    Hide Wikipost
Old 10-28-2016, 12:43 PM   -   Wikipost
R/C Tech Forums Thread Wiki: 1/12 forum
Last edit by: fenton06
This is a place to share knowledge related to 1/12th scale racing. It is not to be used for conversations.
KITS:
Click links to go to manufacturer product page. If any are missing please add them!
TIRES:
Pre-mounted tires readily available in the US:
Pre-mounted tires readily available in the Europe:
  • Hot Race ??
Gluing your own donuts:
https://www.youtube.com/watch?v=hm7z1rz-74s - Special thanks to Edward Pickering!
Truing tires:
https://www.youtube.com/watch?v=8wqHOLWq6Uc - Special thanks to Edward Pickering!
The following information came from HERE, with some editing and information added. Thanks Christian!
THIS MAY NEED UPDATING FOR THE NEW BLACK CRC CARPET
Brands:
BSR, CRC, Jaco:
Pro One is no longer selling to the public, but it and the brands above are all mounted by BSR and use the same foam. The nomenclature of the BSR vs Jaco/CRC is a little different in a few instances but is otherwise the same. The BSR foam consists of three families, and can be identifed as synthetics, naturals, and blends.
Synthetics - The old school, light weight, easy to true "dry feeling" tires. These include tires like CRC/Jaco Yellow (BSR White), Black, Gray, etc. These tires offer the highest wear rate and lowest grip. Many racers continue to use these nder high bite conditions.
Naturals - These tires are usually the best alternative for low bite and asphalt. They include Pink, Magenta, Double Pink, Lilac (BSR Team Purple), Purple, and other tires. These tires provide a ton of grip, but tend to get sticky in high bite conditions. This rubber does not wear as easily, and the cars will pick up gunk and fibers from the carpet under most high bite conditions. This is especially bad if the humidity is high.
Blends - These are the tires most people run today. They were initially called "JFT foam" by some, as it was believed that the tires were the same as the JFT tires. We can divide the blends further into two groups: high rubber and low rubber content. The high rubber would be the new rear Orange and Red from the BSR family, and the low rubber would be the Green and Blue varieties. When, asked about the difference, John Foister from BSR Tires said they came from the same "family" of foam, but they offered different grip. According to John, the Green/Blue has more bite than Orange/Red, but from track testing Oranges offer more bite than Green (being equivalent to in hardness) when the grip is high and absolutely no grip when it is lower. The Orange foam has a denser pore structure and the tire is not as prone to chunking. It is also important to note is that BSR Blue rears are not the same as the BSR Blue fronts!
JFT:
JFT stands for Japan Foam Tire. They started the new wave of foam tires we are all using now (Blue/Blu, Green/Greene, Dbl Blue, etc). These tires are a little different than the BSR tire family, but work in very similar conditions. They offers four varieties A (asphalt), C (carpet), S (???), and R (???). This does not mean that those types only work on that surface, but this is what they recommend.
JFT uses the same foam for fronts and rears if the color is the same.
A: Used on asphalt, considered close to the natural rubber variety and are named consistently with other natural tires.
C: Used on carpet, considered a blend.
S: Used on carpet?, tires are ???
R: Used on carpet?, tires are ???
For setup, the JFT foam seem to generate more bite than the BSR, therefore the car tends to be a little more aggressive.
Ulti:
Ulti is another Japanese brand that offers an array of compounds. They have their own way of rating tires, and are difficult to equate to other brands. They have 4 different varieties, each in varying degrees of hardness.
J: High rubber content tire, similar to Pink/ Magenta. Soft would be close to a pink. These offer the most bite and are great for asphalt/carpet front tire. (J hard being very popular)
X: "Balanced" blend, similar to JFT Blue/ Green. Soft is equivalent to Green, medium to Blue in hardness. Great for carpet!
Y: High synthetic blend with lower grip, and is not a very popular variety.
Z: A very expensive "special" foam that is supposed to be magic on asphalt. Only make it in soft shore.
European tires:
There are many great European foam tire brands that use their own types of foam, as well as traditional foams. SOmeone with more knowledge about them will need to fill this in!
Tire Diameter:
If you are racing on carpet, you have to evaluate how much grip your track has. If your track is low to medium grip, you can run bigger tires. If you are on higher bite you have to cut them smaller, there is simply no way around it. Bigger tires are needed for asphalt, especially in the rear. The larger tires provide much needed lateral bite.
Carpet (mm):
Low - Medium Bite
Front: 42.0 - 42.5
Rear: 42.5 - 43.00
Medium - High Bite
Front: 40.5 - 41.0
Rear: 41.5 - 42.0
Big Race
Front: 39.5 - 40.0
Rear: 40.5 - 41.0
Asphalt (mm):
Parking Lot
Front: 43.0 - 44.0
Rear: 44.0 - 45.0
Prepped High Bite
Front: 42.0 - 43.0
Rear: 43.0 - 44.0
Tire Saucing:
Most facilities have moved towards odorless traction additives such as SXT. Some of additives evaporate very quickly and some do not. This seems to be something that is also dependent on tire compound and ambient temperature. For example, saucing a Green compound seems like it never dries, especially when tjhe temperature is lower. We have found that wiping the tires off 15 minutes before we go run allows the sauce to cure, which makes the car come in much quicker with Green rears. Blue compounds on the other hand, do fine when wiped off right before hitting the track.
Saucing half front and full rear is a good initial starting point. If the front of the car is too agressive you can sauce les than half, or for a shorter amount of time.
Tire Fuzzing:
In conditions of increasing grip, foam tires will somewtimes get sticky and pick up fuzz and debris from the track. This is highly dependent on the rubber sedan tire that is being run at your local track and the compound/ type of foam you are running on you car. The softer the sedan tire and the harder/higher rubber content in your foam tire, trouble with fuzzing seems more likely to occur.
There are ways to get around fuzzing under most conditions, and usually involves the selection of the correct foam compound. The more fuzz you get, the softer/lower rubber content you want to run.
Examples:
Problem: Car fuzzes with Lilac/Team Purple fronts and car starts pushing.
Solution: Use a softer front tire and or different family of foam. Replace it with Blue or Double Blue front.
Problem: Car loses rear bite 6 minutes into the run. Blue rear tires look almost clean but have small carpet hairs.
Solution: Use Green rear tires. The softer compound wears instead of getting sticky, minimizing fuzz.
Tire Selection:
Starting out, pick 2 tire compounds for the front and rear. The following should have you covered 99% of the time.
Front - Green and Blue (BSR) or Green and Light Blue (JFT)
Rear - Blue and Double Blue (BSR) or Blue and Dark Blue (JFT)
You may wonder about other compounds out there and if they might be better, trust me, they probably won't be. Even if there are other tires that can be as fast, the synthetic family wears out really fast and the high natural rubber will probably fuzz on you over an 8 minute run. The blends family seems to be the most versatile foam type available today. They last awhile, and sticking to them will make your process of tire selection simpler.
Tire Charts:
BSR/CRC/Jaco
Contact
Corally
JFT (Japan Foam Tire)
Ulti
Enneti (Xceed)
ELECTRONICS:
ESC:
As of now, ROAR is staying 1S (3.7V nominal; 4.2V fully charged) for 1/12. There are many 1S ESC's with a built in BEC so nothing else is required to power the receiver and servo.
If you don't want to lock yourself into a 1S specific ESC, you do have other options! It is possible to use your 2S ESC without a booster or receiver pack, and the ESC simply supplies the lower voltage. If that does not appeal to you, you will need to use an Rx pack or booster. The Rx pack and booster will both supply the receiver with a higher voltage than the 1S pack.
If you decide to use an Rx pack, MAKE SURE TO REMOVE THE RED WIRE FROM THE ESC PLUG THAT GOES INTO THE RECEIVER!!!
If you choose to use a voltage booster, it works exactly how it sounds. Instead of plugging the ESC into the receiver, it plugs into the booster, and the booster plug goes to the ESC, supplying the higher voltage.
1S ESC:
If there are any missing please add them!!
If anyone would like a need for a chart comparing the ESC's specs PM fenton06 and I'll get one made and put in here!
Voltage Boosters:
Servos:
BODIES:
Black Art (CRC - US Dist):
  • Audi R8C - BA002 - .020 Thick
  • Black Market (Mohawk 12) - BA005 - .020
  • Lola B10 - BA006 - .020 thick
  • Toyota TS030 - BA008 - .020 thick
    Lola - black/red, TS030 - green/pink
PROTOForm:
Reflex Racing/RSD:
SUSPENSION ADJUSTMENTS:
Print Wikipost
Like Tree40Likes
Old 12-24-2003, 10:58 PM   #5746
davepull's Avatar
yes it would be cheaper but if you bought a 12L3 150.00 and the irs conver 99.00 you would want the lowered pods 50.00 I don't really care for the ae axle plus it is the small ring type so you get the large ring complete kit 70.00 then you want the silva shock 15.00 and then you want the car to be all blue aluminum so you have to get the ae blue 10.00 body kit and ae stand offs 6.00
car 150.00
conversion 100.00
other stuff 150.00
350.00
ya you can sell the other ae stuff but what will you get for it maybe 100.00 then you have to buy tires 40.00 it really adds up if you don't have a 12th scale
the crc t force for the six pack 65.00
red six pack 225.00
295.00 for the red crc car you would have to check with crc to see if this car has the large ring axle.
hope this helps
davepull is offline   Reply With Quote
Old 12-24-2003, 11:00 PM   #5747
davepull's Avatar
Originally posted by racerdx6
Get a hyperdrive. I think that's what I'm going to do. It's basically a 12L3, but they fixed all the things that were wrong with it. It's also got a shorter wheel base, prefect for indoor tracks (atleast most of 'em). The reflex looks like it will be too hard to get parts for. I can also use the old style front end on it if i want to. Ill do some testing with them and see which one is faster, or which one I like more.
the only problem with the hyperdrive car is it has no hop ups incleded. like annodized stuff. plus it is basically a crc six pack
Old 12-24-2003, 11:01 PM   #5748
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I dont know that I like all of this conversion stuff, sounds like it really adds up quick. Despite what everyone says or doesnt say about the Yokomo, it's still at the top of my list, I just do good with Yokomo stuff, and I know I can find a setup to work with it.
My real concern is electronics space, will a GT7 fit?
Old 12-24-2003, 11:05 PM   #5749
www.hyperdriveracing.com
racerdx6 is offline   Reply With Quote
Old 12-24-2003, 11:12 PM   #5750
davepull's Avatar
the gt-7 will fit fine alot of guys like the quantium (i have One) because it is so small. have you seen the new futaba speedo it is made buy lrp for futaba
http://www.futabarc.com/radioaccys/futm0939.html
lrp
http://www.rc10.com/shusting/Catalog...tition_lrp.htm
don't get me wrong the yok car is a good car but you said you like red (crc)
Old 12-24-2003, 11:13 PM   #5751
Kinda looks like a 12L3 with damper tubes...
Old 12-24-2003, 11:16 PM   #5752
lrp
Sweet, I'm really partial to Novak, but at least that will match my Futaba gear even though it's a Quantum. I wonder if it's based off of the Quantum or Q2 though...
I wont buy a car just because it's red, my SD and GT4 didn't come red
Old 12-24-2003, 11:18 PM   #5753
davepull's Avatar
it is based off the quantim 1 which still rocks I just hope that I helped you out.
Old 12-24-2003, 11:21 PM   #5754
Yeah, you helped me out, that's what'll power my 1/12 scale when I get it
Old 12-24-2003, 11:31 PM   #5755
JCB
JCB's Avatar
I like my 12L3. The kit cost me $135. CRC dampner Tubes $35. CRC Lowered Pods $25. IRS Large Ring rear axle $45. Total: $240.
Hope this helps.
JCB is offline   Reply With Quote
Old 12-24-2003, 11:49 PM   #5756
What are the lowered pods?
Old 12-24-2003, 11:58 PM   #5757
What are the differences between the CRC v3.1 and the new v3.2?
James Nguyen is offline   Reply With Quote
Old 12-25-2003, 12:20 AM   #5758
JCB
JCB's Avatar
Randman,
They will allow you to run smaller tires in the rear. Much lower than you would be able to run with the stock ones. In the long run you will save money on tires
Old 12-25-2003, 02:36 AM   #5759
what JCB said is correct... but, if you have to use no.4 adjusters on your axle, AND you need the lowered pods to get it upto 3mm.... then MAN you have SMALL tires! by the time there that small, they are junk anyway!
if you want tire life, then when you true them up, make them a bit bigger than normal.
i dont see why you people are big fans of conversions and stuff, there's hardly anything between 12th cars... the biggest change is springs or t-bar.
get your car, whichever you choose, get it dialled, and then if you are still behind the competition...then get the conversions and stuff.
p.s. dont forget 2nd hand models
merry xmas to all
matt
rice98w is offline   Reply With Quote
Old 12-25-2003, 06:21 AM   #5760
stormperson's Avatar
Send a message via AIM to stormperson
James- I think the differences are listed on the website, from what I could tell, its different standoffs, larger rear axle, the new cheaper CRC lowered pods and i think thats it.
On lowered pods... You can only run your tire so low before the shore rating that it came with is no longer correct. Yes lowered pods are nice however, its not really a great way to save money since you end up hurting yourself with an ill-handling car.
My $.02 on speedo's...
LRP all the way baby! lol. I have had really good luck with all of the lrp Q1's and Q2's that I have owned. Also if you can fit the GT7 and all of the extra's that you have to solder onto to it, then have fun. Between the size of the thing to begin with, then add a power cap, and then try to locate the updated doide... its a realy pain.
However, Novak's ARE BETTER IN STOCK! They do put out more voltage than the LRP. How big of a difference, slight, but it might be worth a tenth or two over a 8 minute race probably, however I did hear this from a novak mod driver who was wondering why he fell off sooner and the comm was more worn than his lrp teammates, and novak confirmed it. just an FYI....
Although I am still sticking to the blue myself.
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
