Old 03-22-2013, 08:53 AM   #676
theatriks's Avatar
Thanks guys ......raceberry doesnt have a site up yet huh?
theatriks is offline   Reply With Quote
Old 03-22-2013, 10:20 AM   #677
Matthijs's Avatar
no, it's kind of a secret, special, high tech company with a low profile, we don't want just anybody using these parts and as a result being just as fast The latest results from the TRF-guys speak for themselves
but you can contact him on http://www.facebook.com/home.php?#!/...332601?fref=ts
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 03-22-2013, 07:22 PM   #678
theatriks's Avatar
Lol I don't do Facebook ....is race berry a secret agent too lol
Old 03-23-2013, 02:16 PM   #679
Yes men in black styleeeee
We could tell you his name but then we have to kill you
sidecarphil1 is offline   Reply With Quote
Old 03-23-2013, 04:12 PM   #680
theatriks's Avatar
No don't tell me then lol....but could you tell him to get a site up already .
Old 03-24-2013, 10:17 AM   #681
Matthijs's Avatar
in a few weeks his stuff will be sold by Tonisport, until then you can contact Bernd at raceberry(at)web.de
Old 04-22-2013, 02:09 PM   #682
theatriks's Avatar
Ok asphalt season starts up here next race ...thank god ....it was a tuff winter/carpet season with this car.......so im guessing most guys are using chris setup from hemstead?......i modified my rear bulk heads and cut off the extra mounts that vasco suggested...i wonder if i should go back to the un modified ones for asphalt.......i remeber last summer this car was amazing just box stock on pavement.
Old 04-23-2013, 02:19 AM   #683
this is what i am running at the moment
Front
C C out with short arms
0mm spacer under front block 0.5mm under rear block
550 oil HPI pink springs 3rd hole from inside at the top of the shock
medium links with 3mm spacers
1.5mm ackerman
Rear
B out front E out rear
0.5mm spacer under the blocks
550 oil HPI silver springs 3rd hole from inside at the top of the shock
medium link with 2.5mm spacers
600 geardiff oil
1 piece rear/front suspension holder only using outer holes(raceberry) floating servo mount
TF6 top deck
Old 04-23-2013, 11:57 AM   #684
Registered User
Send a message via MSN to Vasco C
I would suggest sticking to the modified ones. The new prototype chassis feature holes for front bulkheads in rear.. The difference however shouldn't be that big, just a little more flex..
Setup wise I'd recommend basically what Phil says as a starting point, apart from the 0 - 0.5mm shims underneath the front pivot blocks.. run 0.5-0.5, the anti dive only works on certain tracks.
I'd start with HPI silver/silver since this is 90% of the times the way to go, pink/silver is not always the best option out there.
I've included a basic setup that should work at nearly every track/surface.
Furthermore I'm happy to tell you guys that Kyosho is working hard on putting an 'upgrade' kit together. This kit will most likely include the new steel axles/outdrives, floating servo mount, solid piece suspension block(s), new topdeck and maybe a few other nice goodies. I can't tell you the exact specifications or release date yet since this is still unknown. Ofc I'll try my best to keep you all updated!
I've been driving around with all the new prototype bits for quite a while now and have to say that they work amazingly well! We made a lot of progress on carpet but on asphalt the car is outstanding!
Vasco C is offline   Reply With Quote
Old 04-23-2013, 12:52 PM   #685
theatriks's Avatar
Thanks vasco ..sidecarphil.....i will try this out !...and yes the car is definately outstanding on asphalt.....cant wait to see the new goodies!
Old 04-23-2013, 01:14 PM   #686
theatriks's Avatar
Wouldnt the tf-005h arms work better on asphalt?
Old 04-23-2013, 01:22 PM   #687
Registered User
Don't know the part nr's to be honest, but the 'short' original TF6 arms work best in pro-stock most of the time.
Old 04-23-2013, 01:32 PM   #688
theatriks's Avatar
Ok ya got ya there but im gonna run this car in mod so i will give both arms a try.
Old 04-29-2013, 08:54 AM   #689
Matthijs's Avatar
Last sunday the Dutch Nationals were dominated by John 'Kiwi' Bruins with the TF6 SP in the stock (sp cirtix and 13.5 v3) class. Outstanding performance and a good warmup for the next ETS race on the same track ;-)
Old 05-01-2013, 01:49 PM   #690
Anyone know when the updates and prototype parts might be available for the TF6 SP??
Freddie_Skoda is offline   Reply With Quote
SAFRA S'pore International R/C Championships, presented by HPI Racing, 4 - 6 Apr 08 Race Academy Singapore R/C Racers 156 04-08-2008 10:11 AM
kyosho tf-5 belt drive T Lawrence R/C Items: For Sale/Trade 22 04-03-2007 07:19 PM
Which is The best Shaft Touring Car:Kyosho TF-5, Yokomo LCG, Tamiya EVO 5, HPI Pro 4? yyhayyim Electric On-Road 13 07-03-2006 07:48 PM
SEO by vBSEO 3.5.0
