    Hide Wikipost
Old 09-20-2017, 01:39 AM   -   Wikipost
R/C Tech Forums Thread Wiki: 1/12 forum
Last edit by: Skiddins
This is a place to share knowledge related to 1/12th scale racing. It is not to be used for conversations.
KITS:
Click links to go to manufacturer product page. If any are missing please add them!
TIRES:
Pre-mounted tires readily available in the US:
Pre-mounted tires readily available in the Europe:
  • Hot Race ??
Gluing your own donuts:
https://www.youtube.com/watch?v=hm7z1rz-74s - Special thanks to Edward Pickering!
Truing tires:
https://www.youtube.com/watch?v=8wqHOLWq6Uc - Special thanks to Edward Pickering!
The following information came from HERE, with some editing and information added. Thanks Christian!
THIS MAY NEED UPDATING FOR THE NEW BLACK CRC CARPET
Brands:
BSR, CRC, Jaco:
Pro One is no longer selling to the public, but it and the brands above are all mounted by BSR and use the same foam. The nomenclature of the BSR vs Jaco/CRC is a little different in a few instances but is otherwise the same. The BSR foam consists of three families, and can be identifed as synthetics, naturals, and blends.
Synthetics - The old school, light weight, easy to true "dry feeling" tires. These include tires like CRC/Jaco Yellow (BSR White), Black, Gray, etc. These tires offer the highest wear rate and lowest grip. Many racers continue to use these nder high bite conditions.
Naturals - These tires are usually the best alternative for low bite and asphalt. They include Pink, Magenta, Double Pink, Lilac (BSR Team Purple), Purple, and other tires. These tires provide a ton of grip, but tend to get sticky in high bite conditions. This rubber does not wear as easily, and the cars will pick up gunk and fibers from the carpet under most high bite conditions. This is especially bad if the humidity is high.
Blends - These are the tires most people run today. They were initially called "JFT foam" by some, as it was believed that the tires were the same as the JFT tires. We can divide the blends further into two groups: high rubber and low rubber content. The high rubber would be the new rear Orange and Red from the BSR family, and the low rubber would be the Green and Blue varieties. When, asked about the difference, John Foister from BSR Tires said they came from the same "family" of foam, but they offered different grip. According to John, the Green/Blue has more bite than Orange/Red, but from track testing Oranges offer more bite than Green (being equivalent to in hardness) when the grip is high and absolutely no grip when it is lower. The Orange foam has a denser pore structure and the tire is not as prone to chunking. It is also important to note is that BSR Blue rears are not the same as the BSR Blue fronts!
JFT:
JFT stands for Japan Foam Tire. They started the new wave of foam tires we are all using now (Blue/Blu, Green/Greene, Dbl Blue, etc). These tires are a little different than the BSR tire family, but work in very similar conditions. They offers four varieties A (asphalt), C (carpet), S (???), and R (???). This does not mean that those types only work on that surface, but this is what they recommend.
JFT uses the same foam for fronts and rears if the color is the same.
A: Used on asphalt, considered close to the natural rubber variety and are named consistently with other natural tires.
C: Used on carpet, considered a blend.
S: Used on carpet?, tires are ???
R: Used on carpet?, tires are ???
For setup, the JFT foam seem to generate more bite than the BSR, therefore the car tends to be a little more aggressive.
Ulti:
Ulti is another Japanese brand that offers an array of compounds. They have their own way of rating tires, and are difficult to equate to other brands. They have 4 different varieties, each in varying degrees of hardness.
J: High rubber content tire, similar to Pink/ Magenta. Soft would be close to a pink. These offer the most bite and are great for asphalt/carpet front tire. (J hard being very popular)
X: "Balanced" blend, similar to JFT Blue/ Green. Soft is equivalent to Green, medium to Blue in hardness. Great for carpet!
Y: High synthetic blend with lower grip, and is not a very popular variety.
Z: A very expensive "special" foam that is supposed to be magic on asphalt. Only make it in soft shore.
European tires:
There are many great European foam tire brands that use their own types of foam, as well as traditional foams. SOmeone with more knowledge about them will need to fill this in!
Tire Diameter:
If you are racing on carpet, you have to evaluate how much grip your track has. If your track is low to medium grip, you can run bigger tires. If you are on higher bite you have to cut them smaller, there is simply no way around it. Bigger tires are needed for asphalt, especially in the rear. The larger tires provide much needed lateral bite.
Carpet (mm):
Low - Medium Bite
Front: 42.0 - 42.5
Rear: 42.5 - 43.00
Medium - High Bite
Front: 40.5 - 41.0
Rear: 41.5 - 42.0
Big Race
Front: 39.5 - 40.0
Rear: 40.5 - 41.0
Asphalt (mm):
Parking Lot
Front: 43.0 - 44.0
Rear: 44.0 - 45.0
Prepped High Bite
Front: 42.0 - 43.0
Rear: 43.0 - 44.0
Tire Saucing:
Most facilities have moved towards odorless traction additives such as SXT. Some of additives evaporate very quickly and some do not. This seems to be something that is also dependent on tire compound and ambient temperature. For example, saucing a Green compound seems like it never dries, especially when tjhe temperature is lower. We have found that wiping the tires off 15 minutes before we go run allows the sauce to cure, which makes the car come in much quicker with Green rears. Blue compounds on the other hand, do fine when wiped off right before hitting the track.
Saucing half front and full rear is a good initial starting point. If the front of the car is too agressive you can sauce les than half, or for a shorter amount of time.
Tire Fuzzing:
In conditions of increasing grip, foam tires will somewtimes get sticky and pick up fuzz and debris from the track. This is highly dependent on the rubber sedan tire that is being run at your local track and the compound/ type of foam you are running on you car. The softer the sedan tire and the harder/higher rubber content in your foam tire, trouble with fuzzing seems more likely to occur.
There are ways to get around fuzzing under most conditions, and usually involves the selection of the correct foam compound. The more fuzz you get, the softer/lower rubber content you want to run.
Examples:
Problem: Car fuzzes with Lilac/Team Purple fronts and car starts pushing.
Solution: Use a softer front tire and or different family of foam. Replace it with Blue or Double Blue front.
Problem: Car loses rear bite 6 minutes into the run. Blue rear tires look almost clean but have small carpet hairs.
Solution: Use Green rear tires. The softer compound wears instead of getting sticky, minimizing fuzz.
Tire Selection:
Starting out, pick 2 tire compounds for the front and rear. The following should have you covered 99% of the time.
Rear - Green and Blue (BSR) or Green and Light Blue (JFT)
Front - Blue and Double Blue (BSR) or Blue and Dark Blue (JFT)
You may wonder about other compounds out there and if they might be better, trust me, they probably won't be. Even if there are other tires that can be as fast, the synthetic family wears out really fast and the high natural rubber will probably fuzz on you over an 8 minute run. The blends family seems to be the most versatile foam type available today. They last awhile, and sticking to them will make your process of tire selection simpler.
Tire Charts:
BSR/CRC/Jaco
Contact
Corally
JFT (Japan Foam Tire)
Ulti
Enneti (Xceed)
ELECTRONICS:
ESC:
As of now, ROAR is staying 1S (3.7V nominal; 4.2V fully charged) for 1/12. There are many 1S ESC's with a built in BEC so nothing else is required to power the receiver and servo.
If you don't want to lock yourself into a 1S specific ESC, you do have other options! It is possible to use your 2S ESC without a booster or receiver pack, and the ESC simply supplies the lower voltage. If that does not appeal to you, you will need to use an Rx pack or booster. The Rx pack and booster will both supply the receiver with a higher voltage than the 1S pack.
If you decide to use an Rx pack, MAKE SURE TO REMOVE THE RED WIRE FROM THE ESC PLUG THAT GOES INTO THE RECEIVER!!!
If you choose to use a voltage booster, it works exactly how it sounds. Instead of plugging the ESC into the receiver, it plugs into the booster, and the booster plug goes to the ESC, supplying the higher voltage.
1S ESC:
If there are any missing please add them!!
If anyone would like a need for a chart comparing the ESC's specs PM fenton06 and I'll get one made and put in here!
DISCONTINUED 1S ESC:
Voltage Boosters:
Servos:
BODIES:
Black Art (CRC - US Dist):
  • Audi R8C - BA002 - .020 Thick
  • Black Market (Mohawk 12) - BA005 - .020
  • Lola B10 - BA006 - .020 thick
  • Toyota TS030 - BA008 - .020 thick
    Lola - black/red, TS030 - green/pink
PROTOForm:
Reflex Racing/RSD:
SUSPENSION ADJUSTMENTS:
Pan Car Front Suspension Tuning:
DISCLAIMER : The following tuning advice was written based on the tuning experience of the author and may not hold true for all cars, drivers, or surfaces. In the end the best tuning advice is to experiment and make changes one at a time so you can track your changes and find the car balance that works best for your driving style. One real world test is worth a million ‘expert’ opinions.
Front End Type:
All popular modern pan car front suspensions are very similar, with a few exceptions such as Speedmerchant New School but most of the info in this wiki applies to them as well. For the most part, they consist of a rigid bottom arm, an upper A-arm, and a kingpin with a spring. There are different flavors of this general design, such as the CRC Dynamic Strut that uses a threaded kingpin and upper pivot ball instead of the Associated style that uses a kingpin that goes through the entire steering knuckle assembly, but their operation is the same with the rigid lower arm and the upper arm controlling the arc of movement as the suspension is compressed.
Assembly:
More so than in almost any other part of the car, the front suspension of your 1/12 car must move absolutely free. Reamers and hobby knives are important here, as any binding will cause the car to corner unpredictably. A little play in the suspension is a good thing, and racers will often find that ‘worn in’ suspension pieces function a little better than new.
Springs:
Besides tires, spring rate is the most important part of deciding how your car will handle through corners, but are somewhat complicated. As a general rule of thumb, a very hard front spring will have somewhat less steering grip than a softer spring with the same suspension setup and tires, but not as much as in other classes such as touring or offroad. On carpet, springs of different tension can be used to tune how your car will maintain or lose energy through corners with the following general rule of thumb:
Hard Spring (0.55mm or harder): Less overall steering, quick reaction to driver input, less on power steering, harder turn-in with potentially lazy mid-corner and exit.
Soft Spring (.45mm): More overall steering especially at low speed, slightly slower reaction to driver input, more on-power steering, less aggressive turn-in but can ‘hook’ and give better mid-corner and exit.
It is worth noting that front springs from different suppliers are often very different, in both height, wire thickness, and coils for a given spring height meaning that a “medium” spring from one manufacturer may be the “hard” spring for another. To make accurate changes you may want to use one spring maker and stick with their line.
Another aspect to pan car springs is that they can get “blown out” and collapse, no longer as stiff or as tall as they were. These should be replaced with fresh springs to ensure consistent handling.
Dampening:
This is generally a minor adjustment, but adding dampening tube fluid to the front kingpins of a 1/12 car can give it a little more initial steering. Often unusual compounds see use here, such as Losi Smart Diff Grease or Associated Green Slime being a popular front kingpin lube.
Caster and Reactive Caster:
Caster is the angle of the kingpin, almost always angling back to the rear of the car, with a typical range from 0-10 degrees. Increasing your caster will typically result in less turn-in but a little more control, more steering exiting the corner, and somewhat increased straight-line stability with less tendency to wander because a wheel running caster will tend to straighten itself. Less caster will usually give you more off-power steering, but often with correspondingly less on-power when accelerating out of the corner.
Running reactive caster attempts to use both of these aspects to increase overall steering: when the car loads up on the outside front tire, the caster angle decreases, increasing the front end ‘hook’ as you enter the corner and then giving you the high caster on-power steering as you exit and weight is transferred off the front end. More reactive caster means more overall steering, but can mean you may have to adjust your driving style to drive more ‘ahead of the car’, needing to predict where the front end will grip.
As grip increases, less reactive caster is the normal tuning change made to keep the front end of the car from gripping too hard and oversteering and prevent traction roll. Static caster adjustments are still used to change the cars on power / off power steering balance.
Reactive Camber and Front Roll Center:
Reactive camber or camber gain is how much camber is added the front wheels as the suspension compresses. This can be increased or decreased by changing the angle and length of the top arm. Short, angled arm = more. Long, flat arm = less. More reactive camber will typically cause the car to “roll up” on the outer front wheel, transferring more weight in a turn and give more steering up to the point at which the tire is overloaded. This is generally more front grip and weight transfer than wanted on carpet, and as a result most cars run a flatter longer front arm.
Roll Center is the point on which the car will twist laterally or ‘roll’ during cornering. This can be raised or lowered by changing the angle and length of the top arm, with a short angled arm raising is slightly and a long flat arm lowering it. From what I have calculated most modern 1/12 cars meant for carpet have a roll center somewhere around the height of the chassis plate or just below it, but due to the lower arms being rigid and flat the roll center cannot be under the bottom of the tires like it often is on a touring car.
These two are inexorably linked in pan cars. Top arm length can be changed by the top arm mount in or out using shims or a CRC Long Arm kit, but is generally a minor tuning choice. Tuning of roll center with shims is usually a minor tuning choice in a pan car with a rigid bottom arm due to how the car cannot gain extra mechanical advantage on the lower arm as you can in a touring car, while reactive camber can be a significant driver of the car’s performance. In a modern car running on carpet the kit setup is usually perfectly fine.
Front End Alignment:
Static camber is the angle of your front wheels at rest, typically somewhere from 0 to 1.5 degrees on a pan car depending on surface, tire choice, and other factors, but a good starting point is usually somewhere around 0.5 degrees. More camber will typically give more steering, but many racers use static camber to ensure that their tires wear flat even if that means not having exactly equal camber on both sides of the car. This is adjusted by threading in and out the upper turnbuckle or pivot ball.
It is also worth noting that when running on high grip the flex and deformation of your chassis, suspension parts, and front wheels can become significant and cause uneven front tire wear. Some troubleshooting of the right combination of static camber, camber gain, caster, and tire/rim choice may be necessary to ensure even front tire wear.
Toe-In:
The front toe is one of the more easily adjusted aspects of the car and can have a significant effect on the attitude of the car due to it being a quick way to moderately adjust Ackerman without making significant other changes. With nothing else being adjusted, going from zero toe to toe-in will give a car a harder turn-in and will tend to scrub speed with the front end as opposed to using drag brake. This can be necessary when racing in Super Stock or higher power classes and will allow you to drive more aggressively, and can help the car track straighter under power. Toe-out will tend to make the car coast more through corners due to reducing the steering angle of the outer front tire. If a car has too much off-power steering but is otherwise stable, adding toe-out can calm the car but may the car to wander on the straights especially if the front end setup is very soft.
Ackerman:
Ackerman is the difference in steering angle between the two front tires during a turn. It is the result of how during a turn the inside of the car experiences a tighter circle and needs correspondingly more steering angle, but is also an important tuning tool. More Ackerman means having more inside wheel steering angle relative to the outer wheel, less means that the difference in steering angle is smaller.
To add or remove Ackerman, using a servo horn that spaces the links further apart (such as a Kimbrough Small Servo Saver, the outer holes on a Tamiya or Xray servo saver) will have more Ackerman than a servo that puts the links close together (Kimbrough Medium inner holes, Tamiya or Xray inner holes.) The rule of thumb is that a servo that puts the ball studs close together but spaced away from the servo horn will have less Ackerman than one that spaces them far apart and close to the servo horn. Ackerman changes will have the same effect as changing toe with more Ackerman being effectively toeing the wheels out and less toeing them in, but will not affect the straight-line attitude of the car.
Turning Circle / Steering Angle:
In offroad or even touring car you can set up the car to use the full angle of the steering 100% of the time. You will almost certainly not be able to do this in 1/12 scale. It goes without saying that as you turn up your steering angle you will gain steering often to the point of the car being undriveable. The quickest way to set the steering correctly is to set the sub-trim in your radio such that the car tracks straight and the servo horn is straight up and down, then set the endpoints equally such that they don't quite hit the steering bump-stops, then turn down the dual-rate or total throw from there. A typical starting point is somewhere between 45 and 60% of the total steering throw, or a 4-5' turning circle.
SOMEONE ELSE DO THE REAR TUNING SECTION! AND A TROUBLESHOOTING TREE! FEEL FREE TO MAKE YOUR OWN CHANGES!
Print Wikipost
Like Tree62Likes
Old 12-23-2007, 04:50 PM   #27736
chris moore's Avatar
Trader Rating: 87 (99%+)
I remember someone else that had or did use this, mabey OD, hopefully thay will chime in with the answer you need.
chris moore is offline   Reply With Quote
Old 12-23-2007, 05:18 PM   #27737
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
I have one of those, and use it to set the rear width and make sure the rear tires are centered on the pod.
1)Add shims to rear axle until width reads 172mm (I use a set of 12" Harbor Freight Digital calipers to check this.) Doesn't matter what side you put the shims on at this point.
2)Put the metal block up against the rear wheel as shown in the picture. Leave the thumbscrew that holds the rod loose.
3)Push on the rod until it barely touches the side of the chassis as shown in the picture. Tighten the thumbscrew.
4) Put the gauge on the other rear wheel and sweep the rod so it passes the side of the chassis. The rod should barely touch the side of the chassis. If the rod doesn't touch the chassis or hits with the side of the rod, the axle isn't centered. Move the shims on the rear axle, reset the rod and try again. When the rod barely touches the side of the chassis on both sides, the axle is centered.
It takes a few tries to get it right, but once you do you can note how many shims are on each side and you don't have to mess with it again unless you change rear wheel brands (different offset).
Hope this helps. I saw you post this on rcracing.com so i'm guessing you're local to the NorCal area. Next time you come to Norcal Hobbies hit me up and I can show you how to use it.
-James
JamesArluck is offline   Reply With Quote
Old 12-23-2007, 06:43 PM   #27738
Trader Rating: 32 (100%+)
I am looking for this part number for a hotbodies center shock 61661. Does anyone know where I can find it?
-Monti-
Monti is offline   Reply With Quote
Old 12-23-2007, 08:22 PM   #27739
bsmooth's Avatar
Trader Rating: 17 (100%+)
-James
Thanks James, I'll try that.
What about toe and camber? I really don't get that part. I'll look you up if I make it to NorCal.
Regards,
Steve
bsmooth is offline   Reply With Quote
Old 12-23-2007, 08:40 PM   #27740
corallyman's Avatar
Trader Rating: 99 (100%+)
Originally Posted by bsmooth View Post
Here it is: ( niftech.com )
Steve,
I am sorry, I won't be of any help. I never had that system. I guess mine was something from racecraft or something like that.
Steve
corallyman is offline   Reply With Quote
Old 12-23-2007, 10:06 PM   #27741
bsmooth's Avatar
Originally Posted by corallyman View Post
Steve,
Steve
No problem. I'll get it sorted one way or another.
Old 12-23-2007, 10:14 PM   #27742
Regards,
Steve
For camber I use an RPM camber gauge, and just eyeball toe in. When i'm feeling anal i'll borrow OD unity tweek station which has really nice gauges for toe and camber. Racetech used to make a cool tool to check caster and camber with, but that's long out of production. I have NO idea how to check toe using the niftech thingie, sorry.
-James
Old 12-23-2007, 11:38 PM   #27743
corallyman's Avatar
Racetech....that's what I have. It is a pretty cool device.
Steve
I'll post a picture of it tomorrow or shortly after.
Old 12-24-2007, 05:38 AM   #27744
ToddFalkowski's Avatar
Send a message via Yahoo to ToddFalkowski
-Monti-
Monti, about the only place I found it was on the HB Europe site. http://www.hbeurope.com/parts.php?pa...pe=STD&lang=en
ToddFalkowski is offline   Reply With Quote
Old 12-24-2007, 08:48 AM   #27745
Grenade10's Avatar
Trader Rating: 37 (100%+)
Back a few posts was a very good process to set the rear width and how to center the rear axel.
Something that I forgot to check was after changing brands of tires, you need to re-check and probably re-set the width and centering as the wheels from different brands are not made the same!
Also, I've had my Unity Set Up station for 20+ years and it still is the most universal out there. It will do 1/12, 1/10 and even 1/8 scale for track width, caster and toe in on all four wheels and then tweek the car. Nice to purchase something once (Darn expensive at $150 20 years ago, but still the same price today.)
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 12-24-2007, 09:34 AM   #27746
bsmooth's Avatar
The Unity is very nice! I may go that route if this one is too much of a hassle.
Old 12-24-2007, 10:18 AM   #27747
-Monti-
HA! Welcome to the scavenger hunt. I have not found a part number for the complete shock to date. Hot Bodies will probably offer that as a future option but it's not available as a complete shock right now. You have to buy all of the parts and part number 61661 is not available, ANYWHERE!!! I have checked as many of the Euro sites that I could find and all of the Asian sites I could find. None available anywhere. I am sure that they will become available eventually. Stormer has all of the parts in stock except for 61661.
If anyone finds 61661 any where, please post the site.
Crashby is offline   Reply With Quote
Old 12-24-2007, 10:33 AM   #27748
Thanks for the help and I had run into the same issue, I have all the parts from Stormer but I still need 61661. I was maybe hoping that someone knows of a local hobby shop that has some parts on the wall? I did check Horzions web site and they said Feb 08 before they could expect to have that part. I am about ready to make my own if that is going to be the case! If anyone has any other information please help.
-Monti-
Another option would be to buy a kit for the part! HAHA
Old 12-25-2007, 05:45 AM   #27749
HB
Hi
I'm new whit 1/12cars
can someone tel me what have to put under the Damper washer???
fett or someting???
HB is offline   Reply With Quote
Old 12-25-2007, 07:04 AM   #27750
Scottrik's Avatar
Trader Rating: 245 (100%+)
Are any of you using the Niftech alignment tool? I just got mine, and am having a heck of a time trying to understand how it works!
I'm able to get it attached to the car, but how the hell are you supposed to derive any measurements when there is nothing scribed anywhere (except for the white lines)
Hey guys--
The surgeons were unable to kill me so here I am, back to pester.
Here is what I posted via pm to a fellow regarding how to use the Niftech alignment gauge. For simplicity/speed sake I use a RPM camber gauge to set camber. For toe, though, even though I have a Unity station I invariably use the Niftech gauges--just a lot less hassle setting up, much more (MUCH much more) compact, works as well, etc. Plus as was indicated the Niftech gauge is also excellent for adjusting center on the rear axle.
lmk if I can provide additional info.
The single-hole bar has precision etched lines on either end that line up with a rod sticking through the other. It is the accuracy of the bar holes and these lines that make it work.
Set car on a stand that supports it off it's wheels. I use foam stands from p-dub but others are fine too.
Center the servo horn as best possible using the sub-trim on your radio to fine tune
Front wheels removed, install the bars on either axle. I install the one with 2 holes that holds the rod on the rf (to my left--the chassis is facing me). It really doesn't matter which side, I just find it easier to be consistent.
Radio transmitter and receiver on.
Pull the front of the car so it hangs out over the edge of your bench/set-up board/whatever. You need clearance to swing the bars around. Your batteries and motor are installed so there's plenty of weight to hold the car on the table.
You can eyeball the bars pretty straight. Once you're close push the rod through and see how it lines up with the line on the opposite (lf bar--to my right). Once it's pointing straight at the forward line flip the bar to your left (the one with the rod) over and check it against the back side of the other bar...how does it line up with the line there. It likely won't quite, what this means is one side is toed in a little and one side is toed out.
If it is pointing behind the line that means the rf (to your left) is toed in a bit and the lf (to your right) is toed out a bit. Give a part turn (not more than 1/8) to the rf turnbuckle (again, to your left) to shorten it and a similar amount to the lf turnbuckle (to your right) to lengthen it and check again. THIS is the fiddling that takes a little getting used to, but after a few times you'll see exactly how it works.
Once I get it so the rod points at the lines front and back you have it set with zero toe--the wheels are pointed exactly parallel to the centerline of the chassis. I ran like this for a couple years but this year I've taken to running about 1mm or a bit more of toe out. To get this I find the zero point then shorten each turnbuckle by about 1/8 turn. You can measure how much this yields by checking with the rod again. If you have it flipped back and push it through to touch the other bar then flip it to the front. There will now be a gap, divide that gap by 2 and you have your toe.
I RARELY need to adjust my steering trim to have the car track straight after I've done this. It's amazing how such a simple device can work so well.
It is also PERFECT for checking to see that your rear axle is centered in the car.
If I knew how to post things to U-Tube, etc, I'd make a video on doing this. I spent far longer typing this than it takes me to perform the check/adjustment.
The BIG key to making this work is to have your turnbuckles properly oriented. I can't tell you how many times I've bought or worked on cars that weren't so you're spending your time guessing which direction goes longer or shorter. I have ALL my cars set up so that when I use my turnbuckle wrench(es) the turbuckles get longer if I pull forward and shorter if I pull to the rear. This is done by making sure that ALL of the right-hand thread ends of ALL your turnbuckles point to the right side of the car.
I think I've mentioned that I've got a Unity station. They're a VERY nice piece, but I never use it. It's really no more accurate. It might be a little faster to use but the time to set it up WAY more than offsets that. Plus it needs a lot of space, you gotta be careful around it, etc. The Niftech bars are pretty much indestructible and sit nicely with my wrenches, etc.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
azeroth
