Old 10-11-2012, 08:39 AM   #526
Registered User
Originally Posted by Matthijs View Post
ready for some indoor carpet racing!
What's the part number for the shorter uni?
oosh123 is offline   Reply With Quote
Old 10-11-2012, 09:42 AM   #527
theatriks's Avatar
here you go
Originally Posted by dontfeelcold View Post
http://banzaihobby.com/radio-control...p-up-parts/tf6
In regards to the parts TFW114 and TFW115, the pics are the same but the lengths are different.
Is one for the front and one for the rear?
correct and you need the TF242-02 (wheelshaft) & TF242-03 (joint block) to make it complete (for each universal)
theatriks is offline   Reply With Quote
Old 10-11-2012, 09:51 AM   #528
theatriks's Avatar
i think the kit comes with 2 tfw-03 am i right so i would only need to order 2 more ?
Old 10-11-2012, 10:40 AM   #529
Matthijs's Avatar
correct, if you already have the Alu uni's from the TF6sp kit you can use those and the new steel axle ( 2 x TFW114). For the rear you need
2x TF242-02 (wheelshaft) &
2x TF242-03 (joint block) &
2x TFW115
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 10-11-2012, 11:07 AM   #530
theatriks's Avatar
2x TFW115
LOL your looking at 130 bucks for this stuff....
Old 10-11-2012, 12:32 PM   #531
Registered User
2x TFW115
I saw the manual and the shaft is a 41 mm long for the front.
Does that mean I can use the 37.5 mm for the front so that it can fit a diff with C-C block facing inside?
Old 10-11-2012, 01:24 PM   #532
theatriks's Avatar
2x TFW115
Ok so spent the 130 lol ...also you think kyosho will come out with a floating servo mount?
Old 10-11-2012, 02:45 PM   #533
Matthijs's Avatar
what is that? you meane a piece of aluminium bolted on the chassisplate and adding some play and room to your servo and steering system?
I really don't know, I've got my servo mounted with tape and the support on the outside, works fine!
Old 10-11-2012, 03:06 PM   #534
theatriks's Avatar
LOL ! Ok so you dont bolt down your servo on the inside mount ? you just bolt it in the outside mount and double side tape it?
Old 10-11-2012, 11:28 PM   #535
Matthijs's Avatar
correct! If you really want a bulletproof driveline you can use the steel outdrives. For the spool 2x TFW112, for the geardiff 2x TFW009. If your using the car outside on a dusty track I recommend using an Durango driveshaft outdrive boot set (TDR310022), keeps dust and dirt away!
Old 10-12-2012, 10:07 AM   #536
Registered User
Send a message via MSN to Vasco C
Bolting the servo either on the inner or the outer post doesn't really matter as long as you only use one. No real need for a floating servo if you do it this way..
Vasco C is offline   Reply With Quote
Old 10-12-2012, 10:49 AM   #537
theatriks's Avatar
beauty advice guys ..thanks!
Old 10-12-2012, 03:32 PM   #538
drove my TF6SP on our tight small indoor track tonight all i can say is
FANTASTIC it has so much steering and rear grip
Think i come to MACH and teach you how to drive Matthijs
sidecarphil1 is offline   Reply With Quote
Old 10-12-2012, 11:21 PM   #539
Matthijs's Avatar
you're on! ;-)
Old 10-13-2012, 03:31 AM   #540
Matthijs's Avatar
pic with the outdrive boots on ;-)
SAFRA S'pore International R/C Championships, presented by HPI Racing, 4 - 6 Apr 08 Race Academy Singapore R/C Racers 156 04-08-2008 10:11 AM
kyosho tf-5 belt drive T Lawrence R/C Items: For Sale/Trade 22 04-03-2007 07:19 PM
Which is The best Shaft Touring Car:Kyosho TF-5, Yokomo LCG, Tamiya EVO 5, HPI Pro 4? yyhayyim Electric On-Road 13 07-03-2006 07:48 PM
SEO by vBSEO 3.5.0
