Old 09-01-2012, 08:11 AM   #466
theatriks's Avatar
Whats the tranny ratio on the sp i cant find it anywhere in the manual?
theatriks is offline   Reply With Quote
Old 09-01-2012, 02:34 PM   #467
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Originally Posted by theatriks View Post
Alright just finished the build took me 5 hours .....your rite i did use a mix of shock tops ....so thanks for the heads up.....what are the cvds that came in the kit aluminum?
Yes mate the kit is aluminum the streek ones are you just about to be relased
internal ratio is 1.83
Here are some setup sheets..
http://www.petitrc.com/reglages/kyos...KyoshoTF6.html
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 09-02-2012, 03:31 AM   #468
Registered User
Send a message via MSN to Vasco C
Another quick tip when building the shocks:
According to the manual you have to use two special rubber shims on the bottom of the shock to keep it from leaking. I prefer to use one rubber shim and one 1.5mm regular aluminum one for smoother shock operation. Seen from the piston side of the shock shaft its piston - rubber shim - alu shim - shock end cap.
Another helpful trick to get rid of shock rebound easily is to drill a 1mm hole in the top plastic shock cap so the air between the bladder and the cap can get out when (re)building.
Have fun with your new kit
Vasco C is offline   Reply With Quote
Old 09-02-2012, 01:25 PM   #469
theatriks's Avatar
Thanks for the tips boys......Well heres a quick rundown .....got the kit thursday night...built it friday...installed the electronics saturday....WON the A-main with it on Sunday in 17.5 spec class....do i like my kyosho hmmm let me think
Old 09-02-2012, 04:38 PM   #470
Me_MrTyson's Avatar
Sounds like another Happy driver
Are you racing indoors or outdoors?
Old 09-02-2012, 05:36 PM   #471
theatriks's Avatar
I was racing on freshly paved ashphalt...had some nice in field chicanes and the car transitioned beautifully through them.
Old 09-03-2012, 07:40 AM   #472
theatriks's Avatar
Quick question ....are the kit supplied a arms tf-005h the carbon reinforced or just regular plastic ones.
Old 09-03-2012, 10:57 AM   #473
Registered User
Quick reply: carbon
Old 09-03-2012, 11:02 AM   #474
Originally Posted by Vasco C View Post
Quick reply: carbon
and if it was a slow reply would the answer be the same ????
makes a change for you to be quick !!!!!
sidecarphil1 is offline   Reply With Quote
Old 09-03-2012, 12:14 PM   #475
theatriks's Avatar
Quick reply: carbon
Im curious to see what you guys think about a convo i had with a fast racer at my local track...his preference was the plastic a-arms being that they may flex a bit more ....i personally think you wouldnt be able to notice a substantial difference between the too other then strenght under impact.
Old 09-04-2012, 12:36 AM   #476
Registered User
You will notice a rather huge difference! Back in the days when I drove with the Yokomo BD-5 we started out with plastic suspension as it came with the kit. Switching to a carbon suspension made the car much more responsive to setup changes and way more precise to drive. Especially in high traction conditions..
Old 09-04-2012, 09:28 AM   #477
theatriks's Avatar
ok cool im gonna get a spare set of the long and short arms just too experiment ....should i bother getting the tf6 chassis or just stick with the sp chassis for carpet?
Old 09-04-2012, 10:09 AM   #478
Registered User
SP chassis - TF6 upperdeck
Old 09-04-2012, 10:24 AM   #479
theatriks's Avatar
Thanks dude and i appreciate the fast responses ...awesome thread!
Old 09-04-2012, 10:29 AM   #480
Registered User
Anytime
For pro-stock use short suspension instead of the long one (tarmac and carpet)
SAFRA S'pore International R/C Championships, presented by HPI Racing, 4 - 6 Apr 08 Race Academy Singapore R/C Racers 156 04-08-2008 09:11 AM
kyosho tf-5 belt drive T Lawrence R/C Items: For Sale/Trade 22 04-03-2007 06:19 PM
Which is The best Shaft Touring Car:Kyosho TF-5, Yokomo LCG, Tamiya EVO 5, HPI Pro 4? yyhayyim Electric On-Road 13 07-03-2006 06:48 PM
