    Hide Wikipost
Old 09-19-2017, 11:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: 1/12 forum
Last edit by: DesertRat
This is a place to share knowledge related to 1/12th scale racing. It is not to be used for conversations.
KITS:
Click links to go to manufacturer product page. If any are missing please add them!
TIRES:
Pre-mounted tires readily available in the US:
Pre-mounted tires readily available in the Europe:
  • Hot Race ??
Gluing your own donuts:
https://www.youtube.com/watch?v=hm7z1rz-74s - Special thanks to Edward Pickering!
Truing tires:
https://www.youtube.com/watch?v=8wqHOLWq6Uc - Special thanks to Edward Pickering!
The following information came from HERE, with some editing and information added. Thanks Christian!
THIS MAY NEED UPDATING FOR THE NEW BLACK CRC CARPET
Brands:
BSR, CRC, Jaco:
Pro One is no longer selling to the public, but it and the brands above are all mounted by BSR and use the same foam. The nomenclature of the BSR vs Jaco/CRC is a little different in a few instances but is otherwise the same. The BSR foam consists of three families, and can be identifed as synthetics, naturals, and blends.
Synthetics - The old school, light weight, easy to true "dry feeling" tires. These include tires like CRC/Jaco Yellow (BSR White), Black, Gray, etc. These tires offer the highest wear rate and lowest grip. Many racers continue to use these nder high bite conditions.
Naturals - These tires are usually the best alternative for low bite and asphalt. They include Pink, Magenta, Double Pink, Lilac (BSR Team Purple), Purple, and other tires. These tires provide a ton of grip, but tend to get sticky in high bite conditions. This rubber does not wear as easily, and the cars will pick up gunk and fibers from the carpet under most high bite conditions. This is especially bad if the humidity is high.
Blends - These are the tires most people run today. They were initially called "JFT foam" by some, as it was believed that the tires were the same as the JFT tires. We can divide the blends further into two groups: high rubber and low rubber content. The high rubber would be the new rear Orange and Red from the BSR family, and the low rubber would be the Green and Blue varieties. When, asked about the difference, John Foister from BSR Tires said they came from the same "family" of foam, but they offered different grip. According to John, the Green/Blue has more bite than Orange/Red, but from track testing Oranges offer more bite than Green (being equivalent to in hardness) when the grip is high and absolutely no grip when it is lower. The Orange foam has a denser pore structure and the tire is not as prone to chunking. It is also important to note is that BSR Blue rears are not the same as the BSR Blue fronts!
JFT:
JFT stands for Japan Foam Tire. They started the new wave of foam tires we are all using now (Blue/Blu, Green/Greene, Dbl Blue, etc). These tires are a little different than the BSR tire family, but work in very similar conditions. They offers four varieties A (asphalt), C (carpet), S (???), and R (???). This does not mean that those types only work on that surface, but this is what they recommend.
JFT uses the same foam for fronts and rears if the color is the same.
A: Used on asphalt, considered close to the natural rubber variety and are named consistently with other natural tires.
C: Used on carpet, considered a blend.
S: Used on carpet?, tires are ???
R: Used on carpet?, tires are ???
For setup, the JFT foam seem to generate more bite than the BSR, therefore the car tends to be a little more aggressive.
Ulti:
Ulti is another Japanese brand that offers an array of compounds. They have their own way of rating tires, and are difficult to equate to other brands. They have 4 different varieties, each in varying degrees of hardness.
J: High rubber content tire, similar to Pink/ Magenta. Soft would be close to a pink. These offer the most bite and are great for asphalt/carpet front tire. (J hard being very popular)
X: "Balanced" blend, similar to JFT Blue/ Green. Soft is equivalent to Green, medium to Blue in hardness. Great for carpet!
Y: High synthetic blend with lower grip, and is not a very popular variety.
Z: A very expensive "special" foam that is supposed to be magic on asphalt. Only make it in soft shore.
European tires:
There are many great European foam tire brands that use their own types of foam, as well as traditional foams. SOmeone with more knowledge about them will need to fill this in!
Tire Diameter:
If you are racing on carpet, you have to evaluate how much grip your track has. If your track is low to medium grip, you can run bigger tires. If you are on higher bite you have to cut them smaller, there is simply no way around it. Bigger tires are needed for asphalt, especially in the rear. The larger tires provide much needed lateral bite.
Carpet (mm):
Low - Medium Bite
Front: 42.0 - 42.5
Rear: 42.5 - 43.00
Medium - High Bite
Front: 40.5 - 41.0
Rear: 41.5 - 42.0
Big Race
Front: 39.5 - 40.0
Rear: 40.5 - 41.0
Asphalt (mm):
Parking Lot
Front: 43.0 - 44.0
Rear: 44.0 - 45.0
Prepped High Bite
Front: 42.0 - 43.0
Rear: 43.0 - 44.0
Tire Saucing:
Most facilities have moved towards odorless traction additives such as SXT. Some of additives evaporate very quickly and some do not. This seems to be something that is also dependent on tire compound and ambient temperature. For example, saucing a Green compound seems like it never dries, especially when tjhe temperature is lower. We have found that wiping the tires off 15 minutes before we go run allows the sauce to cure, which makes the car come in much quicker with Green rears. Blue compounds on the other hand, do fine when wiped off right before hitting the track.
Saucing half front and full rear is a good initial starting point. If the front of the car is too agressive you can sauce les than half, or for a shorter amount of time.
Tire Fuzzing:
In conditions of increasing grip, foam tires will somewtimes get sticky and pick up fuzz and debris from the track. This is highly dependent on the rubber sedan tire that is being run at your local track and the compound/ type of foam you are running on you car. The softer the sedan tire and the harder/higher rubber content in your foam tire, trouble with fuzzing seems more likely to occur.
There are ways to get around fuzzing under most conditions, and usually involves the selection of the correct foam compound. The more fuzz you get, the softer/lower rubber content you want to run.
Examples:
Problem: Car fuzzes with Lilac/Team Purple fronts and car starts pushing.
Solution: Use a softer front tire and or different family of foam. Replace it with Blue or Double Blue front.
Problem: Car loses rear bite 6 minutes into the run. Blue rear tires look almost clean but have small carpet hairs.
Solution: Use Green rear tires. The softer compound wears instead of getting sticky, minimizing fuzz.
Tire Selection:
Starting out, pick 2 tire compounds for the front and rear. The following should have you covered 99% of the time.
Rear - Green and Blue (BSR) or Green and Light Blue (JFT)
Front - Blue and Double Blue (BSR) or Blue and Dark Blue (JFT)
You may wonder about other compounds out there and if they might be better, trust me, they probably won't be. Even if there are other tires that can be as fast, the synthetic family wears out really fast and the high natural rubber will probably fuzz on you over an 8 minute run. The blends family seems to be the most versatile foam type available today. They last awhile, and sticking to them will make your process of tire selection simpler.
Tire Charts:
BSR/CRC/Jaco
Contact
Corally
JFT (Japan Foam Tire)
Ulti
Enneti (Xceed)
ELECTRONICS:
ESC:
As of now, ROAR is staying 1S (3.7V nominal; 4.2V fully charged) for 1/12. There are many 1S ESC's with a built in BEC so nothing else is required to power the receiver and servo.
If you don't want to lock yourself into a 1S specific ESC, you do have other options! It is possible to use your 2S ESC without a booster or receiver pack, and the ESC simply supplies the lower voltage. If that does not appeal to you, you will need to use an Rx pack or booster. The Rx pack and booster will both supply the receiver with a higher voltage than the 1S pack.
If you decide to use an Rx pack, MAKE SURE TO REMOVE THE RED WIRE FROM THE ESC PLUG THAT GOES INTO THE RECEIVER!!!
If you choose to use a voltage booster, it works exactly how it sounds. Instead of plugging the ESC into the receiver, it plugs into the booster, and the booster plug goes to the ESC, supplying the higher voltage.
1S ESC:
If there are any missing please add them!!
If anyone would like a need for a chart comparing the ESC's specs PM fenton06 and I'll get one made and put in here!
DISCONTINUED 1S ESC:
Voltage Boosters:
Servos:
BODIES:
Black Art (CRC - US Dist):
  • Audi R8C - BA002 - .020 Thick
  • Black Market (Mohawk 12) - BA005 - .020
  • Lola B10 - BA006 - .020 thick
  • Toyota TS030 - BA008 - .020 thick
    Lola - black/red, TS030 - green/pink
PROTOForm:
Reflex Racing/RSD:
SUSPENSION ADJUSTMENTS:
Print Wikipost
Like Tree62Likes
Old 12-14-2008, 11:45 AM   #29896
There is also the Tekin RS which is smaller then any of the ones you mention.
Old 12-14-2008, 01:45 PM   #29897
chris moore's Avatar
Trader Rating: 87 (99%+)
Originally Posted by jph View Post
Hi, I have another question,
What esc can y'all recomend for a 17.5 burshless setup for 1/12 scale?
Novak 4 cell gtb w/ 17.5, Speed Passion GT, or should I wait for the new Orion? Is it worth the extra $100?
What is everone else running?
Thanks,
Jeff
I'm using the 4-cell gtb, it fits fine and works great. But if I had the money I'd go with the Tekin because its smaller and smaller is better in 1/12.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 12-14-2008, 02:00 PM   #29898
Ike
Ike's Avatar
Thanks,
Jeff
I'd get one of the new Gen. speedos if I were you. One of the new LRP speedos, the KO/Orion, or the Tekin... Only thing I don't like about the Tekin right now is that it seems to have issues with the new single cell lipos, hopefully they will fix that.
Ike is offline   Reply With Quote
Old 12-14-2008, 02:02 PM   #29899
jph
The Tekin RS looks good, how is the Redline 17.5?
jph is offline   Reply With Quote
Old 12-14-2008, 02:09 PM   #29900
jph
Is the Sphere the new LRP?
Old 12-14-2008, 02:40 PM   #29901
Ike
Ike's Avatar
Nope, the new ones are the SPX stock spec and the SXX.
Old 12-14-2008, 02:45 PM   #29902
jph
Ooh, the SXX looks cool.
How long do I have to wait for one?
Old 12-14-2008, 02:59 PM   #29903
Ike
Ike's Avatar
March for the SXX I believe and very soon for the Stock Spec.
Old 12-14-2008, 03:00 PM   #29904
jph
Nevermind, I see that it is March.
I don't know if I can wait that long.
Maybe LRP needs some help testing one.
Old 12-14-2008, 03:01 PM   #29905
jph
Ok, I just seen that also.
Old 12-14-2008, 08:10 PM   #29906
MikeH's Avatar
Trader Rating: 14 (100%+)
CarbonJoe and Oldguyzrule - Thanks guys
Ewe kant fiks stooped
MikeH is offline   Reply With Quote
Old 12-15-2008, 05:35 AM   #29907
PartTime's Avatar
Hey guys, 1/12 newbe here. A few questions.
I picked up a used CRC, older car but not sure witch one. If it helps its a brushed motor pod with delrin upper arms and alum 5deg mounts. I need to know where to start tuning. I have purple in front and was thinking dbl pink or gray rear. But after that Im lost. I have pod springs but dont know where to start and if I start with the springs what do I do with the damper tubes? Or maybe start with the shock? Im gonna assume that I have .020 springs in the front and am gonna leave them alone seeing how I dont have any others right now.
I found Rich Chang's tuning guide but still wondering were to start and in what order would be best.
DK
Edit: Im running 17.5/4 cell on carpet.
PartTime is offline   Reply With Quote
Old 12-15-2008, 07:12 AM   #29908
Trader Rating: 76 (100%+)
DK
Hey Parttime, I think I would start with this. First off, never assume anything. Front springs are only two dollars, buy a pair that way you know for sure what you have. I would also start off with 10 degree's of caster in the front.
The cnter shock I would start of with 30 wt oil and a copper spring from associated. The dampning tubes start with 10,000, and the side springs should be white. Ride height about 3.5 in the rear, and 3-3.25 in the front. Also, about 1 millimeter of pod droop. Dope all the rear tires and the inside 1/3 of the fronts.
If you have any more questions, feel free to ask.
Ken
MUDVAYNE is offline   Reply With Quote
Old 12-15-2008, 07:34 AM   #29909
Trips's Avatar
Trader Rating: 16 (100%+)
+1 to everything Ken said, I'd jsut add that for tires Jaco yellow rear/lilsac front ought to work almost everywhere (carpet) Also if the track is bumpy or the grip low, I'd go 3.5mm front and 4mm rear on the ride height. Maybe have a blue shock spring on hand if the car feels too aggressive...
MARSHAL!!
Trips is offline   Reply With Quote
Old 12-15-2008, 08:02 AM   #29910
AdrianM's Avatar
As a thank you to all our customers we are offering free UPS Ground shipping on all domestic orders until December 24th.
www.bmiracing.com
Adrian Martinez
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 11 (2 members and 9 guests)
Pinkz, pmes
