    Hide Wikipost
Old 10-28-2016, 12:43 PM   -   Wikipost
R/C Tech Forums Thread Wiki: 1/12 forum
Last edit by: fenton06
This is a place to share knowledge related to 1/12th scale racing. It is not to be used for conversations.
KITS:
Click links to go to manufacturer product page. If any are missing please add them!
TIRES:
Pre-mounted tires readily available in the US:
Pre-mounted tires readily available in the Europe:
  • Hot Race ??
Gluing your own donuts:
https://www.youtube.com/watch?v=hm7z1rz-74s - Special thanks to Edward Pickering!
Truing tires:
https://www.youtube.com/watch?v=8wqHOLWq6Uc - Special thanks to Edward Pickering!
The following information came from HERE, with some editing and information added. Thanks Christian!
THIS MAY NEED UPDATING FOR THE NEW BLACK CRC CARPET
Brands:
BSR, CRC, Jaco:
Pro One is no longer selling to the public, but it and the brands above are all mounted by BSR and use the same foam. The nomenclature of the BSR vs Jaco/CRC is a little different in a few instances but is otherwise the same. The BSR foam consists of three families, and can be identifed as synthetics, naturals, and blends.
Synthetics - The old school, light weight, easy to true "dry feeling" tires. These include tires like CRC/Jaco Yellow (BSR White), Black, Gray, etc. These tires offer the highest wear rate and lowest grip. Many racers continue to use these nder high bite conditions.
Naturals - These tires are usually the best alternative for low bite and asphalt. They include Pink, Magenta, Double Pink, Lilac (BSR Team Purple), Purple, and other tires. These tires provide a ton of grip, but tend to get sticky in high bite conditions. This rubber does not wear as easily, and the cars will pick up gunk and fibers from the carpet under most high bite conditions. This is especially bad if the humidity is high.
Blends - These are the tires most people run today. They were initially called "JFT foam" by some, as it was believed that the tires were the same as the JFT tires. We can divide the blends further into two groups: high rubber and low rubber content. The high rubber would be the new rear Orange and Red from the BSR family, and the low rubber would be the Green and Blue varieties. When, asked about the difference, John Foister from BSR Tires said they came from the same "family" of foam, but they offered different grip. According to John, the Green/Blue has more bite than Orange/Red, but from track testing Oranges offer more bite than Green (being equivalent to in hardness) when the grip is high and absolutely no grip when it is lower. The Orange foam has a denser pore structure and the tire is not as prone to chunking. It is also important to note is that BSR Blue rears are not the same as the BSR Blue fronts!
JFT:
JFT stands for Japan Foam Tire. They started the new wave of foam tires we are all using now (Blue/Blu, Green/Greene, Dbl Blue, etc). These tires are a little different than the BSR tire family, but work in very similar conditions. They offers four varieties A (asphalt), C (carpet), S (???), and R (???). This does not mean that those types only work on that surface, but this is what they recommend.
JFT uses the same foam for fronts and rears if the color is the same.
A: Used on asphalt, considered close to the natural rubber variety and are named consistently with other natural tires.
C: Used on carpet, considered a blend.
S: Used on carpet?, tires are ???
R: Used on carpet?, tires are ???
For setup, the JFT foam seem to generate more bite than the BSR, therefore the car tends to be a little more aggressive.
Ulti:
Ulti is another Japanese brand that offers an array of compounds. They have their own way of rating tires, and are difficult to equate to other brands. They have 4 different varieties, each in varying degrees of hardness.
J: High rubber content tire, similar to Pink/ Magenta. Soft would be close to a pink. These offer the most bite and are great for asphalt/carpet front tire. (J hard being very popular)
X: "Balanced" blend, similar to JFT Blue/ Green. Soft is equivalent to Green, medium to Blue in hardness. Great for carpet!
Y: High synthetic blend with lower grip, and is not a very popular variety.
Z: A very expensive "special" foam that is supposed to be magic on asphalt. Only make it in soft shore.
European tires:
There are many great European foam tire brands that use their own types of foam, as well as traditional foams. SOmeone with more knowledge about them will need to fill this in!
Tire Diameter:
If you are racing on carpet, you have to evaluate how much grip your track has. If your track is low to medium grip, you can run bigger tires. If you are on higher bite you have to cut them smaller, there is simply no way around it. Bigger tires are needed for asphalt, especially in the rear. The larger tires provide much needed lateral bite.
Carpet (mm):
Low - Medium Bite
Front: 42.0 - 42.5
Rear: 42.5 - 43.00
Medium - High Bite
Front: 40.5 - 41.0
Rear: 41.5 - 42.0
Big Race
Front: 39.5 - 40.0
Rear: 40.5 - 41.0
Asphalt (mm):
Parking Lot
Front: 43.0 - 44.0
Rear: 44.0 - 45.0
Prepped High Bite
Front: 42.0 - 43.0
Rear: 43.0 - 44.0
Tire Saucing:
Most facilities have moved towards odorless traction additives such as SXT. Some of additives evaporate very quickly and some do not. This seems to be something that is also dependent on tire compound and ambient temperature. For example, saucing a Green compound seems like it never dries, especially when tjhe temperature is lower. We have found that wiping the tires off 15 minutes before we go run allows the sauce to cure, which makes the car come in much quicker with Green rears. Blue compounds on the other hand, do fine when wiped off right before hitting the track.
Saucing half front and full rear is a good initial starting point. If the front of the car is too agressive you can sauce les than half, or for a shorter amount of time.
Tire Fuzzing:
In conditions of increasing grip, foam tires will somewtimes get sticky and pick up fuzz and debris from the track. This is highly dependent on the rubber sedan tire that is being run at your local track and the compound/ type of foam you are running on you car. The softer the sedan tire and the harder/higher rubber content in your foam tire, trouble with fuzzing seems more likely to occur.
There are ways to get around fuzzing under most conditions, and usually involves the selection of the correct foam compound. The more fuzz you get, the softer/lower rubber content you want to run.
Examples:
Problem: Car fuzzes with Lilac/Team Purple fronts and car starts pushing.
Solution: Use a softer front tire and or different family of foam. Replace it with Blue or Double Blue front.
Problem: Car loses rear bite 6 minutes into the run. Blue rear tires look almost clean but have small carpet hairs.
Solution: Use Green rear tires. The softer compound wears instead of getting sticky, minimizing fuzz.
Tire Selection:
Starting out, pick 2 tire compounds for the front and rear. The following should have you covered 99% of the time.
Front - Green and Blue (BSR) or Green and Light Blue (JFT)
Rear - Blue and Double Blue (BSR) or Blue and Dark Blue (JFT)
You may wonder about other compounds out there and if they might be better, trust me, they probably won't be. Even if there are other tires that can be as fast, the synthetic family wears out really fast and the high natural rubber will probably fuzz on you over an 8 minute run. The blends family seems to be the most versatile foam type available today. They last awhile, and sticking to them will make your process of tire selection simpler.
Tire Charts:
BSR/CRC/Jaco
Contact
Corally
JFT (Japan Foam Tire)
Ulti
Enneti (Xceed)
ELECTRONICS:
ESC:
As of now, ROAR is staying 1S (3.7V nominal; 4.2V fully charged) for 1/12. There are many 1S ESC's with a built in BEC so nothing else is required to power the receiver and servo.
If you don't want to lock yourself into a 1S specific ESC, you do have other options! It is possible to use your 2S ESC without a booster or receiver pack, and the ESC simply supplies the lower voltage. If that does not appeal to you, you will need to use an Rx pack or booster. The Rx pack and booster will both supply the receiver with a higher voltage than the 1S pack.
If you decide to use an Rx pack, MAKE SURE TO REMOVE THE RED WIRE FROM THE ESC PLUG THAT GOES INTO THE RECEIVER!!!
If you choose to use a voltage booster, it works exactly how it sounds. Instead of plugging the ESC into the receiver, it plugs into the booster, and the booster plug goes to the ESC, supplying the higher voltage.
1S ESC:
If there are any missing please add them!!
If anyone would like a need for a chart comparing the ESC's specs PM fenton06 and I'll get one made and put in here!
Voltage Boosters:
Servos:
BODIES:
Black Art (CRC - US Dist):
  • Audi R8C - BA002 - .020 Thick
  • Black Market (Mohawk 12) - BA005 - .020
  • Lola B10 - BA006 - .020 thick
  • Toyota TS030 - BA008 - .020 thick
    Lola - black/red, TS030 - green/pink
PROTOForm:
Reflex Racing/RSD:
SUSPENSION ADJUSTMENTS:
Print Wikipost
Like Tree8Likes
Old 12-12-2006, 01:08 AM   #22426
radio_car_racer's Avatar
Originally Posted by protc3
the new prototype
Jason
is the chassis milled on the underside to allow the cell tape to sit flush with the chassis just like the other BMI 12th I have? It's the best bit of detail by far on any 12th out there
Any chance of a Team car for the UK as I'm the only 1 over here running BMI 12th @ the mo
radio_car_racer is offline   Reply With Quote
Old 12-12-2006, 02:30 AM   #22427
asw7576's Avatar
Can this minimize glitching ?
Or I should use bigger capacitor instead ?
Old 12-12-2006, 04:11 AM   #22428
protc3's Avatar
Originally Posted by radio_car_racer
Jason
i will be making the tape slot in the bottom of the chassis.send over a resume to the shop and i will see what i can do for you buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-12-2006, 07:21 AM   #22429
Send a message via AIM to aoizip
Jason,
Will you be able to make different thickness of the L-plate for the new car also?
Thanks,
~Ming
aoizip is offline   Reply With Quote
Old 12-12-2006, 08:46 AM   #22430
RCSteve93's Avatar
I use the Spektrum version. It is big, but when I use it I notice that total control of the car is much smoother. Also I have never glitched with it.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 12-12-2006, 08:55 AM   #22431
RCSteve93's Avatar
Does anyone know of a company that makes an low profile old school front end, that would let me cut my tires really low.
rm -rf /windows
Old 12-12-2006, 09:47 AM   #22432
hi all,
i just bought a 12l3 to start out with. does anyone know of a webpage that specializes in the 12l3? any info is greatly appreciated!
adam
adam lancia is offline   Reply With Quote
Old 12-12-2006, 10:00 AM   #22433
the best way to do it (if you want to run REALLY small tires) is to purchase an AE offset steering block for the dynamic strut front end and grind down the top untill it fits in-between the e-clips. I am running it and I can run on rim and still make ride height
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 12-12-2006, 10:25 AM   #22434
RCSteve93's Avatar
Sorry, but I am seriously confused.
rm -rf /windows
Old 12-12-2006, 10:32 AM   #22435
lol, okay
buy these-
http://www2.towerhobbies.com/cgi-bin...?&I=LX3141&P=7
they come in at about 10mm high
the ones you are using right now should measure about 9.6mm high (at least thats what mine did)
you want to grind off the top of the offset steering block untill it is 9.6mm high, or so that it will fit snugly between the two e-clips on the kingpin.
www.freerice.com
Old 12-12-2006, 11:34 AM   #22436
RCSteve93's Avatar
lol, okay
buy these-
Thanks for clearing it up. I see what you did, and I have those blocks on my car. I also realized I had them flipped.
rm -rf /windows
Old 12-12-2006, 11:45 AM   #22437
no problem. you will need to add some spacers under the ball stud to get rid of bump steer when you start running the tires really small.
www.freerice.com
Old 12-12-2006, 01:07 PM   #22438
RCSteve93's Avatar
It works awsome now.
rm -rf /windows
Old 12-12-2006, 01:50 PM   #22439
wingman2's Avatar
Hi all,
I thought I'd let you know that I tried a couple of fans on the cells of my C12 on Sunday to see if they would keep the overall tempreture down inside the car during a run. At the end, the cells were not even warm and the motor was a lot less hot than usual.
With heat being a big problem with modern cells and motors I though is was worth a go!
Also, just to let you know that I hooked BOTH fans up to a 6v 150mAh RX pack and it lasted for 25 minutes so during a 8 minute run, they probably only draw about 60 mAh which is nothing when you have 42/4300 to play with!
Cheers all, Chris.
1/12 forum-dscn4065.jpg   1/12 forum-dscn4064.jpg
wingman2 is offline   Reply With Quote
Old 12-12-2006, 02:18 PM   #22440
Express North-South Shoot-Out - Horsham R/C
Stock 1/12 A-Main
1 2 Mark Strasnick 38 00:08:09.649
2 1 Mark Smyka 38 00:08:10.101
3 7 Brandon Hess 36 00:08:00.788 - DARKSIDE Mx2
4 3 Jason Schreffler 36 00:08:05.855
5 5 Sal Amato 36 00:08:08.724
6 4 Andrew Smith 36 00:08:12.568
7 8 Ralph Morella 35 00:08:06.754
8 10 Vito Catalfamo 35 00:08:17.924
9 9 Steve Walter 34 00:08:02.362 - DARKSIDE Mx2
10 6 Greg Fangonil 34 00:08:04.119
Darkside Mx2, Coming to an A-main near you........
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
