Old 02-07-2010, 12:40 PM   #1
Default Tamiya Launch TB03-ifs R chassis
don't know if anyone was aware...?
tamiya item number 84109 look at their website for more details...
Tamiya is proud to release this version of the TB-03R which comes loaded with $291.25 worth of Option Parts, making it a great value. Once assembled, you will be able to experience first hand how the Option Parts will improve the performance of your machine.
Included Option Parts
1. Item 54099 TB-03 Carbon Reinforced K Parts (Stiffener)
2. Item 51333 TRF416 E Parts (Rear Upright)
3. Item 51332 TRF416 C Parts (Front Upright)
4. Item 54123 TB-03 Carbon Reinforced M Parts (Damper Stay)
5. Item 54098 TB-03 Carbon Reinforced A Parts (Gear Case)
6. Item 53928 Short Reversible Suspension Arm
7. Item 42102 TRF Special Damper (Hard Black Coating) 4pcs.
8. Item 54078 44mm Swing Shafts
9. Item 54077 44mm Lightweight Rear Swing Shafts (Blue)
10. Item 54067 TB-03 Suspension Mount (1XA)
11. Item 53500 Cross Joint for Assembly Universal Shaft
12. Item 51000 Hi-Torque Servo Saver (Black)
13. Item 53471 Medium Narrow White 5-Spoke Wheels (0 Offset).
14. Item 53642 5mm Aluminum Ball Connectors (Blue) 10pcs.
15. Item 53640 5mm Aluminum Ball Nut (Blue) 10pcs.
16. Item 53539 5.5mm Aluminum Spacer Set
17. Item 53823 Clamp Type Aluminum Wheel Hub (5mm Thick)
18. Item 49473 Hard Coat Aluminum Pinion Gear (22T)
19. Item 53963 TRF511 Stabilizer Set
20. TB-03R Chassis Kit Aluminum Front Damper Mount (Tentative)
Specs & Features
1/10 R/C assembly kit.
Body not included (sold separately). Compatible with TT-01, TB-03, and TA05 bodies.
Medium Narrow White 5-Spoke Wheels (0 Oset) included.
Urethane bumper included.
Tires, Motor, 2-channel R/C system, ESC, and Tamiya Battery Pack sold separately.
Recommended Tires for Winter: Item 53433 Medium-Narrow Tires Type A, Summer: Item 53705 Reinforced Tires Type B3 (24mm Width).
Jamie24 is offline   Reply With Quote
Old 02-07-2010, 12:45 PM   #2
linky link
but $450 rtl price ?!?!?!?!?
sidecarphil1 is offline   Reply With Quote
Old 02-07-2010, 12:51 PM   #3
That's MSRP.
Figure a $300 street price.
jiml is offline   Reply With Quote
Old 02-07-2010, 01:15 PM   #4
does anyone know what the blue alu link is between the rocker arms? is it a stiffner?
if so, anyone got a part number as will get one for my TA05-ifs R
they never retail at the retail prices so i expect it to be arround the $300-$380 mark
but there are a load of hop ups still needed for it... so you could end up spending $500+
SEO by vBSEO 3.5.0
