    Hide Wikipost
Old 09-21-2017, 01:26 PM   -   Wikipost
R/C Tech Forums Thread Wiki: 1/12 forum
Last edit by: DesertRat
This is a place to share knowledge related to 1/12th scale racing. It is not to be used for conversations.
KITS:
Click links to go to manufacturer product page. If any are missing please add them!
TIRES:
Pre-mounted tires readily available in the US:
Pre-mounted tires readily available in the Europe:
  • Hot Race ??
Gluing your own donuts:
https://www.youtube.com/watch?v=hm7z1rz-74s - Special thanks to Edward Pickering!
Truing tires:
https://www.youtube.com/watch?v=8wqHOLWq6Uc - Special thanks to Edward Pickering!
The following information came from HERE, with some editing and information added. Thanks Christian!
THIS MAY NEED UPDATING FOR THE NEW BLACK CRC CARPET
Brands:
BSR, CRC, Jaco:
Pro One is no longer selling to the public, but it and the brands above are all mounted by BSR and use the same foam. The nomenclature of the BSR vs Jaco/CRC is a little different in a few instances but is otherwise the same. The BSR foam consists of three families, and can be identifed as synthetics, naturals, and blends.
Synthetics - The old school, light weight, easy to true "dry feeling" tires. These include tires like CRC/Jaco Yellow (BSR White), Black, Gray, etc. These tires offer the highest wear rate and lowest grip. Many racers continue to use these nder high bite conditions.
Naturals - These tires are usually the best alternative for low bite and asphalt. They include Pink, Magenta, Double Pink, Lilac (BSR Team Purple), Purple, and other tires. These tires provide a ton of grip, but tend to get sticky in high bite conditions. This rubber does not wear as easily, and the cars will pick up gunk and fibers from the carpet under most high bite conditions. This is especially bad if the humidity is high.
Blends - These are the tires most people run today. They were initially called "JFT foam" by some, as it was believed that the tires were the same as the JFT tires. We can divide the blends further into two groups: high rubber and low rubber content. The high rubber would be the new rear Orange and Red from the BSR family, and the low rubber would be the Green and Blue varieties. When, asked about the difference, John Foister from BSR Tires said they came from the same "family" of foam, but they offered different grip. According to John, the Green/Blue has more bite than Orange/Red, but from track testing Oranges offer more bite than Green (being equivalent to in hardness) when the grip is high and absolutely no grip when it is lower. The Orange foam has a denser pore structure and the tire is not as prone to chunking. It is also important to note is that BSR Blue rears are not the same as the BSR Blue fronts!
JFT:
JFT stands for Japan Foam Tire. They started the new wave of foam tires we are all using now (Blue/Blu, Green/Greene, Dbl Blue, etc). These tires are a little different than the BSR tire family, but work in very similar conditions. They offers four varieties A (asphalt), C (carpet), S (???), and R (???). This does not mean that those types only work on that surface, but this is what they recommend.
JFT uses the same foam for fronts and rears if the color is the same.
A: Used on asphalt, considered close to the natural rubber variety and are named consistently with other natural tires.
C: Used on carpet, considered a blend.
S: Used on carpet?, tires are ???
R: Used on carpet?, tires are ???
For setup, the JFT foam seem to generate more bite than the BSR, therefore the car tends to be a little more aggressive.
Ulti:
Ulti is another Japanese brand that offers an array of compounds. They have their own way of rating tires, and are difficult to equate to other brands. They have 4 different varieties, each in varying degrees of hardness.
J: High rubber content tire, similar to Pink/ Magenta. Soft would be close to a pink. These offer the most bite and are great for asphalt/carpet front tire. (J hard being very popular)
X: "Balanced" blend, similar to JFT Blue/ Green. Soft is equivalent to Green, medium to Blue in hardness. Great for carpet!
Y: High synthetic blend with lower grip, and is not a very popular variety.
Z: A very expensive "special" foam that is supposed to be magic on asphalt. Only make it in soft shore.
European tires:
There are many great European foam tire brands that use their own types of foam, as well as traditional foams. SOmeone with more knowledge about them will need to fill this in!
Tire Diameter:
If you are racing on carpet, you have to evaluate how much grip your track has. If your track is low to medium grip, you can run bigger tires. If you are on higher bite you have to cut them smaller, there is simply no way around it. Bigger tires are needed for asphalt, especially in the rear. The larger tires provide much needed lateral bite.
Carpet (mm):
Low - Medium Bite
Front: 42.0 - 42.5
Rear: 42.5 - 43.00
Medium - High Bite
Front: 40.5 - 41.0
Rear: 41.5 - 42.0
Big Race
Front: 39.5 - 40.0
Rear: 40.5 - 41.0
Asphalt (mm):
Parking Lot
Front: 43.0 - 44.0
Rear: 44.0 - 45.0
Prepped High Bite
Front: 42.0 - 43.0
Rear: 43.0 - 44.0
Tire Saucing:
Most facilities have moved towards odorless traction additives such as SXT. Some of additives evaporate very quickly and some do not. This seems to be something that is also dependent on tire compound and ambient temperature. For example, saucing a Green compound seems like it never dries, especially when tjhe temperature is lower. We have found that wiping the tires off 15 minutes before we go run allows the sauce to cure, which makes the car come in much quicker with Green rears. Blue compounds on the other hand, do fine when wiped off right before hitting the track.
Saucing half front and full rear is a good initial starting point. If the front of the car is too agressive you can sauce les than half, or for a shorter amount of time. On black carpet the car may be numb to sauce changes, either a long or short sauce can produce very similar handling.
Tire Fuzzing:
In conditions of increasing grip, foam tires will somewtimes get sticky and pick up fuzz and debris from the track. This is highly dependent on the rubber sedan tire that is being run at your local track and the compound/ type of foam you are running on you car. The softer the sedan tire and the harder/higher rubber content in your foam tire, trouble with fuzzing seems more likely to occur.
There are ways to get around fuzzing under most conditions, and usually involves the selection of the correct foam compound. The more fuzz you get, the softer/lower rubber content you want to run.
Examples:
Problem: Car fuzzes with Lilac/Team Purple fronts and car starts pushing.
Solution: Use a softer front tire and or different family of foam. Replace it with Blue or Double Blue front. Alternatively you can sauce the front tires harder and tune the car for less front end bite.
Problem: Car loses rear bite 6 minutes into the run. Blue rear tires look almost clean but have small carpet hairs.
Solution: Use Green rear tires. The softer compound wears instead of getting sticky, minimizing fuzz. Possibly a longer sauce will prevent fuzzing.
Tire Selection:
Starting out, pick 2 tire compounds for the front and rear. The following should have you covered 99% of the time.
Rear - Green and Blue (BSR) or Green and Light Blue (JFT)
Front - Blue and Double Blue (BSR) or Blue and Dark Blue (JFT)
You may wonder about other compounds out there and if they might be better, trust me, they probably won't be. Even if there are other tires that can be as fast, the synthetic family wears out really fast and the high natural rubber will probably fuzz on you over an 8 minute run. The blends family seems to be the most versatile foam type available today. They last awhile, and sticking to them will make your process of tire selection simpler.
Tire Charts:
BSR/CRC/Jaco
Contact
Corally
JFT (Japan Foam Tire)
Ulti
Enneti (Xceed)
ELECTRONICS:
ESC:
As of now, ROAR is staying 1S (3.7V nominal; 4.2V fully charged) for 1/12. There are many 1S ESC's with a built in BEC so nothing else is required to power the receiver and servo.
If you don't want to lock yourself into a 1S specific ESC, you do have other options! It is possible to use your 2S ESC without a booster or receiver pack, and the ESC simply supplies the lower voltage. If that does not appeal to you, you will need to use an Rx pack or booster. The Rx pack and booster will both supply the receiver with a higher voltage than the 1S pack.
If you decide to use an Rx pack, MAKE SURE TO REMOVE THE RED WIRE FROM THE ESC PLUG THAT GOES INTO THE RECEIVER!!!
If you choose to use a voltage booster, it works exactly how it sounds. Instead of plugging the ESC into the receiver, it plugs into the booster, and the booster plug goes to the ESC, supplying the higher voltage.
1S ESC:
If there are any missing please add them!!
If anyone would like a need for a chart comparing the ESC's specs PM fenton06 and I'll get one made and put in here!
DISCONTINUED 1S ESC:
Voltage Boosters:
Servos:
BODIES:
Black Art (CRC - US Dist):
  • Audi R8C - BA002 - .020 Thick
  • Black Market (Mohawk 12) - BA005 - .020
  • Lola B10 - BA006 - .020 thick
  • Toyota TS030 - BA008 - .020 thick
    Lola - black/red, TS030 - green/pink
PROTOForm:
Reflex Racing/RSD:
SUSPENSION ADJUSTMENTS:
Pan Car Front Suspension Tuning:
DISCLAIMER : The following tuning advice was written based on the tuning experience of the author and may not hold true for all cars, drivers, or surfaces. In the end the best tuning advice is to experiment and make changes one at a time so you can track your changes and find the car balance that works best for your driving style. One real world test is worth a million ‘expert’ opinions.
Front End Type:
All popular modern pan car front suspensions are very similar, with a few exceptions such as Speedmerchant New School but most of the info in this wiki applies to them as well. For the most part, they consist of a rigid bottom arm, an upper A-arm, and a kingpin with a spring. There are different flavors of this general design, such as the CRC Dynamic Strut that uses a threaded kingpin and upper pivot ball instead of the Associated style that uses a kingpin that goes through the entire steering knuckle assembly, but their operation is the same with the rigid lower arm and the upper arm controlling the arc of movement as the suspension is compressed.
Assembly:
More so than in almost any other part of the car, the front suspension of your 1/12 car must move absolutely free. Reamers and hobby knives are important here, as any binding will cause the car to corner unpredictably. A little play in the suspension is a good thing, and racers will often find that ‘worn in’ suspension pieces function a little better than new.
Springs:
Besides tires, spring rate is the most important part of deciding how your car will handle through corners, but are somewhat complicated. As a general rule of thumb, a very hard front spring will have somewhat less steering grip than a softer spring with the same suspension setup and tires, but not as much as in other classes such as touring or offroad. On carpet, springs of different tension can be used to tune how your car will maintain or lose energy through corners with the following general rule of thumb:
Hard Spring (0.55mm or harder): Less overall steering, quick reaction to driver input, less on power steering, harder turn-in with potentially lazy mid-corner and exit.
Soft Spring (.45mm): More overall steering especially at low speed, slightly slower reaction to driver input, more on-power steering, less aggressive turn-in but can ‘hook’ and give better mid-corner and exit.
It is worth noting that front springs from different suppliers are often very different, in both height, wire thickness, and coils for a given spring height meaning that a “medium” spring from one manufacturer may be the “hard” spring for another. To make accurate changes you may want to use one spring maker and stick with their line.
Another aspect to pan car springs is that they can get “blown out” and collapse, no longer as stiff or as tall as they were. These should be replaced with fresh springs to ensure consistent handling.
Dampening:
This is generally a minor adjustment, but adding dampening tube fluid to the front kingpins of a 1/12 car can give it a little more initial steering. Often unusual compounds see use here, such as Losi Smart Diff Grease or Associated Green Slime being a popular front kingpin lube.
Caster and Reactive Caster:
Caster is the angle of the kingpin, almost always angling back to the rear of the car, with a typical range from 0-10 degrees. Increasing your caster will typically result in less turn-in but a little more control, more steering exiting the corner, and somewhat increased straight-line stability with less tendency to wander because a wheel running caster will tend to straighten itself. Less caster will usually give you more off-power steering, but often with correspondingly less on-power when accelerating out of the corner.
Running reactive caster attempts to use both of these aspects to increase overall steering: when the car loads up on the outside front tire, the caster angle decreases, increasing the front end ‘hook’ as you enter the corner and then giving you the high caster on-power steering as you exit and weight is transferred off the front end. More reactive caster means more overall steering, but can mean you may have to adjust your driving style to drive more ‘ahead of the car’, needing to predict where the front end will grip.
As grip increases, less reactive caster is the normal tuning change made to keep the front end of the car from gripping too hard and oversteering and prevent traction roll. Static caster adjustments are still used to change the cars on power / off power steering balance.
Reactive Camber and Front Roll Center:
Reactive camber or camber gain is how much camber is added the front wheels as the suspension compresses. This can be increased or decreased by changing the angle and length of the top arm. Short, angled arm = more. Long, flat arm = less. More reactive camber will typically cause the car to “roll up” on the outer front wheel, transferring more weight in a turn and give more steering up to the point at which the tire is overloaded. This is generally more front grip and weight transfer than wanted on carpet, and as a result most cars run a flatter longer front arm.
Roll Center is the point on which the car will twist laterally or ‘roll’ during cornering. This can be raised or lowered by changing the angle and length of the top arm, with a short angled arm raising is slightly and a long flat arm lowering it. From what I have calculated most modern 1/12 cars meant for carpet have a roll center somewhere around the height of the chassis plate or just below it, but due to the lower arms being rigid and flat the roll center cannot be under the bottom of the tires like it often is on a touring car.
These two are inexorably linked in pan cars. Top arm length can be changed by the top arm mount in or out using shims or a CRC Long Arm kit, but is generally a minor tuning choice. Tuning of roll center with shims is usually a minor tuning choice in a pan car with a rigid bottom arm due to how the car cannot gain extra mechanical advantage on the lower arm as you can in a touring car, while reactive camber can be a significant driver of the car’s performance. In a modern car running on carpet the kit setup is usually perfectly fine.
Front End Alignment:
Static camber is the angle of your front wheels at rest, typically somewhere from 0 to 1.5 degrees on a pan car depending on surface, tire choice, and other factors, but a good starting point is usually somewhere around 0.5 degrees. More camber will typically give more steering, but many racers use static camber to ensure that their tires wear flat even if that means not having exactly equal camber on both sides of the car. This is adjusted by threading in and out the upper turnbuckle or pivot ball.
It is also worth noting that when running on high grip the flex and deformation of your chassis, suspension parts, and front wheels can become significant and cause uneven front tire wear. Some troubleshooting of the right combination of static camber, camber gain, caster, and tire/rim choice may be necessary to ensure even front tire wear.
Toe-In:
The front toe is one of the more easily adjusted aspects of the car and can have a significant effect on the attitude of the car due to it being a quick way to moderately adjust Ackerman without making significant other changes. With nothing else being adjusted, going from zero toe to toe-in will give a car a harder turn-in and will tend to scrub speed with the front end as opposed to using drag brake. This can be necessary when racing in Super Stock or higher power classes and will allow you to drive more aggressively, and can help the car track straighter under power. Toe-out will tend to make the car coast more through corners due to reducing the steering angle of the outer front tire. If a car has too much off-power steering but is otherwise stable, adding toe-out can calm the car but may the car to wander on the straights especially if the front end setup is very soft.
Ackerman:
Ackerman is the difference in steering angle between the two front tires during a turn. It is the result of how during a turn the inside of the car experiences a tighter circle and needs correspondingly more steering angle, but is also an important tuning tool. More Ackerman means having more inside wheel steering angle relative to the outer wheel, less means that the difference in steering angle is smaller.
To add or remove Ackerman, using a servo horn that spaces the links further apart (such as a Kimbrough Small Servo Saver, the outer holes on a Tamiya or Xray servo saver) will have more Ackerman than a servo that puts the links close together (Kimbrough Medium inner holes, Tamiya or Xray inner holes.) The rule of thumb is that a servo that puts the ball studs close together but spaced away from the servo horn will have less Ackerman than one that spaces them far apart and close to the servo horn. Ackerman changes will have the same effect as changing toe with more Ackerman being effectively toeing the wheels out and less toeing them in, but will not affect the straight-line attitude of the car.
Turning Circle / Steering Angle:
In offroad or even touring car you can set up the car to use the full angle of the steering 100% of the time. You will almost certainly not be able to do this in 1/12 scale. It goes without saying that as you turn up your steering angle you will gain steering often to the point of the car being undriveable. The quickest way to set the steering correctly is to set the sub-trim in your radio such that the car tracks straight and the servo horn is straight up and down, then set the endpoints equally such that they don't quite hit the steering bump-stops, then turn down the dual-rate or total throw from there. A typical starting point is somewhere between 45 and 60% of the total steering throw, or a 4-5' turning circle.
Pan Car Rear Pod Tuning:
Modern pan cars are all link cars with a center pivot ball and solid rear axle. This suspension system is required by ROAR rules and has the advantage of being simple, lightweight, and inexpensive compared to other more exotic methods of rear suspension, but it has some complicated movements that can be unintuitive.
Motion of the Rear Pod:
Due to how the rear pod is a solid axle, the only motion the pod itself sees is the main pivot up and down, but due to the main chassis being independently sprung it will feel the lean, dive, and squat of the main chassis as the car is driven. The lateral forces of the main chassis during cornering is transmitted through the main pivot ball and side links, the roll through the side springs and side dampeners, and the squat and dive through the main shock and spring. In addition, the torque of the motor against the pinion gear both during acceleration and braking is significant enough to cause a change in attitude even in low-powered classes. The motor pinion will try to “climb” the spur gear, lifting the center pivot of the car and countering the “squat” of the main chassis weight being transferred backward by the acceleration or the opposite under brakes.
Main Shock:
The adjustment of the main shock of a pan car is one of its more important tuning parameters. Spring, dampening oil, and pod droop are all controlled by the main shock.
Main Spring:
A soft main spring generally means more rear grip and more forgiving off-power, while a stiffer spring can mean more steering especially off-power, but the main spring must also be stiff enough to prevent the chassis from dragging when running on high grip. For most cars the kit spring is a medium weight spring that is a good starting point.
Main Shock Dampening:
The weight of the main shock oil will determine how fast the car will react off-power. 30wt or roughly 300cps shock oil is a good starting point, going up in weight will increase initial off-power turn-in, while going down will generally make initial turn-in softer. Often a heavier shock oil can make the car transition from entry to mid to corner exit smoother, where a car with light fluid may have a more pronounced ‘hook’ in the mid corner.
Side Springs:
The side springs transfer the roll motion of the main chassis to the rear plate via spring tension. Softer side springs give the car more rear grip and can make the car have a smoother steering feel. Stiffer springs promote the cars rotation and give more steering. You can either pre-load side springs or let them float, due to all side springs being progressive beehive shaped springs pre-load makes them effectively harder and will give more steering, but a small amount of pre-load can also make the care more predictable and forgiving. In conditions of extremely high grip, it may be possible to run no side springs at all due to the steering afforded by the tacky running surface and helps prevent traction-roll, likewise in extremely low grip when rear stability is absolutely necessary. Generally 1/12 cars run soft side springs but stiffer ones can be very common in Pro 10, WGT, or WGT-R.
Side Dampener Tubes:
Heavier tube lube will keep a car flatter at corner entry, initiating quicker. It may also make the car square off the corner entry when the grip gets beyond med-high. Going lighter will reduce steering initiation and maybe preferred on higher grip. This parameter is really unique to the driver preference, as some drivers are very fast and consistent with heavily dampened cars while others prefer softer setups.
Droop:
Controlled by the length of the shock, adjusting the rear pod droop is extremely important on high-grip surfaces. Reducing droop prevents the car from transferring weight during cornering and will give more rear stability and prevent traction-roll or problematic lifting of the inside rear tires during cornering, low droop can also give the car slightly more on-power steering. Increasing will allow the car to transfer more weight and dive harder into corners, but by allowing the center of the car to rise you will be more prone to traction roll issues. A typical starting point is 1-2mm of droop from ride height, but 0mm is often used on high grip.
Print Wikipost
Like Tree62Likes
Old 02-13-2002, 06:45 PM   #526
darnold's Avatar
BTW put a zero in front of the shim sizes for the ball studs at the front suspension.
Next: I run 1 metal washer from the kit under the front arms with 1.74" fronts down to 1.65" fronts. This car seems to have better clearance than my previous car so you don't need big tires and that helps on high bite tracks. I run the #1 cam down with 1.90" rears and if you run 1.95" rears or higher then try the #2 down. The main thing is to keep the chassis level and get it as close to 3mm and keep it around there as possible. I am just now starting to concentrate on this and it is paying dividends.
Back at the rear of the car make sure you space the rear out to maximum length (ROAR rules) which I think is 6 3/4" this really makes the rear stable. To do this I put .201" spacer on the diff side and with the clamp mounted so that the thin side faces the axle cam I use a .227" washer on that side (left side looking from the back). I use 30wght. oil instead of the 20wght I got in the kit and a blue Assoc spring with light tension (about .150" of thread showing) and a .030" washer under the ball stud on top of the damper plate for the top of the shock (to smooth the reaction from the shock out a little).
darnold is offline   Reply With Quote
Old 02-13-2002, 06:56 PM   #527
thanx darnold I am sure that your setup will all make sense when I have the car in front of me. That pretty much flew over my head. I am just going to cut and paste a few of your posts so that I can have them in a hard copy format!!!!!!!!!! I also looked back through the posts and found your gearing help so that is on my CLIPBOARD as well. Thanx for all the great tech help on this. Just two points of clarification, the damper tube in the rear is the shock right? And you said red damper stuff in the pivot balls on the front does that mean just a little in the cup so that it lubes the pivot ball? Hope you understand my questions. thanx again,
IKE
FoamDonuts is offline   Reply With Quote
Old 02-13-2002, 06:58 PM   #528
darnold's Avatar
Final stuff- I mount the servo on the chassis (Jr 3550z) and the balls stick out behind the servo towards the back so I have to use the top holes. To get rid of a lot of the bump steer I had to put .060" of spacers underneath the ball studs in the steering blocks. This doesn't allow for enough room to put the little lock nut on the stud but the steering blk material seems really healthy. Anyway I would check it a couple times each race day just in case. BTW keep a careful eye on the screws and the lock nuts for the ball studs because they may work themselves loose initially but after tightening them several times they seem to stay, but I still check them before every run. DO NOT USE Threadlock in the alluminum pieces (rear blocks) but follow the directions advise and use some of the grease they give you to ease the thread in process. I do use the Quantum with the small cap and I have not seen others go up in smoke even in Foam TC Mod although I have read on this site of it happening. I don't use the heatsink either although every TC car of the Big Boys that I have seen had it on theirs. I mount my transponder holder to the chassis opposit the speedo and the rx is right behind the servo with a rx pack on the left side of the servo to balance things out. An rx pack gives about 15sec extra runtime and more importantly keeps the voltage up in the main batteries beter. Also cut down the rollover antena some to help the car corner a little better. Let me know how it goes and any other questions you may have. BTW a Ti double what? I gear my 10's at 25/100 , my 9's at 24/100 and my newly aquired 8 at 21/100 (1.85" rears, go down a tooth for every .05" taller in the rear tire and vice versa)-Dave A.
Old 02-13-2002, 07:02 PM   #529
Dave, do you have the ability to take a few pics of your car? I would really love to see it from a few different angles so I can get the gist of your layout. THanx again.
IKE
Old 02-13-2002, 07:28 PM   #530
darnold's Avatar
Foams- sorry about the technicality of the posts I understand because I am just starting to understand some of this stuff since I have been back racing for the past 3yrs after being out for almost a decade. It's just that many people don't realize that the settings are only 1/2 the picture and that you need the build out of the car as well. You see with the Trinity front end by raising and lowering the height of the ball studs that the front suspesion linkage mounts to you raise and lower the roll center and the same is true even more so I think with the spacing of the steering block between the top and bottom arms on the kingpin. With rc cars in general and especially 1/12th scale because the cg is down at the ground (F1 is like this) then the lower the roll center the quicker the car will react and the more grip into the corner the car will have. Too much of this and the car will traction roll on high bite surfaces and be really "twitchy" (although twitchy is a relative term). To high and the car doesn't want to steer or react to your inputs. I also dope the entire front tires for more consistency so that I am not relying on the tracks traction in every turn and part as much. So that's why you have the sizes of the washers and where I have put them. They make a noticeable difference in how the car handles and how much corner speed it has. I am still experimenting some to see if I can find a little faster setup but I like this one the best so far. My radio steering setup is: 85% Dual Rate with 55% individual end points and NO exponential.
Old 02-13-2002, 07:53 PM   #531
darnold's Avatar
oh- I almost forgot that you need to take a dremel and round off the front top suspension arm like the instructions tell you to do or the front tires hit the top suspesion are and lock up which kills corner speed and makes the car act a little funny. If you need a larger picture of the car check out the thread below and click on "news" and they have an 02 Trinity that you can click on and see a big picture. BTW the damper tubes I am referring to are the plastic side tubes that mount on the cross brace and go across the car just in front of the rear pod, not the center shock. Trinity Red stuff is a type of medium thick grease that they sell and it seems to hold up for a while. Lube the inside of the pivot balls and damper tubes well. Here's the site address: www.twelfth.circuit.btinternet.co.uk
Old 02-13-2002, 08:48 PM   #532
dave,
I think I follow you now on the red stuff, you just coat the pivot balls and the tubes you arent actually filling anything up with the red stuff. I was under the impression that you were filling the tubes like you would with a shock. THanx again,
IKE
Old 02-13-2002, 09:02 PM   #533
Rick Vessell's Avatar
Dave,
.022 springs it is. If I dope too much tire the car gets twitchy. I normally dope between 1/2 and 3/4. 3/4 is too much and 1/2 is for only when the bite is really up. I have a 9 turn Ti that I plan on running. I ran the Furys in my TC and really liked them plus, I know Sean so I can always get motor help if I'm really stumped. Won't be up to Indy before the race unfortunately. I'm moving my wife and all our stuff the weekend before and I don't officially relocate until the middle of March. Yeah, that's right, I move her home, come back to Dallas, get ready, and then come right back up there the next weekend! Whew! I must be crazy!
Is Jucha coming too? What about James Arnold?
Rick Vessell is offline   Reply With Quote
Old 02-13-2002, 09:06 PM   #534
darnold's Avatar
Foams I don't have a digi camera but my buddy Robk does and maybe this weekend I can take a couple sets of pics and post them. I may also be able to draw some of the points out in ms draw and post those.-Dave
Old 02-13-2002, 09:14 PM   #535
darnold's Avatar
Sako- Sounds like a LOT of work. James is planning on being there along with Jucha. I am planning on getting a 9 turn soon. My 10's have been faster lately due to the r&d with integy. I just got a hold of an 8turn and it rocks! I think this Sunday Rob King and I are going up to Grand Rapids to race. Jeff Brown is suppose to race and if Walt Henderson runs his 12th mod then the 3 of us get to race our own heat! Rob I think will be running TC up there. Yeah, I need a fast 9turn and Integy is supposed to be sending me some arms to test but that was a couple of weeks ago and still no 9 turn arms. Have you tried a P94 yet?
Old 02-13-2002, 09:24 PM   #536
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
Socko...all i have is an 11 double D4.......Lightspeed.Talked to Pileup..hes wanting to try it also....should be interesting getting gearing correct so we dont dump
I want to throw my set up out here..just to see what ya'll think.....RC12LW...yes..LW.....Purple fr./Pink rr..........020 fr. spring......no lube on king pin.....one white spacer each side upper arm /new style front end....1/8 ride height fr. and rr.(prolly tooo low,my car is black on chassis and sticky)kit shock(delta) 30 oil...kit spring.....063 t-bar........3 drops green slime on upper disc.......paragon fx2 on front and rear...full width on both.....car is dialed......i've read different set ups and mine seems soft...but i can put the car anywhere...very neutral....P-35 body
Dragon Slayer is offline   Reply With Quote
Old 02-13-2002, 09:34 PM   #537
darnold's Avatar
Hey Dragon S- Sounds good if you are racing on asphalt, huh, are you? By the black sticky stuff on you chassis it makes me think however that you may be on carpet, I'm not sure. If you are on carpet than you setup is easy to drive but very slow in the corners compared to what it could be (but you may still be faster than everyone else there). Unless the carpet is really bad or very few people run there so that the grip is down (you can't see any black groove in the corners) then you should use gray rears at least. The .020's sound good and you are running 2deg caster if I'm not mistaken and with the 10deg block (angled down blks) you go down to 0deg caster in the corners. The roll center on that front end is already high so nothing to do there. Try going to 4deg caster and rase your ride height to .120" (just over 3mm). Also, how much front tire are you doping and for how long do you let your dope sit on the tires?
Old 02-13-2002, 09:56 PM   #538
darnold's Avatar
dragon s- my bad, I just noticed the full width of the fronts. If you also put a thick t-bar on it along with the other stuff I just posted and check your lap times you should notice lower times. BTW .120" = 1/4" and from the sounds of it your car is way low, below legal since 3mm (1/4") is legal. Your car should also be costing you runtime in comparison to what you could have. Just raise it up some all around, put the grays on, try a little more caster to keep it calm and help it respond to your inputs (initiate) especially in high speed corners (sweepers, carosels,etc.), put the thick T-bar on to help it turn still and put some green stuff on the kingpins to make the front even smoother than you already have it. Here's a little story that happened last week. Another race just bought the 02Trinity and he came out with a 19t and we practiced together. He built it toatally stock and did a good job, plus the car is awesome anyway right out of the box. The only differences where my Assoc .020 front springs which = .022 in Trinity and my thick T-bar to the stock thin one in the kit (.064"). He tried to follow me into the corners but couldn't understand why there was this drastic differnce in our corner speed even with his batteries moved forward. Gues what it was? Yep, the thin t-bar. I drove his car and it FELT Great and if you didn't know better (or in his case see better) you would never have known how much corner speed was missing. It can be very hard to detect .1sec here or there but if you get a couple or few of those consistent per lap it = 1,2,3 laps and the lines can be the exact same! Hope this helps bro.-dave
Old 02-14-2002, 03:05 AM   #539
Trips's Avatar
Trader Rating: 16 (100%+)
Hmm... someone's math is a bit off...
1/8" = .125"
1/4" = .250"
3mm = .118"
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 02-14-2002, 11:49 AM   #540
darnold's Avatar
Trips- You're right, thanks. Actually I thought it didn't look right when I posted. I didn't convert it mathematically, I had a ruler right next to me and since I had my callipers out doing some other stuff I just compared the calli's to the ruler. Must have mis-read the markings on the ruler. Next time I think good ole' fashioned math is in order.
Dragon S- That shows even more that your car is too soft so keep the 1/8" ride height (axle cams and washers as they are) but do all of the other stuff and compare your lap times. If the car steers too much then lessen the amount of dope on the fronts to about 1/2 and try it then.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
