is straight up and down, then set the endpoints equally such that they don't quite hit the steering bump-stops, then turn down the dual-rate or total throw from there. A typical starting point is somewhere between 45 and 60% of the total steering throw, or a 4-5' turning circle.
Pan Car Rear Pod Tuning:
Modern pan cars are all link cars with a center pivot ball and solid rear axle. This suspension system is required by ROAR rules and has the advantage of being simple, lightweight, and inexpensive compared to other more exotic methods of rear suspension, but it has some complicated movements that can be unintuitive.
Motion of the Rear Pod:
Due to how the rear pod is a solid axle, the only motion the pod itself sees is the main pivot up and down, but due to the main chassis being independently sprung it will feel the lean, dive, and squat of the main chassis as the car is driven. The lateral forces of the main chassis during cornering is transmitted through the main pivot ball and side links, the roll through the side springs and side dampeners, and the squat and dive through the main shock and spring. In addition, the torque of the motor against the pinion gear both during acceleration and braking is significant enough to cause a change in attitude even in low-powered classes. The motor pinion will try to “climb” the spur gear, lifting the center pivot of the car and countering the “squat” of the main chassis weight being transferred backward by the acceleration or the opposite under brakes.
Main Shock:
The adjustment of the main shock of a pan car is one of its more important tuning parameters. Spring, dampening oil, and pod droop are all controlled by the main shock.
Main Spring:
A soft main spring generally means more rear grip and more forgiving off-power, while a stiffer spring can mean more steering especially off-power, but the main spring must also be stiff enough to prevent the chassis from dragging when running on high grip. For most cars the kit spring is a medium weight spring that is a good starting point.
Main Shock Dampening:
The weight of the main shock oil will determine how fast the car will react off-power. 30wt or roughly 300cps shock oil is a good starting point, going up in weight will increase initial off-power turn-in, while going down will generally make initial turn-in softer. Often a heavier shock oil can make the car transition from entry to mid to corner exit smoother, where a car with light fluid may have a more pronounced ‘hook’ in the mid corner.
Side Springs:
The side springs transfer the roll motion of the main chassis to the rear plate via spring tension. Softer side springs give the car more rear grip and can make the car have a smoother steering feel. Stiffer springs promote the cars rotation and give more steering. You can either pre-load side springs or let them float, due to all side springs being progressive beehive shaped springs pre-load makes them effectively harder and will give more steering, but a small amount of pre-load can also make the care more predictable and forgiving. In conditions of extremely high grip, it may be possible to run no side springs at all due to the steering afforded by the tacky running surface and helps prevent traction-roll, likewise in extremely low grip when rear stability is absolutely necessary. Generally 1/12 cars run soft side springs but stiffer ones can be very common in Pro 10, WGT, or WGT-R.
Side Dampener Tubes:
Heavier tube lube will keep a car flatter at corner entry, initiating quicker. It may also make the car square off the corner entry when the grip gets beyond med-high. Going lighter will reduce steering initiation and maybe preferred on higher grip. This parameter is really unique to the driver preference, as some drivers are very fast and consistent with heavily dampened cars while others prefer softer setups.
Droop:
Controlled by the length of the shock, adjusting the rear pod droop is extremely important on high-grip surfaces. Reducing droop prevents the car from transferring weight during cornering and will give more rear stability and prevent traction-roll or problematic lifting of the inside rear tires during cornering, low droop can also give the car slightly more on-power steering. Increasing will allow the car to transfer more weight and dive harder into corners, but by allowing the center of the car to rise you will be more prone to traction roll issues. A typical starting point is 1-2mm of droop from ride height, but 0mm is often used on high grip.
Pan Car Differential Tuning:
This is officially where the Black Magic starts. Highly successful pan car racers can have very different ways of building diffs, but the following tips have helped multiple racers assemble consistent pan car diffs:
All modern pan cars are direct drive and use a ball-diff type solid axle. This is the lightest and most efficient manner of transferring power to the drive wheels, and by far the simplest drive system used in RC. In spite of its simplicity and low number of parts, pan car differentials are often miss-understood, particularly by those who have never raced pan cars before. This short guild will hopefully clear up any misconceptions about assembly, tuning, and troubleshooting of pan car differentials for beginners.
Assembly:
It is recommended that you use an electronics cleaner or plastic-safe motor spray to clean the dirt, oils or grease out of even fresh parts to ensure a good diff action. Some racers will blast new bearing grease out of bearings before re-oiling with light oil, but this may not be as beneficial as some believe and that light oil can get into the diff and cause slipping. The most important parts to get clean and dry are the diff rings, diff balls, and spur gear. Then assemble the diff according to the kit instructions, but refrain from adding grease until the next step.
When assembling your differential, pay attention to clearances between different moving surfaces, bearings should fit snug and spin free, including the bearing on which the spur gear is mounted because if the spur gear is not tight with its carrier bearing it will not spin true. With the diff assembled but not yet greased there should be a tick of side-to-side play in the spur gear when torqued side-to-side, indicating that the diff balls and not the gear are in contact with the diff rings. Check the action of the diff with it dry, as it will be easier to determine the source of binding or roughness than it would be before greasing the diff. If it turns smooth but with good ‘bite’ between the diff balls and ring gears without slipping, the spur gear and diff balls are ready for grease.
Almost without fail racers from other RC classes such as offroad or touring car assemble their first pan car diffs with far too much grease. It is important to understand that the point of grease in pan car diffs is not to smooth out the operation of the components as they mesh together as it is in a gear diff, but to lube the contact between spur gear spinning diff ball.
The type of grease to use is white silicone grease such as Team Associated Stealth grease. This is not “good grease” as it is not slippery and does not cushion metal surfaces well, but that is the point, you are counting on the friction between the diff ball and diff ring to transfer all of the power your motor makes to the axle. Using more slippery grease like black carbon/moly grease will make your differential slip.
To apply grease, remove the spur gear with the diff balls still in their pockets, and dab a tiny amount of grease to each diff ball, and by tiny I mean that the dot of grease should just barely cover the visible surface of the diff ball, steady hands will be necessary. With the dab of grease on each diff ball, use your thumb and forefinger to roll each diff ball in its pocket to evenly spread the grease on the inner surface of the spur gear. Most of the grease will wind up on your fingers, and that is intentional. This is the most reliable action the author has found to get an appropriate amount of grease into the diff.
The next step may be slightly controversial, as we have already removed most of this admittedly tiny amount of grease from the spur gear/diff ball assembly: Take a clean shop towel or rag and firmly wipe down both sides of the spur gear, with the objective of getting all of the grease off from both sides of the plastic gear except for what is in the diff ball pockets. This is necessary to ensure that excess grease does not get onto the ring gears. DO NOT GREASE THE RING GEARS, enough grease will get on them to ensure good operation just from the grease left in the diff balls. Re-assemble the diff.
Setting Differential Pre-Load:
A pan car will almost always benefit from the pre-load of the diff only being strong enough to prevent the diff from slipping. A tight or viscous diff like the oil-filled gear diffs now popular in touring car will lead to unpredictable handling and oversteer. Also, over-tightening the diff can damage either the thrust bearing assembly or outside bearing. As you tighten the diff, check how much force it takes to turn the slip the spur gear, if it takes some effort with your thumb, the diff is probably tight enough. Another way to measure if the diff is tight enough is on-track, if your car will spin the tires from a standing full-throttle start before slipping the diff it is tight enough to race.
A very common issue is that your diff requires excessive preload to prevent slipping, the most likely explanation is that you used too much grease or some other oil has gotten into the diff in which case a clean-out and re-greasing of the diff would be useful. If you assembled the diff dry and had it didn’t slip, but it slips after adding grease, you need to use less grease and try to keep that grease from getting onto the surface of the diff rings. One option would be to spin up the diff with the motor or by hand, then disassemble and clean the diff rings with motor spray before re-assembling and checking the tension by hand again. This can use the centrifugal force of spinning the diff to remove excess grease from the spur gear. DO NOT simply hold one tire to spin up the diff and other tire to full speed especially if running higher powered classes, this is far more RPM difference than the diff will ever see during racing and may damage your spur gear from the heat. Free-spinning the axle assembly is fine to remove excess grease, but don’t over-speed the diff action.
Final Assembly:
When assembling your diff with the pod, take care to not put pre-load on the pod bearings or this may cause binding. Some racers intentionally put a tick of side-to-side play between the pod bearings and the axle by placing a piece of paper between the hub and bearing before tightening it, this may be excessive but will ensure smooth action without a bind.
General Tips:
1: Silicon Nitride diff balls are THE FIRST upgrade the author would recommend to new pan car racers. At under $1 each they are basically the same price as hardened steel and will never need to be replaced, and at nearly diamond-hardness will never flat spot or be the cause of a bad or crunchy diff. One set has lasted the author three different cars.
2: XENON Racing spur gears are the best pan car spur gears. Period. This is particularly true in low-powered classes that use smaller spurs. The plastic they use is distinctly stiffer and better cut than Kimbrough or other softer gears. They do have the ability to take 16 diff balls, but can be run with 8 or 12 and still be perfectly smooth.
3: A diff that uses a dedicated thrust bearing assembly instead of a ‘thrust washer’ that simply pushes against the outer hub bearing have a significant durability advantage. Standard ball bearings are not meant to hold the amount of axial load these diffs require, and when the diff takes a hit such as when you clip a corner with a back wheel that shock zaps right back through that bearing, bending a spot in the race and making the diff feel like it was assembled with diff rocks. The Slapmaster or Yokomo R12 thrust bearing can be adapted to other cars.
4: Unless they are damaged it is generally unnecessary to change diff rings or balls doing general maintenance. A quick clean out and rebuild will do a lot for your diff action. Many instances of diff rings lasting entire racing seasons without issue are commonplace, and haphazardly replacing components looking for smooth diff action is generally unnecessary.
Diff Troubleshooting:
1: Diff feels crunchy –
Check your diff balls and rings, if they are clean and fresh check your bearings to ensure that they are smooth and undamaged. A bearing with a damaged race can still spin relatively smoothly, but cause a crunchy feel, especially when you are not running a thrust bearing in your diff.
2: Diff has a tight spot but otherwise smooth –
Make sure that your diff rings are flat against the axle and hub, and that they are not bent or damaged. Also, a bent or damaged spur gear can make the diff have a tight spot due to the diff balls being forced into an oval-shaped path instead of a circle.
3: Diff feels smooth before the run but seems to tighten during use, causing the car to go loose –
Disassemble, clean, and re-grease the diff. Going too long between rebuilds may cause your diff to go dry and under the heat of racing it will tighten and cause oversteer.
4: Car pulls under acceleration or braking –
Check the pod bearings and axle for any bent or damaged components. Also many times a car that pulls under power will have a damaged wheel, make sure that they spin true.
Pan Weight Distribution:
In a pan car running a transverse battery layout, you may have the choice of running the battery forward in the chassis or back, changing the static distribution of weight. On low grip surfaces such as asphalt this typically coincides with grip, a front mounted battery will have more front grip and a rear mounted would have more rear grip, but this logic falls apart on carpet.
On carpet, especially high-grip carpet, running your pack toward the back of the car can make you prone to traction roll or lifting of the inside rear tires in corners. It also will narrow the cars ‘tuning window’, amplifying the effects of setup changes and changes in conditions. The upside is that under the right circumstances such as a medium-grip carpet track and high-grip rear tires a rear-pack setup can carry a lot of corner speed by preventing the back from rotating and making it ‘follow the front’ instead of pivoting on it.
Running the battery forward in the car or switching to an inline setup will usually make the car easier to drive on carpet. It takes side-load off the rear pivot and rear tires, which mellows the car and helps to prevent traction roll. The car will usually be less sensitive to tuning changes as well.
The static weight distribution the author would recommend to start is about 60% rear, 40% front. A few % change is fine, but try not to have more than 60% on the rear to start as a heavily rear-biased car can begin to be hard to tune. 55%/45% may be easier to drive.
Print Wikipost
Like Tree124Likes
Old 07-19-2002, 09:14 AM   #1141
will the Lunsford Ti turnbuckles fit on an AE 1/12th front end? or do I need the AE ones?
the lunsford turnbuckles will fit.. you only need to know the length of the current turnbuckles
ErikF-Fike is offline   Reply With Quote
Old 07-19-2002, 02:05 PM   #1142
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
Kevin....just done steal my Fluorescent Yellow flame job that fades into Fl. Yellow stars, finishing up on the wing with Fl. Yelllow.....
Dragon Slayer is offline   Reply With Quote
Old 07-19-2002, 02:22 PM   #1143
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
They did the same thing to y'all that they did to us (1/10th onroad) - we actually guaranteed them 10 entries from Northern and Southern Cali and they dumped us months ago. Had we brought our 1/10ths, we prolly would have double entered a couple in 1/12th as well (I prolly would have. . .)
The are also FAR short of max entries - something like 184.
ROAR needs a serious wakeup call! What is it about? Clout? Money? or, rather, what it should be - RACING and the RACERS!!!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 07-19-2002, 02:42 PM   #1144
newracer's Avatar
Maybe they are all running stock instead? there were 12 entries for stock 1/12th.
newracer is offline   Reply With Quote
Old 07-19-2002, 03:25 PM   #1145
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Darn.....I guess i have to go back to the LHS and return all this FL-yellow that I just bought
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-20-2002, 08:37 AM   #1146
darnold's Avatar
Kev- Awwwweee, you promised me a blue body that runs into blue mist and then blue flames finishing in a matt blue with a blue cockpit. Now I'm not going to get it? Wow. LOL, hehehehe
DaveL- I have heard nothing but problems for this race. It seems that their non allowment of traction compond, refusal to treat the racing surface with sugar water or something else killed peoples enthusiasm to run mod 12th.
These are major problems for racing when there is a lack of normative procedures for running the race. How many outdoor races don't allow traction compond? How many races don't treat the track surface? Add in what appears to be the general sentiment of "Our track, Our Rules" and we the racers have some serious problems that the Organizing bodies need to address.
The above attitude is one of the major dings that is still retarding 12th scales comeback. Track owners, managers and workers still are trying to impose their will of what THEY want raced and sold. I just don't get it, I thought this was America but haven't we been seeing the truth of this come out for a while now. Enron, AT&T, Tyco, etc. American business still thinks that it dictates to the consumer and that the consumer can't do anything about it. That is until the consumer takes their business elsewhere and they lose money and shut down.
This in a nutshell is what appears to be happening to this race. I have heard (although it may not be true) that the attitude of "Our Track, Our Race, Our Rules based upon Our LOCAL Racing..." has been in full effect for this race. I have also heard that a fairly prominent Nationally ranked driver and about 20 other racers are boycotting this race because of the lunacy. Doesn't surpise me that most of the other Mod 12th scalers have chosen not to play by these crazy rules and destroy their car as well. Heck, that's why I'm still at home to. Oh, and its this type of crazy stuff that leads to people finding out "secret" equipement and setup advantages that leads to poor competition and a LOT of frustration for most racers. Who wants to play THAT game??? This is one thing that the U.S. Triple Crown tries to avoid (except for the Roar Carpet Nats race) in spite of all of our other problems (such as the trophies, which we are working on).
DS- Audi would be great to run I think and the Proto Courage is a good one that we already have. The Hot bodies Ferrari gives a lot of downforce and looks good (I think, but you guys know my taste descretion). What have been you guys accounts of racing any of these bodies compared to the old standby of the Proto Nissan or Parma Speed8? Do they handle as well? Do they have different handling characteristics?
darnold is offline   Reply With Quote
Old 07-20-2002, 10:26 AM   #1147
newracer's Avatar
at first they wern't going to prepare the track or allow any traction compound. but now they are going to clean and spray it and allow suntan lotion, simple green, and WD-40 for traction compound. I have heard that there is plenty of traction.
Old 07-20-2002, 11:53 PM   #1148
Boomer's Avatar
In fact, it went beyond "our track, our rules" it goes to "our track, our classes" - they brought back the T-1 class (2-door touring) which was VOTED OUT by the Roar membership and dropped both 1/12th mod and 1/10th stock - both of which are legitimate Roar classes (see the rulebook)
I wrote back and forth with Trex (president of Roar) a number of times (letters published on the 1/10th Scale On-Road thread) and got no real answer.
If y'all want a class that actually WANTS you. . . at least look at Norrca. They really WANT 1/10th and 1/12th scale drivers. This year's On-Road Nats was well put together and well run. While they didn't put anything actually ON the track, they allowed compounds and the track ended up being quite hooked.
Old 07-21-2002, 12:22 PM   #1149
Taz_S's Avatar
Point province when you not going to spend the time to prepare the track to be ready for a Nation event, then why go when it going to be sub par. I was one of the driver who plane on going to run TC Mod, 1/12th Mod and Pro 10 but they told us Pro 10 divers we not welcome so I took my other 2 class and stay home.
Let see the list of drivers who love running 1/12th mod that did not sign up.
Billy Easton, Mark Pavidis, Mike Blackstock, Jon Orr,
Mike Dumas, Brian Kinwald.
Who did not sign up this year at all.
Josh Cyrul.
So if these guys are not will to run 1/12th you might think something wrong at the track for them not to do that. It not a fun thing to run one class at big events. To much time to waste away.
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 07-21-2002, 04:45 PM   #1150
Avink1's Avatar
Send a message via AIM to Avink1
Pete and Dave, that was fun racing with you guys last night. I really need to work on my motors you guys were fast. I like the Carpet Knife better than my old Trinity, it seemed to drive much smoother.
Does anyone have a set up for medium to high bite ozite carpet for a Carpet Knife, i checked crc's website but they don't say what side springs are being used and those set ups seem to be for really high bite carpet since they are national events. Just would like to see what everyone is running. Thank you.
Avink1 is offline   Reply With Quote
Old 07-21-2002, 10:30 PM   #1151
darnold's Avatar
Avink1- For mod try white springs with thin Hydra fluid in tubes. Use the Kimbrough axle cams to lengthen the wheelbase and use the lowered rear roll center setup (smaller link balls, I think both CRC and SpeedMerchant sell it and it can be made with Dubro Parts I think). Use .20 springs up front with 3deg Caster and -2deg Camber. Use 60weight oil in the center shock and if you need more rear traction accelating out of the corners then go down to 50weight. For the Shock spring use gold or red and set the tension around 1/4 up front the bottom of the threads. Make sure that you have about 1/8" of backward movement on the pod from level with the chassis plate.
Everyone- I hope I wasn't too hard on the crew hosting the Roar Outdoor Nats this year. My main beef is that we have loopholes in the rules that allow for these types of controversies and potentially poor racing experiences as a result. I commend Roar and everyone else who was able to bring pressure to bear to help the host track see some light. Unfortunately the damage has been done for all. It's a shame it seems.
Old 07-22-2002, 02:13 AM   #1152
Avink1's Avatar
darnold, thanks for the help i'll give that set-up a try. you should come to tchr when you have the chance, i could use your help with chassis and motor set-ups plus its always fun with more people racing, thanks again for your help.
simons bros, i'll try to make it next saturday night to race with you guys again. i forgot how much fun mod 12th scale is, since i've been running the buggy i didn't have much time to run. I gotta get ready for this winter ya know, mitch jeff and joe are going to be fast as always and i gotta try to run with them, o well, it'll be fun. see you guys at the track.
Old 07-22-2002, 06:27 AM   #1153
Avink1's Avatar
does anyone have any pics of some of the older 12th scale cars? i have only been racing 12th scale for a little over a year now, i think, and was just wondering how these cars have evolved over time. so if anyone can post a link or send me an email [email protected] that would be really cool, thanks.
Old 07-22-2002, 10:49 AM   #1154
I don't think you were to hard on anybody with your comments to the nats. I have always felt that the organizer should be offering the standard ROAR classes for that venue at a minimum. These classes have priority over the support classes that typically are based on the popular class in that local area. Having said that, cancelling classes for low turn-outs can be done, but you have to identify a cut-off and the minimum cars in a class. I heard throught the grape vine that ROAR, Trinity and Associated talked about 1/12 mod and when told that the big T and AE weren't having their best drivers run this class, ROAR pulled the plug. I don't like that. Let the privateers go at it. Give them a chance. This goes against their Mission Statement. I am very dissapointed in them. You are reading this from an elected Regional Director.
But the other part is they awarded the race to a track that I understand is operated or run by a former board member that doesn't have a grip on the way these classes are run. I am referring to the traction compound rule. But Dave, we ran with a rule at the carpet nationals and the europeans ran without traction compound for years. We also know that the suntan oil has been very effective on pavement, so I am not sure that is a good reason to be upset or boycott the event. We have all had to deal with things like that and we have ended up running to the level of our ability and had a good time. I think that this shows that drivers are rather fickle about things and should become more resilient and capable of adjusting.
davidl is offline   Reply With Quote
Old 07-22-2002, 03:44 PM   #1155
Boomer's Avatar
davidl - I think you're right on the money - ROAR has gone against its mission statement in seemingly promoting the professionals over the privateers and letting the local track determine the classes to be run. When the governing bodies don't support those under it, harsh words are appropriate.
Down here in SoCal, we aren't all that fickle. If we had been allowed to run (and we DID ask. . .many times) we would have run with or without compound. I ran a number of heats at Norrca without and I did just fine. When we did run compound, we ran Sunblock.
But, to me, it's all about getting our class cancelled - in the case of mine, it was even before we were able to sign up! We were told that our class wasn't standard anymore, but that they would be running a non-standard class in its place.
I, personally, think that the Roar Pres has been far far more fickle than the drivers - we're just a reflection or reaction. . .
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Blue Sky
