    Hide Wikipost
Old 10-28-2016, 12:43 PM   -   Wikipost
R/C Tech Forums Thread Wiki: 1/12 forum
Last edit by: fenton06
This is a place to share knowledge related to 1/12th scale racing. It is not to be used for conversations.
KITS:
Click links to go to manufacturer product page. If any are missing please add them!
TIRES:
Pre-mounted tires readily available in the US:
Pre-mounted tires readily available in the Europe:
  • Hot Race ??
Gluing your own donuts:
https://www.youtube.com/watch?v=hm7z1rz-74s - Special thanks to Edward Pickering!
Truing tires:
https://www.youtube.com/watch?v=8wqHOLWq6Uc - Special thanks to Edward Pickering!
The following information came from HERE, with some editing and information added. Thanks Christian!
THIS MAY NEED UPDATING FOR THE NEW BLACK CRC CARPET
Brands:
BSR, CRC, Jaco:
Pro One is no longer selling to the public, but it and the brands above are all mounted by BSR and use the same foam. The nomenclature of the BSR vs Jaco/CRC is a little different in a few instances but is otherwise the same. The BSR foam consists of three families, and can be identifed as synthetics, naturals, and blends.
Synthetics - The old school, light weight, easy to true "dry feeling" tires. These include tires like CRC/Jaco Yellow (BSR White), Black, Gray, etc. These tires offer the highest wear rate and lowest grip. Many racers continue to use these nder high bite conditions.
Naturals - These tires are usually the best alternative for low bite and asphalt. They include Pink, Magenta, Double Pink, Lilac (BSR Team Purple), Purple, and other tires. These tires provide a ton of grip, but tend to get sticky in high bite conditions. This rubber does not wear as easily, and the cars will pick up gunk and fibers from the carpet under most high bite conditions. This is especially bad if the humidity is high.
Blends - These are the tires most people run today. They were initially called "JFT foam" by some, as it was believed that the tires were the same as the JFT tires. We can divide the blends further into two groups: high rubber and low rubber content. The high rubber would be the new rear Orange and Red from the BSR family, and the low rubber would be the Green and Blue varieties. When, asked about the difference, John Foister from BSR Tires said they came from the same "family" of foam, but they offered different grip. According to John, the Green/Blue has more bite than Orange/Red, but from track testing Oranges offer more bite than Green (being equivalent to in hardness) when the grip is high and absolutely no grip when it is lower. The Orange foam has a denser pore structure and the tire is not as prone to chunking. It is also important to note is that BSR Blue rears are not the same as the BSR Blue fronts!
JFT:
JFT stands for Japan Foam Tire. They started the new wave of foam tires we are all using now (Blue/Blu, Green/Greene, Dbl Blue, etc). These tires are a little different than the BSR tire family, but work in very similar conditions. They offers four varieties A (asphalt), C (carpet), S (???), and R (???). This does not mean that those types only work on that surface, but this is what they recommend.
JFT uses the same foam for fronts and rears if the color is the same.
A: Used on asphalt, considered close to the natural rubber variety and are named consistently with other natural tires.
C: Used on carpet, considered a blend.
S: Used on carpet?, tires are ???
R: Used on carpet?, tires are ???
For setup, the JFT foam seem to generate more bite than the BSR, therefore the car tends to be a little more aggressive.
Ulti:
Ulti is another Japanese brand that offers an array of compounds. They have their own way of rating tires, and are difficult to equate to other brands. They have 4 different varieties, each in varying degrees of hardness.
J: High rubber content tire, similar to Pink/ Magenta. Soft would be close to a pink. These offer the most bite and are great for asphalt/carpet front tire. (J hard being very popular)
X: "Balanced" blend, similar to JFT Blue/ Green. Soft is equivalent to Green, medium to Blue in hardness. Great for carpet!
Y: High synthetic blend with lower grip, and is not a very popular variety.
Z: A very expensive "special" foam that is supposed to be magic on asphalt. Only make it in soft shore.
European tires:
There are many great European foam tire brands that use their own types of foam, as well as traditional foams. SOmeone with more knowledge about them will need to fill this in!
Tire Diameter:
If you are racing on carpet, you have to evaluate how much grip your track has. If your track is low to medium grip, you can run bigger tires. If you are on higher bite you have to cut them smaller, there is simply no way around it. Bigger tires are needed for asphalt, especially in the rear. The larger tires provide much needed lateral bite.
Carpet (mm):
Low - Medium Bite
Front: 42.0 - 42.5
Rear: 42.5 - 43.00
Medium - High Bite
Front: 40.5 - 41.0
Rear: 41.5 - 42.0
Big Race
Front: 39.5 - 40.0
Rear: 40.5 - 41.0
Asphalt (mm):
Parking Lot
Front: 43.0 - 44.0
Rear: 44.0 - 45.0
Prepped High Bite
Front: 42.0 - 43.0
Rear: 43.0 - 44.0
Tire Saucing:
Most facilities have moved towards odorless traction additives such as SXT. Some of additives evaporate very quickly and some do not. This seems to be something that is also dependent on tire compound and ambient temperature. For example, saucing a Green compound seems like it never dries, especially when tjhe temperature is lower. We have found that wiping the tires off 15 minutes before we go run allows the sauce to cure, which makes the car come in much quicker with Green rears. Blue compounds on the other hand, do fine when wiped off right before hitting the track.
Saucing half front and full rear is a good initial starting point. If the front of the car is too agressive you can sauce les than half, or for a shorter amount of time.
Tire Fuzzing:
In conditions of increasing grip, foam tires will somewtimes get sticky and pick up fuzz and debris from the track. This is highly dependent on the rubber sedan tire that is being run at your local track and the compound/ type of foam you are running on you car. The softer the sedan tire and the harder/higher rubber content in your foam tire, trouble with fuzzing seems more likely to occur.
There are ways to get around fuzzing under most conditions, and usually involves the selection of the correct foam compound. The more fuzz you get, the softer/lower rubber content you want to run.
Examples:
Problem: Car fuzzes with Lilac/Team Purple fronts and car starts pushing.
Solution: Use a softer front tire and or different family of foam. Replace it with Blue or Double Blue front.
Problem: Car loses rear bite 6 minutes into the run. Blue rear tires look almost clean but have small carpet hairs.
Solution: Use Green rear tires. The softer compound wears instead of getting sticky, minimizing fuzz.
Tire Selection:
Starting out, pick 2 tire compounds for the front and rear. The following should have you covered 99% of the time.
Front - Green and Blue (BSR) or Green and Light Blue (JFT)
Rear - Blue and Double Blue (BSR) or Blue and Dark Blue (JFT)
You may wonder about other compounds out there and if they might be better, trust me, they probably won't be. Even if there are other tires that can be as fast, the synthetic family wears out really fast and the high natural rubber will probably fuzz on you over an 8 minute run. The blends family seems to be the most versatile foam type available today. They last awhile, and sticking to them will make your process of tire selection simpler.
Tire Charts:
BSR/CRC/Jaco
Contact
Corally
JFT (Japan Foam Tire)
Ulti
Enneti (Xceed)
ELECTRONICS:
ESC:
As of now, ROAR is staying 1S (3.7V nominal; 4.2V fully charged) for 1/12. There are many 1S ESC's with a built in BEC so nothing else is required to power the receiver and servo.
If you don't want to lock yourself into a 1S specific ESC, you do have other options! It is possible to use your 2S ESC without a booster or receiver pack, and the ESC simply supplies the lower voltage. If that does not appeal to you, you will need to use an Rx pack or booster. The Rx pack and booster will both supply the receiver with a higher voltage than the 1S pack.
If you decide to use an Rx pack, MAKE SURE TO REMOVE THE RED WIRE FROM THE ESC PLUG THAT GOES INTO THE RECEIVER!!!
If you choose to use a voltage booster, it works exactly how it sounds. Instead of plugging the ESC into the receiver, it plugs into the booster, and the booster plug goes to the ESC, supplying the higher voltage.
1S ESC:
If there are any missing please add them!!
If anyone would like a need for a chart comparing the ESC's specs PM fenton06 and I'll get one made and put in here!
Voltage Boosters:
Servos:
BODIES:
Black Art (CRC - US Dist):
  • Audi R8C - BA002 - .020 Thick
  • Black Market (Mohawk 12) - BA005 - .020
  • Lola B10 - BA006 - .020 thick
  • Toyota TS030 - BA008 - .020 thick
    Lola - black/red, TS030 - green/pink
PROTOForm:
Reflex Racing/RSD:
SUSPENSION ADJUSTMENTS:
Print Wikipost
Old 05-30-2004, 09:15 AM   #7906
Originally posted by AMGRacer
I am new to 12th scale racing and I wonder if the experts could answer some questions for me.
It seems to me that under acceleration in a 12th scale there is little weight transfer to the rear unlike in a touring car. Am I right? It does appear that the rear pod will flex downwards some, but the middle shock (I have a rc12l3) appears to control the rear wheels contact with the ground due to bumps in the track more so than affecting rearwards weight transfer under acceleration?
Also what is an "average" ride height setting for a 1/12th scale?
In gas sedan racing you usually want your foam tires to be as low profile (side wall) as possible. Is it similar in 12th scale where you use smaller sidewall tires on higher grip surfaces?
Lastly, is there any good online reference material for 1/12th scale tuning?
1/12th scale car setup depends on the surface you are racing on. General rule of thumb is that the less traction the racing surface is providing, the higher the center of gravity (CG) and or the roll center (RC) needs to be. If you are racing on carpet, which provides the optimum in traction, the lower the CR and RC needs to be. This prevents traction rolling. As you move to racing outdoors or on asphalt, then you need to start raising your CG and RC to provide better traction on less than optimum surfaces. The RC can be and most often should be, different from the front of the car to the rear of the car. Changing the RC on a pan car can be difficult due to a lack of adjustability of the suspension but there are ways to improve mechanical grip.
EXAMPLE: If you have an over steer condition under acceleration, which is most often the case on 1/12th cars, you need to increase the RC on the rear of the car or decrease the RC on the front of the car. As I mentioned, due to the minimal ability to adjust the suspension on the rear of a pan car, there are several things you can do.
1. Use a softer compound (durometer) rear tire.
2. Increase the diameter of the rear tire. This in effect raises the rear CG.
3. Use a firmer compound front tire.
4. Decrease the diameter of the front tire. This lowers the front CG.
5. Decrease the thickness of the T bar if you are running a T bar style car.
6. Add cut outs or holes in the T bar to increase flexibility. (Be careful! The T bar is the most fragile part of the pan car suspension.)
7. Remove the center bolt from the middle of the T bar where it attaches to the motor plate.
8. Use lighter weight oil in the center shock.
9. Use a lighter spring on the center shock.
10. Use a stiffer spring on the front kingpins.
11. Increase the toe in on the front of the car.
12. Apply a traction additive to the rear tires but not the front tires.
All of these things or a combination of these things will increase the mechanical grip on the rear of a pan car which will help to eliminate an over steer condition. Joel Johnson grew up racing at our local tracks in the San Francisco Bay Area. I remember one time when the track conditions were so bad that after trying just about everything to increase the traction on the rear of his 1/12th car, he ended up putting layers of tape over the battery slots so the batteries would not set down in the slots. This raised the CG on his car providing more weight transfer which increased his rear grip! Battery slots in pan car chassis were added to lower the CG for carpet racing.
As it turns out, there are many options to increase the grip on a pan car. Not like there is on a touring car, but enough to make a pan car a most enjoyable and satisfying class. Go over and talk to the person who is putting in the fasted lap times and ask him or her what set up they are using remembering that their set up may only get you close. The same holds true for any setup you get off of the internet. Understanding your driving style/abilities and the track conditions is paramount in setting up your any car, scale racing or 1:1 racing.
The key thing to remember is it must be fun!!
Thanks heaps guys.
Crashby is offline   Reply With Quote
Old 05-30-2004, 10:42 AM   #7907
Super Steve's Avatar
Send a message via AIM to Super Steve
i get loads of oversteer.
I am running pruple front, grey rear.
Front tires are worn and thge grey rears are huge (new tires untrued)
I also put compund just on the rear tires.
What front toe in, out do you guys run?
I have like 2 or 3 degree to in on both sides because i can't shorten the turnbuckles any more.
Any ideas?
Super Steve is offline   Reply With Quote
Old 05-30-2004, 11:43 AM   #7908
desslok,
Who are you calling for parts? Talked with the Team CRC guys Friday....
I mentioned I saw this on the Tech board.... they have all the parts you listed in stock. Give them a ring or e-mail.
Also, someone mentioned that the CRC wheels weigh to much.... hhhmmm,
CRC tires and wheels can't be too heavy to win at the most competitive stock races in the world. The results speak for themselves;
1-2 in stock at the Indoor Champs in Cleveland and 1-2 at the 2004 ROAR Nats.
insideline is offline   Reply With Quote
Old 05-30-2004, 01:14 PM   #7909
Send a message via ICQ to Cobra81li200
Any ideas?
I'm not a pro12 pro (yet) but from what I know, smaller tires usually gives much more grip. I think your problem might come from the difference in diameter between your front and rear tires. Try truing your rear tires to a smaller diameter and try again...
Cobra81li200 is offline   Reply With Quote
Old 05-30-2004, 05:07 PM   #7910
Default parts.
I just tryed to order over the web all the parts were listed as unavailable.
I will try again it's been a few days..
ok just checked on there website.. they still show that the parts are un available. I am useing there web order page and when I look at the cart with my requested items the web form states that there not available.
should I order by phone ?
desslok is offline   Reply With Quote
Old 05-30-2004, 09:01 PM   #7911
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
im acquiring a 12l3 in a trade soon and i plan on racing it-ive ran tc3 a couple times on the track is there anything i should kno before racing the L3?? what foam combination should i use, running on a med/hi grip carpet, pretty technical? and also where can i find set-ups? should i ask guys at the track?
-thanks
-ryaN-
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 05-30-2004, 09:09 PM   #7912
Send a message via AIM to Adam Hartzell
-thanks
-ryaN-
Will you be running the car at Larry's? If you are than understand that the amount of grip there will make a 1/12 feel a lot more twichey than usual. I have been racing there for a long time now and have found that Jaco Purple fronts and grey rears seem to be the best. The TRC tires offer more bite but it is not needed at larrys.
Just remember to take it real slow at first as a 1/12 is a lot less forgiving than a TC. I should be there this Thursday doing some testing. Just look for the guy in the PRC shirt. I will be there from 11 am til close.
Adam Hartzell is offline   Reply With Quote
Old 05-30-2004, 09:22 PM   #7913
rdub202's Avatar
ya i will be running it at larrys
-im getting greens with the kit but i will pick up purples and grays
--also what about servo? not expensive but not cheap
---ESC also? same as above
i will not be there thursday it wont be ready by then i might not even have it then but ill keep in touch-do u race fridays?
-r
Old 05-30-2004, 09:29 PM   #7914
I race only in the winter. I just like to test new stuff during the summer.
For a good servo thats cheap I love the Airtronics 94145. I have been using the same one for a long time without a problem.
As far as the ecs goes the LRP quantum Sport without reverse is good for the price but I would spend a little extra and get a Quantum 2 or a VFS2000. I prefer the VFS myself, but The Q2 is just as fast and much easier to use.
Old 05-30-2004, 09:46 PM   #7915
rdub202's Avatar
well that was a little more than i expected to pay but ya gotaa do what u gotta do right?
Old 05-30-2004, 10:29 PM   #7916
desslok,
I just went to their site to check out the situation....
The "none available" shown in the list under the heading "Image" means that there is no picture or image available of the part, NOT that the part is not available. This simply means that there is no picture for the part on the site.
Give them a call or e-mail, or just send in the web order. I bet they have your stuff and you'll get your order quick.
Old 05-31-2004, 10:59 AM   #7917
Default I feel so silly.
oh man I cant believe that I did that.. I dont know why I just did not read the screen better.
I think this qualifies as a Doh.. moment.
Old 05-31-2004, 02:28 PM   #7918
Exclamation Cobra
Get some PINK rears. You will love them in low traction asphault. Greys are for carpet.
Larger tire diamater makes for better traction due to more flex in the side walls. Try em you will see.
David Root
David Root is offline   Reply With Quote
Old 05-31-2004, 02:33 PM   #7919
Cobra--If you still slide with pink rears get blue. They will wear faster but the car will stick.
Old 06-01-2004, 06:29 AM   #7920
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
anybody trading 1/12?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
CL, rccartips
SEO by vBSEO 3.5.0
