    Hide Wikipost
Old 09-19-2017, 11:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: 1/12 forum
Last edit by: DesertRat
This is a place to share knowledge related to 1/12th scale racing. It is not to be used for conversations.
KITS:
Click links to go to manufacturer product page. If any are missing please add them!
TIRES:
Pre-mounted tires readily available in the US:
Pre-mounted tires readily available in the Europe:
  • Hot Race ??
Gluing your own donuts:
https://www.youtube.com/watch?v=hm7z1rz-74s - Special thanks to Edward Pickering!
Truing tires:
https://www.youtube.com/watch?v=8wqHOLWq6Uc - Special thanks to Edward Pickering!
The following information came from HERE, with some editing and information added. Thanks Christian!
THIS MAY NEED UPDATING FOR THE NEW BLACK CRC CARPET
Brands:
BSR, CRC, Jaco:
Pro One is no longer selling to the public, but it and the brands above are all mounted by BSR and use the same foam. The nomenclature of the BSR vs Jaco/CRC is a little different in a few instances but is otherwise the same. The BSR foam consists of three families, and can be identifed as synthetics, naturals, and blends.
Synthetics - The old school, light weight, easy to true "dry feeling" tires. These include tires like CRC/Jaco Yellow (BSR White), Black, Gray, etc. These tires offer the highest wear rate and lowest grip. Many racers continue to use these nder high bite conditions.
Naturals - These tires are usually the best alternative for low bite and asphalt. They include Pink, Magenta, Double Pink, Lilac (BSR Team Purple), Purple, and other tires. These tires provide a ton of grip, but tend to get sticky in high bite conditions. This rubber does not wear as easily, and the cars will pick up gunk and fibers from the carpet under most high bite conditions. This is especially bad if the humidity is high.
Blends - These are the tires most people run today. They were initially called "JFT foam" by some, as it was believed that the tires were the same as the JFT tires. We can divide the blends further into two groups: high rubber and low rubber content. The high rubber would be the new rear Orange and Red from the BSR family, and the low rubber would be the Green and Blue varieties. When, asked about the difference, John Foister from BSR Tires said they came from the same "family" of foam, but they offered different grip. According to John, the Green/Blue has more bite than Orange/Red, but from track testing Oranges offer more bite than Green (being equivalent to in hardness) when the grip is high and absolutely no grip when it is lower. The Orange foam has a denser pore structure and the tire is not as prone to chunking. It is also important to note is that BSR Blue rears are not the same as the BSR Blue fronts!
JFT:
JFT stands for Japan Foam Tire. They started the new wave of foam tires we are all using now (Blue/Blu, Green/Greene, Dbl Blue, etc). These tires are a little different than the BSR tire family, but work in very similar conditions. They offers four varieties A (asphalt), C (carpet), S (???), and R (???). This does not mean that those types only work on that surface, but this is what they recommend.
JFT uses the same foam for fronts and rears if the color is the same.
A: Used on asphalt, considered close to the natural rubber variety and are named consistently with other natural tires.
C: Used on carpet, considered a blend.
S: Used on carpet?, tires are ???
R: Used on carpet?, tires are ???
For setup, the JFT foam seem to generate more bite than the BSR, therefore the car tends to be a little more aggressive.
Ulti:
Ulti is another Japanese brand that offers an array of compounds. They have their own way of rating tires, and are difficult to equate to other brands. They have 4 different varieties, each in varying degrees of hardness.
J: High rubber content tire, similar to Pink/ Magenta. Soft would be close to a pink. These offer the most bite and are great for asphalt/carpet front tire. (J hard being very popular)
X: "Balanced" blend, similar to JFT Blue/ Green. Soft is equivalent to Green, medium to Blue in hardness. Great for carpet!
Y: High synthetic blend with lower grip, and is not a very popular variety.
Z: A very expensive "special" foam that is supposed to be magic on asphalt. Only make it in soft shore.
European tires:
There are many great European foam tire brands that use their own types of foam, as well as traditional foams. SOmeone with more knowledge about them will need to fill this in!
Tire Diameter:
If you are racing on carpet, you have to evaluate how much grip your track has. If your track is low to medium grip, you can run bigger tires. If you are on higher bite you have to cut them smaller, there is simply no way around it. Bigger tires are needed for asphalt, especially in the rear. The larger tires provide much needed lateral bite.
Carpet (mm):
Low - Medium Bite
Front: 42.0 - 42.5
Rear: 42.5 - 43.00
Medium - High Bite
Front: 40.5 - 41.0
Rear: 41.5 - 42.0
Big Race
Front: 39.5 - 40.0
Rear: 40.5 - 41.0
Asphalt (mm):
Parking Lot
Front: 43.0 - 44.0
Rear: 44.0 - 45.0
Prepped High Bite
Front: 42.0 - 43.0
Rear: 43.0 - 44.0
Tire Saucing:
Most facilities have moved towards odorless traction additives such as SXT. Some of additives evaporate very quickly and some do not. This seems to be something that is also dependent on tire compound and ambient temperature. For example, saucing a Green compound seems like it never dries, especially when tjhe temperature is lower. We have found that wiping the tires off 15 minutes before we go run allows the sauce to cure, which makes the car come in much quicker with Green rears. Blue compounds on the other hand, do fine when wiped off right before hitting the track.
Saucing half front and full rear is a good initial starting point. If the front of the car is too agressive you can sauce les than half, or for a shorter amount of time.
Tire Fuzzing:
In conditions of increasing grip, foam tires will somewtimes get sticky and pick up fuzz and debris from the track. This is highly dependent on the rubber sedan tire that is being run at your local track and the compound/ type of foam you are running on you car. The softer the sedan tire and the harder/higher rubber content in your foam tire, trouble with fuzzing seems more likely to occur.
There are ways to get around fuzzing under most conditions, and usually involves the selection of the correct foam compound. The more fuzz you get, the softer/lower rubber content you want to run.
Examples:
Problem: Car fuzzes with Lilac/Team Purple fronts and car starts pushing.
Solution: Use a softer front tire and or different family of foam. Replace it with Blue or Double Blue front.
Problem: Car loses rear bite 6 minutes into the run. Blue rear tires look almost clean but have small carpet hairs.
Solution: Use Green rear tires. The softer compound wears instead of getting sticky, minimizing fuzz.
Tire Selection:
Starting out, pick 2 tire compounds for the front and rear. The following should have you covered 99% of the time.
Rear - Green and Blue (BSR) or Green and Light Blue (JFT)
Front - Blue and Double Blue (BSR) or Blue and Dark Blue (JFT)
You may wonder about other compounds out there and if they might be better, trust me, they probably won't be. Even if there are other tires that can be as fast, the synthetic family wears out really fast and the high natural rubber will probably fuzz on you over an 8 minute run. The blends family seems to be the most versatile foam type available today. They last awhile, and sticking to them will make your process of tire selection simpler.
Tire Charts:
BSR/CRC/Jaco
Contact
Corally
JFT (Japan Foam Tire)
Ulti
Enneti (Xceed)
ELECTRONICS:
ESC:
As of now, ROAR is staying 1S (3.7V nominal; 4.2V fully charged) for 1/12. There are many 1S ESC's with a built in BEC so nothing else is required to power the receiver and servo.
If you don't want to lock yourself into a 1S specific ESC, you do have other options! It is possible to use your 2S ESC without a booster or receiver pack, and the ESC simply supplies the lower voltage. If that does not appeal to you, you will need to use an Rx pack or booster. The Rx pack and booster will both supply the receiver with a higher voltage than the 1S pack.
If you decide to use an Rx pack, MAKE SURE TO REMOVE THE RED WIRE FROM THE ESC PLUG THAT GOES INTO THE RECEIVER!!!
If you choose to use a voltage booster, it works exactly how it sounds. Instead of plugging the ESC into the receiver, it plugs into the booster, and the booster plug goes to the ESC, supplying the higher voltage.
1S ESC:
If there are any missing please add them!!
If anyone would like a need for a chart comparing the ESC's specs PM fenton06 and I'll get one made and put in here!
DISCONTINUED 1S ESC:
Voltage Boosters:
Servos:
BODIES:
Black Art (CRC - US Dist):
  • Audi R8C - BA002 - .020 Thick
  • Black Market (Mohawk 12) - BA005 - .020
  • Lola B10 - BA006 - .020 thick
  • Toyota TS030 - BA008 - .020 thick
    Lola - black/red, TS030 - green/pink
PROTOForm:
Reflex Racing/RSD:
SUSPENSION ADJUSTMENTS:
Print Wikipost
Like Tree62Likes
Old 01-14-2010, 02:07 AM   #33226
RC MARKET's Avatar
SMC New 5300mAh 50C+ 3.7V LiPo
1/12 forum-smc-5350si-1.jpg
RC MARKET is offline   Reply With Quote
Old 01-14-2010, 02:42 AM   #33227
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
U HAVE IT IN STOCK??? THEY ARE OUT ALREADY??
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 01-14-2010, 02:50 AM   #33228
georgec's Avatar
Originally Posted by AreCee View Post
What type of track do you use those on? Running blacks on our carpet track is like putting on ice skates without knowing how to skate. CRC Low Greys in the rear seem to be the best compromise for durability and traction with CRC purples up front. Need a little more steering on a cold day and lilacs work well.
RC4Less also makes natural rubber tyres
georgec is offline   Reply With Quote
Old 01-14-2010, 03:07 AM   #33229
ds400's Avatar
Default Booster or Receiver pack
Hey guys, I am going lipos in my 12th scale soon and will need to get my receiver and servo working properly.
Do you recomend a booster or a receiver pack?
Whats the best brand and most reliable? Can I get if from Hk?
Cheers
ds400 is offline   Reply With Quote
Old 01-14-2010, 03:32 AM   #33230
i saw those, im assuming there better than the exotic tires? going to order 3 or 4 sets tomorrow,just dont know the difference between the two...but seems like people are vouchin for them pretty hard.. i like that!!!!
Old 01-14-2010, 06:33 AM   #33231
I'm looking at getting into 1/12 onroad after racing oval pancars for the last 5 years. Trying to figure out what I need to get, right now it's between the Associated 12R5.1 and the CRC Gen XL. I'm going to start out in the 17.5 Single Cell class, so any advice on gearing, tires, cars, and bodies would be appreciated.
Thanks in advance Michael
Ballistic2 is offline   Reply With Quote
Old 01-14-2010, 07:26 AM   #33232
RC MARKET's Avatar
Instock now !
http://rcmarket.com.hk/product_info....oducts_id=7887
Old 01-14-2010, 08:02 AM   #33233
THAT BATTERY CALLS FOR CHARGING IN A 2CELL MODE AT 10.6 AMPS? is that safe? and would that icharger u sell there be able to do that. i currentlly use the cheap ice charger, as im new to lipo, time to step it up now...
Old 01-14-2010, 08:05 AM   #33234
2C stands for 2 times the capacity, in other words 10.6 Amps. (On a 1 cell (1s) charging program ofcourse)
Ahmed Aman is offline   Reply With Quote
Old 01-14-2010, 09:10 AM   #33235
Default Spur/pinion
I'll be running LRP SXX
AE 12R5.1 TC5 B4 B44 RC8B RC8BE
TEKIN OS LRP EPIC NOVAK
SPEKTRUM
FUTABA
PROLINE
Tomasb is offline   Reply With Quote
Old 01-14-2010, 09:15 AM   #33236
Default Spur/Pinion
Originally Posted by PDX-Spike View Post
Depends on which ESC you have! When I downloaded the new Tekin RS software, I dropped 8 teeth on my pinion, after increasing my spur by 12 teeth! (was 72/44, now 84/36)! That's on a 100 x 60 track.
I'll be running LRP SXX.
SPEKTRUM
FUTABA
PROLINE
Old 01-14-2010, 10:04 AM   #33237
oeoeo327's Avatar
Trader Rating: 70 (100%+)
The Ice charger won't have a problem with the 5300 battery - the 2C rating means that it can be charged safely at charging rates up to 10.6 amps. However, you must set the charging profile for 3.7 volts, not 7.4; otherwise, your new battery will never see the track.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 01-14-2010, 10:05 AM   #33238
Originally Posted by pakk View Post
Has anyone had any problems running a 2cell lipo pack(8.4v) to futaba servos?
No problem here with 9602s, but a friend couldn't stop his glitching! If you haven't bought the receiver pack yet, and you have a LiFe compatible charger, then get a LiFe receiver pack, as they are 6.6v, and less likely to cause problems.
If you already have the pack, then consider a regulator if you have any problems. There doesn't seem to be any rhyme or reason why some people have no problems, and others do. HTH
SlowerOne is offline   Reply With Quote
Old 01-14-2010, 10:27 AM   #33239
OK,SO WITH THE ICE I CAN SET IT AT 2C and get the 10.6...but again setting at 3.7 volts...what does this do charges faster? better performance as well?
Old 01-14-2010, 10:33 AM   #33240
Regional Moderator
CarbonJoe's Avatar
Yes, it charges faster, with the downside of reducing the lifespan versus charging at 1C (5.3A). 3.7volts is the voltage of the 1s pack. The ICE won't allow you to charge at 2C if you have the voltage set correctly (1s LiPo).
Don't try to trick the ICE just to charge a little bit faster, or you'll smoke your 1s pack.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 6 (2 members and 4 guests)
Pinkz, pmes
