Old 10-17-2011, 06:11 AM   #181
Matthijs's Avatar
really nice pictures, should be a super combo with the Orion stuff You didn't get the lipo chassis and geardiffs?
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 10-17-2011, 06:18 AM   #182
John Doucakis's Avatar
Thanks.
I should get them in the next few weeks.
I will run it only after I get them, otherwise there is no point comparing it against a fully optioned TCX.
John Doucakis is offline   Reply With Quote
Old 10-17-2011, 11:11 AM   #183
Matthijs's Avatar
here is mine, we are racing stock with speedpassion stuff, otherwise I would mount my Orion esc+motor, just for the looks
1st race this weekend indoor on carpet, can't wait!!
Old 10-17-2011, 12:32 PM   #184
Narrow chassis, gear diff, aluminum and titanium fasteners, aluminum turnbuckles, very nice! I like the black lead weights, nice attention to detail.
For a full Team Orion set up you may have a look at my HB TCX in my blog. The same equipment will be moved over to the TF6 eventually.
Just in case you guys have not seen it, this is Shin's car from a recent exhibition carpet race where Andy Moore, Atsushi Hara, Surikarn and other top drivers also participated:
KKChung gallery
Old 10-17-2011, 01:18 PM   #185
Great to see how others do the small details. I just love looking at those pics.
I see a lot of talk of gear diffs. What are the advantages of a gear diff vs a ball diff? What are considered the "right" choice of diffs for a small technical, carpeted indoor track? Gears front and rear, balls front and rear or maybe a combo? What kind of tracks are the solid front axle meant for?
Tom
Kyosho all the way!
TomEG is offline   Reply With Quote
Old 10-17-2011, 11:11 PM   #186
Matthijs's Avatar
Tom
I run the gear diff in front and rear. A geardiff in the rear gives you less slip and les maintenance and more tuning options (oil between 700 and 2000). In the front I run the spool (solid axle) and lately the gear diff with 500.000 oil in it. Acts like a spool but with a very little slip to protect you driveshafts and some extra turn in.
For a tight indoor on carpet I would choose between:
rear: balldiff and front: spool
rear: geardiff and front: spool
rear: geardiff (800 oil) and front: geardiff (500.000 oil)
Haven't tested al those options on carpet yet, I started with the geardiffs in rear and front and really liked it sofar.
I've included my setupsheet, I've made some changes last sunday that are not in this sheet but still don't know if it's faster or more stable so this should be a good starting point ( I tried sending it on facebook to you, but it bounced).
File Type: pdf TF6_setup_MACH_indoor_Matthijs_Jansen.pdf (406.8 KB, 100 views)
Old 10-18-2011, 01:31 AM   #187
Thanks Matthijs, I'll start out with the spool up front and the balldiff at the back. I will order a couple of geardiffs, so I can experiment a little.
Tom
Ps. I have no idea why the facebook message bounced...... But thanks for posting it here.
Kyosho all the way!
Old 10-19-2011, 08:43 AM   #188
Registered User
Send a message via MSN to Vasco C
Matthijs,
Try this:
Run a shorter camber link at the rear end ( middle pos ) for better cornerspeed/reaction. The longest option is better suited for big, flowing outdoor tracks.
Thicker shock oil ( 500wt all around )
3mm underneath front camber link instead of the 2,5 you have now
Dampers bit more upright all around.
CS high grip additive
Maybe 0.5 all around underneath suspension blocks for a bit more traction..
Vasco C is offline   Reply With Quote
Old 10-19-2011, 11:03 PM   #189
Matthijs's Avatar
Originally Posted by Vasco C View Post
Matthijs,
Try this:
thanks Vasco, I've been playing with springs last evening, switching between the HPI gold/silver and Tamiya white/blue, can't decide yet. Also a thinner stabi at front/rear(1.2 / 1.0), but went back to stock (1.4 / 1.2).
As I'm pushing more, the rear is loose on corner exit. Bart W. and Steven K. tried a few laps and likes the steering and roll, but on power, the rear is a bit twitchy. I'll try the shorter linkage and dampers more upright. Already got the front camber link higher. Have to change oils to, maybe lighter in the diff (700) and thicker in the shocks (500).
Old 10-19-2011, 11:56 PM   #190
Pro10noob's Avatar
Mathijs?
Perhaps cleaning putty in the front gear diff will settle the car more down.
Also what Vasco said about the shocks and camber links.
Or if possible make the rear of the car a bit more narrow?
This would also calmb the car down
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-20-2011, 12:35 AM   #191
Matthijs's Avatar
Originally Posted by Pro10noob View Post
Mathijs?
regards Roy
mmm, not looking forward for cleaning out my front diff I'm rebuilding the car this week, maybe a test on saturday otherwise racing on sunday! If I can make it saturday I'll try the spool in front.
Old 10-20-2011, 12:58 AM   #192
Pro10noob's Avatar
Do you run 4 or 5MM hexes at the rear?
If 5 try switching to 4 to narrow the car a bit.
I had to identical cars running the same setup besides the rear suspension block(no unfortionatly no Kyosho).
Drove them both on the same circuit with same ESC settings and same motor.
One had a loose rear and and the other was planted as concrete.
Looked at the rear and and found out that i had a difference in the rear track width of about 3mm.
The narrower car was better in corners and was very good at onpower corner exit.
It had just a little bit less turn in then the wider car.
Perhaps this is something to try before you disassemble the whole car?.
regards Roy
l===/o\===l
Old 10-20-2011, 02:41 AM   #193
Registered User
Raising the front camber links to 3.0 instead of 2.5 will make the car more stable throughout a corner. With the current setting the rear is higher then the front, that makes the car kinda "dive" in corners.
You can also try running C ( FF ) and E ( FR ) to widen up the rear a bit, this will also improve the rear traction/stability of the car.
A very small but important detail: Make sure your front belt is set a little bit tighter then your rear belt. This way the front of the car will start accelerating first out of the corner before the rear end kicks in.. Will also provide more stability on power.
As for springs, I run HPI springs for 90% of the occasions. Mostly pink-silver or gold-silver. When running Tamiya springs I use white/blue.
Hope this helps you out
Old 10-20-2011, 04:29 AM   #194
Matthijs's Avatar
you mean replacing those bushings in the front?
I'll change some things at a time, not all together ;-)
Old 10-20-2011, 04:38 AM   #195
Registered User
Ups... I ment RF and RR blocks... So change the rear of the car to C - E
SAFRA S'pore International R/C Championships, presented by HPI Racing, 4 - 6 Apr 08 Race Academy Singapore R/C Racers 156 04-08-2008 09:11 AM
kyosho tf-5 belt drive T Lawrence R/C Items: For Sale/Trade 22 04-03-2007 06:19 PM
Which is The best Shaft Touring Car:Kyosho TF-5, Yokomo LCG, Tamiya EVO 5, HPI Pro 4? yyhayyim Electric On-Road 13 07-03-2006 06:48 PM
