Old 09-18-2012, 12:54 AM   #496
Matthijs's Avatar
Originally Posted by Arn0 View Post
In case, someone can be interested, editable setup sheet for TF6SP available on petit
nice, great info as always. thanks for the sheet!
and welcome to KIWI!
I've moved into my new house and finally have some time to check this thread again After I get all my hobbystuff unpacked it will be time for the indoorseason!
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 09-18-2012, 01:29 AM   #497
Registered User
Send a message via MSN to Vasco C
About the knuckle spacer:
When running it high or low you're changing the mounting position of the wheel compared to the rear axle. This effects your droop settings which eventually give your car more steering when running it in the lowest position (shim on top of the steering knuckle), or gain more stability/corner speed when running it in high position (shim on the bottom of steering knuckle).
Vasco C is offline   Reply With Quote
Old 09-20-2012, 02:34 PM   #498
John_B's Avatar
Hey there everyone!! Thanks a lot for all the nice words and welcomes, feeling at home already . In the coming weeks, and future, i'll try and keep you all posted as to how everything's going with the build, tips, tricks and ofcourse the racing. If you have any questions or remarks, on and off the track, don't hesitate to ask and i'll help out in the best way possible.
John_B is offline   Reply With Quote
Old 09-20-2012, 03:50 PM   #499
theatriks's Avatar
am i the only one in here not sponsored by kyosho lol....gotta call kyosho lol...anyways love that im getting advice by some pro drivers....hope you guys like a lot of questions lol
theatriks is offline   Reply With Quote
Old 09-23-2012, 02:17 PM   #500
i aint sponsored by kyosho either
not yet good enough to beet Vasco
sidecarphil1 is offline   Reply With Quote
Old 09-30-2012, 01:56 PM   #501
theatriks's Avatar
hey guys quick question....im not sure if this is mistake in the SP manual or not but when assembling the center bulkhead on pg11 ...number 9 the small aluminum L piece rite at the front of the motor mount where the 2 screws go through.....its not showing to put a screw in from under the chassis but theres threads and a hole for a screw.....should this be secured to the chassis(i would think) or is there a reason not to screw it down thats why there not showing you too ?
Old 09-30-2012, 07:40 PM   #502
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
I was told to put a button head screw through the top so that it just poked into the hole in the chassis. I guess just to stop the motor mount from moving but allowing the chassis to flex.
Using a screw there will stiffen the chassis up and can be a point where the car will tweak if its not assembled properly.
dontfeelcold is offline   Reply With Quote
Old 09-30-2012, 07:49 PM   #503
http://banzaihobby.com/radio-control...p-up-parts/tf6
In regards to the parts TFW114 and TFW115, the pics are the same but the lengths are different.
Is one for the front and one for the rear?
Old 09-30-2012, 11:06 PM   #504
Matthijs's Avatar
correct and you need the TF242-02 (wheelshaft) & TF242-03 (joint block) to make it complete (for each universal).
Old 10-01-2012, 02:17 AM   #505
Cool, thanks for that.
Old 10-01-2012, 07:16 AM   #506
theatriks's Avatar
are you guys using cvds in the rear?
Old 10-01-2012, 09:17 AM   #507
Matthijs's Avatar
Haven't installed them yet, indoor season starts next week I think Krissi used them at the worlds.
Old 10-01-2012, 09:19 AM   #508
theatriks's Avatar
i must be confused ...how does using cvds in the rear help any?
Old 10-01-2012, 11:15 AM   #509
Matthijs's Avatar
super smooth driveline, less friction with 3 degrees toe-in, steel axles all around and if that doesn't help, it sure will help in our minds to have the newest cool stuff ;-)
Chrissy's car:
Old 10-01-2012, 11:32 AM   #510
theatriks's Avatar
Some guys are here were telling me to use the 2mm tf6 top deck ..which im gonna try.....but i guess christopher doesnt do it that way.
SAFRA S'pore International R/C Championships, presented by HPI Racing, 4 - 6 Apr 08 Race Academy Singapore R/C Racers 156 04-08-2008 09:11 AM
kyosho tf-5 belt drive T Lawrence R/C Items: For Sale/Trade 22 04-03-2007 06:19 PM
Which is The best Shaft Touring Car:Kyosho TF-5, Yokomo LCG, Tamiya EVO 5, HPI Pro 4? yyhayyim Electric On-Road 13 07-03-2006 06:48 PM
