    Hide Wikipost
Old 09-21-2017, 01:26 PM   -   Wikipost
R/C Tech Forums Thread Wiki: 1/12 forum
Last edit by: DesertRat
This is a place to share knowledge related to 1/12th scale racing. It is not to be used for conversations.
KITS:
Click links to go to manufacturer product page. If any are missing please add them!
TIRES:
Pre-mounted tires readily available in the US:
Pre-mounted tires readily available in the Europe:
  • Hot Race ??
Gluing your own donuts:
https://www.youtube.com/watch?v=hm7z1rz-74s - Special thanks to Edward Pickering!
Truing tires:
https://www.youtube.com/watch?v=8wqHOLWq6Uc - Special thanks to Edward Pickering!
The following information came from HERE, with some editing and information added. Thanks Christian!
THIS MAY NEED UPDATING FOR THE NEW BLACK CRC CARPET
Brands:
BSR, CRC, Jaco:
Pro One is no longer selling to the public, but it and the brands above are all mounted by BSR and use the same foam. The nomenclature of the BSR vs Jaco/CRC is a little different in a few instances but is otherwise the same. The BSR foam consists of three families, and can be identifed as synthetics, naturals, and blends.
Synthetics - The old school, light weight, easy to true "dry feeling" tires. These include tires like CRC/Jaco Yellow (BSR White), Black, Gray, etc. These tires offer the highest wear rate and lowest grip. Many racers continue to use these nder high bite conditions.
Naturals - These tires are usually the best alternative for low bite and asphalt. They include Pink, Magenta, Double Pink, Lilac (BSR Team Purple), Purple, and other tires. These tires provide a ton of grip, but tend to get sticky in high bite conditions. This rubber does not wear as easily, and the cars will pick up gunk and fibers from the carpet under most high bite conditions. This is especially bad if the humidity is high.
Blends - These are the tires most people run today. They were initially called "JFT foam" by some, as it was believed that the tires were the same as the JFT tires. We can divide the blends further into two groups: high rubber and low rubber content. The high rubber would be the new rear Orange and Red from the BSR family, and the low rubber would be the Green and Blue varieties. When, asked about the difference, John Foister from BSR Tires said they came from the same "family" of foam, but they offered different grip. According to John, the Green/Blue has more bite than Orange/Red, but from track testing Oranges offer more bite than Green (being equivalent to in hardness) when the grip is high and absolutely no grip when it is lower. The Orange foam has a denser pore structure and the tire is not as prone to chunking. It is also important to note is that BSR Blue rears are not the same as the BSR Blue fronts!
JFT:
JFT stands for Japan Foam Tire. They started the new wave of foam tires we are all using now (Blue/Blu, Green/Greene, Dbl Blue, etc). These tires are a little different than the BSR tire family, but work in very similar conditions. They offers four varieties A (asphalt), C (carpet), S (???), and R (???). This does not mean that those types only work on that surface, but this is what they recommend.
JFT uses the same foam for fronts and rears if the color is the same.
A: Used on asphalt, considered close to the natural rubber variety and are named consistently with other natural tires.
C: Used on carpet, considered a blend.
S: Used on carpet?, tires are ???
R: Used on carpet?, tires are ???
For setup, the JFT foam seem to generate more bite than the BSR, therefore the car tends to be a little more aggressive.
Ulti:
Ulti is another Japanese brand that offers an array of compounds. They have their own way of rating tires, and are difficult to equate to other brands. They have 4 different varieties, each in varying degrees of hardness.
J: High rubber content tire, similar to Pink/ Magenta. Soft would be close to a pink. These offer the most bite and are great for asphalt/carpet front tire. (J hard being very popular)
X: "Balanced" blend, similar to JFT Blue/ Green. Soft is equivalent to Green, medium to Blue in hardness. Great for carpet!
Y: High synthetic blend with lower grip, and is not a very popular variety.
Z: A very expensive "special" foam that is supposed to be magic on asphalt. Only make it in soft shore.
European tires:
There are many great European foam tire brands that use their own types of foam, as well as traditional foams. SOmeone with more knowledge about them will need to fill this in!
Tire Diameter:
If you are racing on carpet, you have to evaluate how much grip your track has. If your track is low to medium grip, you can run bigger tires. If you are on higher bite you have to cut them smaller, there is simply no way around it. Bigger tires are needed for asphalt, especially in the rear. The larger tires provide much needed lateral bite.
Carpet (mm):
Low - Medium Bite
Front: 42.0 - 42.5
Rear: 42.5 - 43.00
Medium - High Bite
Front: 40.5 - 41.0
Rear: 41.5 - 42.0
Big Race
Front: 39.5 - 40.0
Rear: 40.5 - 41.0
Asphalt (mm):
Parking Lot
Front: 43.0 - 44.0
Rear: 44.0 - 45.0
Prepped High Bite
Front: 42.0 - 43.0
Rear: 43.0 - 44.0
Tire Saucing:
Most facilities have moved towards odorless traction additives such as SXT. Some of additives evaporate very quickly and some do not. This seems to be something that is also dependent on tire compound and ambient temperature. For example, saucing a Green compound seems like it never dries, especially when tjhe temperature is lower. We have found that wiping the tires off 15 minutes before we go run allows the sauce to cure, which makes the car come in much quicker with Green rears. Blue compounds on the other hand, do fine when wiped off right before hitting the track.
Saucing half front and full rear is a good initial starting point. If the front of the car is too agressive you can sauce les than half, or for a shorter amount of time. On black carpet the car may be numb to sauce changes, either a long or short sauce can produce very similar handling.
Tire Fuzzing:
In conditions of increasing grip, foam tires will somewtimes get sticky and pick up fuzz and debris from the track. This is highly dependent on the rubber sedan tire that is being run at your local track and the compound/ type of foam you are running on you car. The softer the sedan tire and the harder/higher rubber content in your foam tire, trouble with fuzzing seems more likely to occur.
There are ways to get around fuzzing under most conditions, and usually involves the selection of the correct foam compound. The more fuzz you get, the softer/lower rubber content you want to run.
Examples:
Problem: Car fuzzes with Lilac/Team Purple fronts and car starts pushing.
Solution: Use a softer front tire and or different family of foam. Replace it with Blue or Double Blue front. Alternatively you can sauce the front tires harder and tune the car for less front end bite.
Problem: Car loses rear bite 6 minutes into the run. Blue rear tires look almost clean but have small carpet hairs.
Solution: Use Green rear tires. The softer compound wears instead of getting sticky, minimizing fuzz. Possibly a longer sauce will prevent fuzzing.
Tire Selection:
Starting out, pick 2 tire compounds for the front and rear. The following should have you covered 99% of the time.
Rear - Green and Blue (BSR) or Green and Light Blue (JFT)
Front - Blue and Double Blue (BSR) or Blue and Dark Blue (JFT)
You may wonder about other compounds out there and if they might be better, trust me, they probably won't be. Even if there are other tires that can be as fast, the synthetic family wears out really fast and the high natural rubber will probably fuzz on you over an 8 minute run. The blends family seems to be the most versatile foam type available today. They last awhile, and sticking to them will make your process of tire selection simpler.
Tire Charts:
BSR/CRC/Jaco
Contact
Corally
JFT (Japan Foam Tire)
Ulti
Enneti (Xceed)
ELECTRONICS:
ESC:
As of now, ROAR is staying 1S (3.7V nominal; 4.2V fully charged) for 1/12. There are many 1S ESC's with a built in BEC so nothing else is required to power the receiver and servo.
If you don't want to lock yourself into a 1S specific ESC, you do have other options! It is possible to use your 2S ESC without a booster or receiver pack, and the ESC simply supplies the lower voltage. If that does not appeal to you, you will need to use an Rx pack or booster. The Rx pack and booster will both supply the receiver with a higher voltage than the 1S pack.
If you decide to use an Rx pack, MAKE SURE TO REMOVE THE RED WIRE FROM THE ESC PLUG THAT GOES INTO THE RECEIVER!!!
If you choose to use a voltage booster, it works exactly how it sounds. Instead of plugging the ESC into the receiver, it plugs into the booster, and the booster plug goes to the ESC, supplying the higher voltage.
1S ESC:
If there are any missing please add them!!
If anyone would like a need for a chart comparing the ESC's specs PM fenton06 and I'll get one made and put in here!
DISCONTINUED 1S ESC:
Voltage Boosters:
Servos:
BODIES:
Black Art (CRC - US Dist):
  • Audi R8C - BA002 - .020 Thick
  • Black Market (Mohawk 12) - BA005 - .020
  • Lola B10 - BA006 - .020 thick
  • Toyota TS030 - BA008 - .020 thick
    Lola - black/red, TS030 - green/pink
PROTOForm:
Reflex Racing/RSD:
SUSPENSION ADJUSTMENTS:
Pan Car Front Suspension Tuning:
DISCLAIMER : The following tuning advice was written based on the tuning experience of the author and may not hold true for all cars, drivers, or surfaces. In the end the best tuning advice is to experiment and make changes one at a time so you can track your changes and find the car balance that works best for your driving style. One real world test is worth a million ‘expert’ opinions.
Front End Type:
All popular modern pan car front suspensions are very similar, with a few exceptions such as Speedmerchant New School but most of the info in this wiki applies to them as well. For the most part, they consist of a rigid bottom arm, an upper A-arm, and a kingpin with a spring. There are different flavors of this general design, such as the CRC Dynamic Strut that uses a threaded kingpin and upper pivot ball instead of the Associated style that uses a kingpin that goes through the entire steering knuckle assembly, but their operation is the same with the rigid lower arm and the upper arm controlling the arc of movement as the suspension is compressed.
Assembly:
More so than in almost any other part of the car, the front suspension of your 1/12 car must move absolutely free. Reamers and hobby knives are important here, as any binding will cause the car to corner unpredictably. A little play in the suspension is a good thing, and racers will often find that ‘worn in’ suspension pieces function a little better than new.
Springs:
Besides tires, spring rate is the most important part of deciding how your car will handle through corners, but are somewhat complicated. As a general rule of thumb, a very hard front spring will have somewhat less steering grip than a softer spring with the same suspension setup and tires, but not as much as in other classes such as touring or offroad. On carpet, springs of different tension can be used to tune how your car will maintain or lose energy through corners with the following general rule of thumb:
Hard Spring (0.55mm or harder): Less overall steering, quick reaction to driver input, less on power steering, harder turn-in with potentially lazy mid-corner and exit.
Soft Spring (.45mm): More overall steering especially at low speed, slightly slower reaction to driver input, more on-power steering, less aggressive turn-in but can ‘hook’ and give better mid-corner and exit.
It is worth noting that front springs from different suppliers are often very different, in both height, wire thickness, and coils for a given spring height meaning that a “medium” spring from one manufacturer may be the “hard” spring for another. To make accurate changes you may want to use one spring maker and stick with their line.
Another aspect to pan car springs is that they can get “blown out” and collapse, no longer as stiff or as tall as they were. These should be replaced with fresh springs to ensure consistent handling.
Dampening:
This is generally a minor adjustment, but adding dampening tube fluid to the front kingpins of a 1/12 car can give it a little more initial steering. Often unusual compounds see use here, such as Losi Smart Diff Grease or Associated Green Slime being a popular front kingpin lube.
Caster and Reactive Caster:
Caster is the angle of the kingpin, almost always angling back to the rear of the car, with a typical range from 0-10 degrees. Increasing your caster will typically result in less turn-in but a little more control, more steering exiting the corner, and somewhat increased straight-line stability with less tendency to wander because a wheel running caster will tend to straighten itself. Less caster will usually give you more off-power steering, but often with correspondingly less on-power when accelerating out of the corner.
Running reactive caster attempts to use both of these aspects to increase overall steering: when the car loads up on the outside front tire, the caster angle decreases, increasing the front end ‘hook’ as you enter the corner and then giving you the high caster on-power steering as you exit and weight is transferred off the front end. More reactive caster means more overall steering, but can mean you may have to adjust your driving style to drive more ‘ahead of the car’, needing to predict where the front end will grip.
As grip increases, less reactive caster is the normal tuning change made to keep the front end of the car from gripping too hard and oversteering and prevent traction roll. Static caster adjustments are still used to change the cars on power / off power steering balance.
Reactive Camber and Front Roll Center:
Reactive camber or camber gain is how much camber is added the front wheels as the suspension compresses. This can be increased or decreased by changing the angle and length of the top arm. Short, angled arm = more. Long, flat arm = less. More reactive camber will typically cause the car to “roll up” on the outer front wheel, transferring more weight in a turn and give more steering up to the point at which the tire is overloaded. This is generally more front grip and weight transfer than wanted on carpet, and as a result most cars run a flatter longer front arm.
Roll Center is the point on which the car will twist laterally or ‘roll’ during cornering. This can be raised or lowered by changing the angle and length of the top arm, with a short angled arm raising is slightly and a long flat arm lowering it. From what I have calculated most modern 1/12 cars meant for carpet have a roll center somewhere around the height of the chassis plate or just below it, but due to the lower arms being rigid and flat the roll center cannot be under the bottom of the tires like it often is on a touring car.
These two are inexorably linked in pan cars. Top arm length can be changed by the top arm mount in or out using shims or a CRC Long Arm kit, but is generally a minor tuning choice. Tuning of roll center with shims is usually a minor tuning choice in a pan car with a rigid bottom arm due to how the car cannot gain extra mechanical advantage on the lower arm as you can in a touring car, while reactive camber can be a significant driver of the car’s performance. In a modern car running on carpet the kit setup is usually perfectly fine.
Front End Alignment:
Static camber is the angle of your front wheels at rest, typically somewhere from 0 to 1.5 degrees on a pan car depending on surface, tire choice, and other factors, but a good starting point is usually somewhere around 0.5 degrees. More camber will typically give more steering, but many racers use static camber to ensure that their tires wear flat even if that means not having exactly equal camber on both sides of the car. This is adjusted by threading in and out the upper turnbuckle or pivot ball.
It is also worth noting that when running on high grip the flex and deformation of your chassis, suspension parts, and front wheels can become significant and cause uneven front tire wear. Some troubleshooting of the right combination of static camber, camber gain, caster, and tire/rim choice may be necessary to ensure even front tire wear.
Toe-In:
The front toe is one of the more easily adjusted aspects of the car and can have a significant effect on the attitude of the car due to it being a quick way to moderately adjust Ackerman without making significant other changes. With nothing else being adjusted, going from zero toe to toe-in will give a car a harder turn-in and will tend to scrub speed with the front end as opposed to using drag brake. This can be necessary when racing in Super Stock or higher power classes and will allow you to drive more aggressively, and can help the car track straighter under power. Toe-out will tend to make the car coast more through corners due to reducing the steering angle of the outer front tire. If a car has too much off-power steering but is otherwise stable, adding toe-out can calm the car but may the car to wander on the straights especially if the front end setup is very soft.
Ackerman:
Ackerman is the difference in steering angle between the two front tires during a turn. It is the result of how during a turn the inside of the car experiences a tighter circle and needs correspondingly more steering angle, but is also an important tuning tool. More Ackerman means having more inside wheel steering angle relative to the outer wheel, less means that the difference in steering angle is smaller.
To add or remove Ackerman, using a servo horn that spaces the links further apart (such as a Kimbrough Small Servo Saver, the outer holes on a Tamiya or Xray servo saver) will have more Ackerman than a servo that puts the links close together (Kimbrough Medium inner holes, Tamiya or Xray inner holes.) The rule of thumb is that a servo that puts the ball studs close together but spaced away from the servo horn will have less Ackerman than one that spaces them far apart and close to the servo horn. Ackerman changes will have the same effect as changing toe with more Ackerman being effectively toeing the wheels out and less toeing them in, but will not affect the straight-line attitude of the car.
Turning Circle / Steering Angle:
In offroad or even touring car you can set up the car to use the full angle of the steering 100% of the time. You will almost certainly not be able to do this in 1/12 scale. It goes without saying that as you turn up your steering angle you will gain steering often to the point of the car being undriveable. The quickest way to set the steering correctly is to set the sub-trim in your radio such that the car tracks straight and the servo horn is straight up and down, then set the endpoints equally such that they don't quite hit the steering bump-stops, then turn down the dual-rate or total throw from there. A typical starting point is somewhere between 45 and 60% of the total steering throw, or a 4-5' turning circle.
Pan Car Rear Pod Tuning:
Modern pan cars are all link cars with a center pivot ball and solid rear axle. This suspension system is required by ROAR rules and has the advantage of being simple, lightweight, and inexpensive compared to other more exotic methods of rear suspension, but it has some complicated movements that can be unintuitive.
Motion of the Rear Pod:
Due to how the rear pod is a solid axle, the only motion the pod itself sees is the main pivot up and down, but due to the main chassis being independently sprung it will feel the lean, dive, and squat of the main chassis as the car is driven. The lateral forces of the main chassis during cornering is transmitted through the main pivot ball and side links, the roll through the side springs and side dampeners, and the squat and dive through the main shock and spring. In addition, the torque of the motor against the pinion gear both during acceleration and braking is significant enough to cause a change in attitude even in low-powered classes. The motor pinion will try to “climb” the spur gear, lifting the center pivot of the car and countering the “squat” of the main chassis weight being transferred backward by the acceleration or the opposite under brakes.
Main Shock:
The adjustment of the main shock of a pan car is one of its more important tuning parameters. Spring, dampening oil, and pod droop are all controlled by the main shock.
Main Spring:
A soft main spring generally means more rear grip and more forgiving off-power, while a stiffer spring can mean more steering especially off-power, but the main spring must also be stiff enough to prevent the chassis from dragging when running on high grip. For most cars the kit spring is a medium weight spring that is a good starting point.
Main Shock Dampening:
The weight of the main shock oil will determine how fast the car will react off-power. 30wt or roughly 300cps shock oil is a good starting point, going up in weight will increase initial off-power turn-in, while going down will generally make initial turn-in softer. Often a heavier shock oil can make the car transition from entry to mid to corner exit smoother, where a car with light fluid may have a more pronounced ‘hook’ in the mid corner.
Side Springs:
The side springs transfer the roll motion of the main chassis to the rear plate via spring tension. Softer side springs give the car more rear grip and can make the car have a smoother steering feel. Stiffer springs promote the cars rotation and give more steering. You can either pre-load side springs or let them float, due to all side springs being progressive beehive shaped springs pre-load makes them effectively harder and will give more steering, but a small amount of pre-load can also make the care more predictable and forgiving. In conditions of extremely high grip, it may be possible to run no side springs at all due to the steering afforded by the tacky running surface and helps prevent traction-roll, likewise in extremely low grip when rear stability is absolutely necessary. Generally 1/12 cars run soft side springs but stiffer ones can be very common in Pro 10, WGT, or WGT-R.
Side Dampener Tubes:
Heavier tube lube will keep a car flatter at corner entry, initiating quicker. It may also make the car square off the corner entry when the grip gets beyond med-high. Going lighter will reduce steering initiation and maybe preferred on higher grip. This parameter is really unique to the driver preference, as some drivers are very fast and consistent with heavily dampened cars while others prefer softer setups.
Droop:
Controlled by the length of the shock, adjusting the rear pod droop is extremely important on high-grip surfaces. Reducing droop prevents the car from transferring weight during cornering and will give more rear stability and prevent traction-roll or problematic lifting of the inside rear tires during cornering, low droop can also give the car slightly more on-power steering. Increasing will allow the car to transfer more weight and dive harder into corners, but by allowing the center of the car to rise you will be more prone to traction roll issues. A typical starting point is 1-2mm of droop from ride height, but 0mm is often used on high grip.
Print Wikipost
Like Tree62Likes
Old 08-31-2009, 07:42 AM   #31966
PartTime's Avatar
Originally Posted by Tire Chunker View Post
Question on a Sphere Competition 2007, can you run lipo 3.7v with a receiver pack or booster?
Last season everyone was using GTB and people were having issues with the LRP. I have read that setting to Nimh to turn off lipo cut-off helps but not sure if makes it ok for 1/12th lipo.
Tom
Yes it works, and very well at that. You need a booster or rx pack and leave the speedo switch OFF. With the switch off it disables the radio priority and cut off circut. This way you have power for 8mins. If speedo is left on it will pull power from the motor to make sure it has enough for the radio and make it feel like your dumping.
DK
PartTime is offline   Reply With Quote
Old 08-31-2009, 07:47 AM   #31967
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
Thanks guys.
Tire Chunker is offline   Reply With Quote
Old 08-31-2009, 10:13 AM   #31968
wingman2's Avatar
Hiya, that is indeed one of my SP12V's and yep, it is the same Wingman!
Corally put the steering servo at the front of their chassis designs starting with the SP12G. Then again with the G2 and G3 and once more with the V. They moved moved the servo position with the release of the 12M.
I am working on a new chassis at the mo that should be quite intresting once it's all finished. Got the drawings all done, will send them off to Fibre Lyte sometime this week.
Cheers, Chris.
wingman2 is offline   Reply With Quote
Old 08-31-2009, 06:33 PM   #31969
Default Sj12
I designed this car and made most the parts other than axle and hardware. nothing borrowed from some other car. The ackerman was done in cad and closer to perfect with no bump steer compared to my traditional 12th. the rear servo was to move weight back. On my old rev5 setup battery back was always more steering. as your car slows down in the turn it dumps weight forward. at my home track i am 3 compounds harder front tire and still plenty of steering with this car and servo configuration. Most run 2x pink i'm on purple. It was just an idea i was testing. the car can bolt up standard front end aswell.
1/12 forum-proto1.jpg
Shifty is offline   Reply With Quote
Old 08-31-2009, 07:06 PM   #31970
PartTime's Avatar
Can you keep that linkage setup with a normal suspension ?
Old 08-31-2009, 08:42 PM   #31971
Moderator
Clegg's Avatar
You have any more pictures on how the center link section works? Looks pretty complex/sturdy.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 09-01-2009, 07:35 AM   #31972
Default 1/12th Scale Tire Guide
1/12 Tires From Petitrc
As the 1:12 scale car season is about to start in many countries - except some others like Japan with a full program all year long, here is a summary of tires hardness.
Please, highlight mistakes or missing information!
BSR
Green - Duro 30-35 - Medium-soft Traditional US green.
White - Duro 30-35 - Medium/soft compound, recommended for mostly carpet tracks. Can be used on asphalt but wears alot on asphalt.
Pink - Duro 30-35 - Soft compound recommended for carpet and aspalt racing. Low wear/longer lasting characteristics.
Gray - Duro 35-40 - Medium compound recommended for mostly carpet tracks but also used on asphalt.
Gray/Silver - Dual compound-silver on outside of gray.
Double Pink - Duro 35-40 - Medium compound recommended for carpet and aspalt racing. This is equivalent to Jaco pink. Low wear/longer lasting characteristics.
Purple - Duro 38-43 - BSR developed their own mix of select sheets and seam positioning for our purple. BSR's single purple is different than others. If you want a purple similar to say Jaco use Our Double purple. - Medium/firm compound recommended for carpet and asphalt racing. Low wear/ longer lasting characteristics.
Double Purple - Duro 45-50 - Firm compound recommended on high traction asphalt and carpet tracks. Equivalent to Jaco purple. Low wear/longer lasting characteristics.
Silver - Duro 45-50 - Firm compound for high bite carpet tracks.
Firm Blue - Duro 55-65 - Hard compound recommended on high traction banked carpet tracks. Also offered as a spec tire for front tires.
Red - Firm compound recommended on asphalt for front tire.
Purple/Orange - Dual compound tire for carpet tracks. Helps prevent traction roll. This tire is equivalent to our sedan Double Pink/orange.
Double Purple/Orange - Dual compound tire for high traction carpet tracks. Helps prevent traction roll.
Corally / Corally USA
Front
Green tyres front 1-12 - Shore 32
Goldstar tyres front 1-12 - Shore 30
Silverstar tyres front 1-12 - Shore 34
Gold tyres front 1-12 - Shore 36
Silver tyres front 1-12 - Shore 38
Rear
Green tyres rear 1-12 - Shore 28
Orange (Outdoor Compound) rear 1-12 - Shore 28
Gold tyres rear 1-12 - Shore 28
Silver tyres rear 1-12 - Shore 30
Pink tyres rear 1-12 - Shore 30
CRC
Standard
Front
Magenta - 36-40 shore "soft purples". High grip, long life. Part of the pink/purple family of rubber. Great for 1/12th modified or asphalt.
Black - Long wear, high grip exotic racing rubber.
Red - Med-Firm 40 shore. Exotic, super long wear, med. grip, high rubber content racing foam. For front tires on asphalt. Not for carpet.
Purple - Firm 45 shore. Exotic, long wear, high grip, high rubber content racing foam.
Dual Compound
Magenta/Orange - Med. 35 - 39 shore. Exotic, long wear, high grip, high rubber content racing foam.
Purple/Orange - Firm 45 shore. Exotic, long wear, high grip, high rubber content racing foam.
Rear
White - Med. wear, high grip exotic racing rubber.
Green -30 shore Good old American foam rubber. Less expensive, good grip on carpet, but more wear than the pink/magenta family and more wear than the white/grey family.
Pink - 30-33 shore. High grip, long wear. The traction leader for rear grip. Great for asphalt. Wears like iron with great grip.
Grey - Long wear, high grip exotic racing rubber.
Magenta - 34 - 38 shore. High grip, long wear. Same family as pink, but firmer. Great for asphalt and carept. Wears like iron with great grip.
Pro Cut - Larger diameter
Front
Grey - Softer than black compound for more steering, gets less stickey than Magenta or Purple.
Black - Firm shore, long-wear, high grip, less rubber content, less tacky on high bite tracks.
Purple - Firm shore, long-wear, high grip, high rubber content.
Magenta - Medium shore, long-wear, high grip, high rubber content.
Rear
White - Soft shore, long-wear, high grip, less rubber content, less tacky on high grip. White compound is very soft and will chunk when trued very small
Grey - Medium shore, long-wear, high grip, less rubber content, less tacky on high grip tracks.
Pink - Soft shore, long-wear, high grip, high rubber content.
GRP Gandini
Jaco
Standard
Front
Green – Medium, standard
Pink – Medium-Soft, low wear
Double pink – Medium, low wear
Purple – Medium-Firm, low wear
Rear
Gray – Medium, low wear
White – Medium-Firm, low wear
Prism – Larger diameter
Front
Magenta – 32
Double Pink – 35
Lilac – 38
Purple – 40
Black – 40
Rear
White – 25
Yellow – 30
Gray – 35
Pink – 30
Magenta - 32
Parma
Standard
White – 25
Pink – 30
Black – 35
Violet – 35/40
Purple – 40
Pro 38 – Larger diameter
Grey – 30
Magenta – 37
Purple – 42
TRC
Standard
Front
Green
Blue
Double Blue
Black
Magenta
Pink
Purple
Red
Cyan
Tan
Lime
Rear
Black
Magenta
Green
White
Gray
Platinum
Pink
Purple
Granite
Capz Dual Stage - Larger diameter
Front
Magenta
Purple
Rear
Magenta
Old 09-01-2009, 10:17 AM   #31973
Suspended
Originally Posted by jammincrtjames View Post
-will ceramic diff balls help the longevity between diff re-builds?
Yes, they do. I see wm have them and they are buy 1 get 1 free right now
audacious is offline   Reply With Quote
Old 09-01-2009, 11:53 AM   #31974
Old Tech's Avatar
Default Any 12L3 Drivers out there?
Question for any 12L3 drivers who are also running the Jaco Prism rear wheels. What are you doing to get enough pod clearance on the left (non-drive) side of the pod? Shimming, trimming the rim/tire on the inside, or maybe another idea?
Old Tech is offline   Reply With Quote
Old 09-01-2009, 12:29 PM   #31975
PartTime's Avatar
Check your width. Should be 172mm max. Shim till you get there and if the tire still rubs then sand down the carbon bottom plate that sticks out past the bulkhead.
DK
Old 09-01-2009, 12:48 PM   #31976
Parma
Parma is now the same as Jaco since Jaco makes the Blackhawk rims/tires for them.
Old 09-01-2009, 01:21 PM   #31977
Old Tech's Avatar
DK
Thanks for the info. I was looking at grinding down the bottom plate a little...which would probably do the trick. I was a little concrened about weakening the bottom plate as it is already thin on that side, but I would think the left bulkhead sould provide a good portion of the strength on that side.
Thanks again.
Old 09-01-2009, 02:47 PM   #31978
wingman2's Avatar
You should try the fibre lyte wheel spacers for those rims. They go between the rim and the hub, rather than the hub and the bearing. They are great because you can shim the axle for maximum width for regular rims, and then use these spacers to get maximum width for offset rims. Makes life much easier all round when using several makes of rear rims.
Old 09-01-2009, 02:53 PM   #31979
Old Tech's Avatar
That sounds like a good idea wingman2. Where can I get such a creature?
Glenn
Old 09-01-2009, 09:22 PM   #31980
wingman2's Avatar
Here you go mate:
http://www.fibre-lyte.co.uk/
I have used them quite a few times and seem a good bunch.
Cheers, Chris.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
antlockyer
