Old 05-28-2010, 02:03 PM   #46
encore75's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to encore75
I like the design of the CVD ends/diff outdrives...pretty trick. Should distribute the load better and reduce the need to change out outdrives so much from gettting chewed up by the traditional single-pin dogbone end.
Tamiya TB-Evolution V & TA05-R | Kyosho Ultima SC & RB5 | Associated FT RC18T
encore75 is offline   Reply With Quote
Old 05-28-2010, 02:06 PM   #47
Registered User
Send a message via MSN to Vasco C
YR4Dude,
Removing the topdeck in order to take the layshaft out is not that big of a deal I think. The way the bulkheads are right now is the best solution for proper flex.
Hebiki,
I think that the car still has cell holes in the plate is due to the fact that they are still using cells in Japan at some races. The chassis is optimised for lipo though, the car is perfectly balanced and the lipo holder works flawless. I actually like the chassis to be a little bit wider, this way your lipo won't touch the asphalt and will stay in perfect shape.
Maybe Kyosho will create a lipo only chassis, but there is not really a reason to do so.
The car can be bought from the Kyosho online shop. I think stores in HongKong will also have the new kit.
The drivetrain works flawless indeed. Very very smooth and can't see any sign of wear on the outdrives/axles. The pin that goes trough the driveshaft is also a little longer then the thickness of the axle, this reduces wear too. It's all in the details
Vasco C is offline   Reply With Quote
Old 05-28-2010, 02:14 PM   #48
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Hebiki View Post
Vasco..thanks for posting. great support from you. too bad this car wont be supported (from what ive been reading on this thread) in the US.
one question.. why no lipo chassis?
I've heard that both Asia and Europe are still using Nimh sub-Cs for 5-cell races. Hence the reason why there are still chassis cut out for sub-c's.
Also Chris take a closer look at that picture and notice the size of the spur and pinion. It looks like they haven't gotten into the variable timing speedos yet.
YR4Dude is offline   Reply With Quote
Old 05-28-2010, 02:17 PM   #49
Registered User
Europe is all Lipo as far as I know.
We had to use handout speedo at the ETS. No timing indeed. Normally I'm using GM speedo with variable timing obviously.
Old 05-30-2010, 03:19 AM   #50
Pro10noob's Avatar
YR4Dude?
The reason for the spur and pinion size is that that they used a speedy/motor combo with a fixed timing to get as much close racing as possible.
It was tested at the ETS at Heemstede and most of the drivers where very happy with it and told everybody that this was stock racing as it should be.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 05-30-2010, 06:36 PM   #51
YR4Dude's Avatar
Originally Posted by Pro10noob View Post
YR4Dude?
regards Roy
Roy,
That is something we've only started trying to get here. However, it has not been so popular and participation has been somewhat spotty even despite Novak Electronics offering to help support such a class by offering a low cost ESC & motor combo. The fixed motor timing class still hasn't caught on.
Old 06-27-2010, 11:31 AM   #52
Hi,
whether somebody knows perhaps what parts (c-hubs etc.) it is worthwhile having on service stock??
Szymon Niebora is offline   Reply With Quote
Old 06-27-2010, 01:43 PM   #53
anybody know?
Old 06-29-2010, 04:43 AM   #54
Registered User
Personally I always make sure I have at least the following spares in stock;
- Front + rear wishbone
- Driveshafts ( + driveshaft balls! )
- Front and rear belt
- Chubs
- Steering knuckles
- Rear hubs
- Spool outdrives
- Spur gears
- Hingepins
Those are the main things to have in my opinion.
Old 06-29-2010, 11:49 PM   #55
JayBee's Avatar
Trader Rating: 31 (100%+)
Who distributes this car in the States???
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-29-2010, 11:51 PM   #56
Kyosho America is the US distributor but they are not bring this car into the states...
Kody is offline   Reply With Quote
Old 07-21-2010, 10:21 AM   #57
RC MARKET's Avatar
http://rcmarket.com.hk/product_info....oducts_id=8996
RC MARKET is offline   Reply With Quote
Old 07-21-2010, 11:46 AM   #58
Hebiki's Avatar
Originally Posted by RC MARKET View Post
wow.. $534
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-21-2010, 12:33 PM   #59
YR4Dude's Avatar
wow.. $534
Go get one Chris.
That way I can buy it off of you in 6 months for 1/2 price.
Old 07-21-2010, 12:38 PM   #60
Trader Rating: 15 (100%+)
Send a message via AIM to DJGonzo69
Saw one of the guys at my local track running this car. It looked pretty solid.
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
SAFRA S'pore International R/C Championships, presented by HPI Racing, 4 - 6 Apr 08 Race Academy Singapore R/C Racers 156 04-08-2008 09:11 AM
kyosho tf-5 belt drive T Lawrence R/C Items: For Sale/Trade 22 04-03-2007 06:19 PM
Which is The best Shaft Touring Car:Kyosho TF-5, Yokomo LCG, Tamiya EVO 5, HPI Pro 4? yyhayyim Electric On-Road 13 07-03-2006 06:48 PM
