Sweep Racing Tires 1/10th Sedan thread >
Like Tree17Likes
Old 04-12-2016, 06:31 AM
  #706
Company Representative
SweepRacingUSA's Avatar
Reedy 2016 SPEC tires update:
New ETA: Apr/18/2016. we will post again once we have a confirmation.
SweepRacingUSA is offline
Old 04-18-2016, 09:13 AM
  #707
So far so good, we should be able to ship from today. thanks
Old 05-15-2016, 07:17 PM
  #708
Trader Rating: 27 (100%+)
The new Reedy 2016 Spec tires are money! Great performance over 10+ runs. A great starting option for asphalt racing.
MDawson is offline
Old 05-17-2016, 01:41 PM
  #709
DMD
DMD's Avatar
Default 👍🏻
Agree!
DMD is offline
Old 02-10-2017, 07:05 AM
  #710
Have a closer look at our STC-6 Body on the Black CRC Carpets.
Since most of the tracks switched to high traction Black Carpets, lowest possible CG designed STC-6 has been shine again!
To make it even better for serious racers, we just added Ultra light weight (0.5mm) to our US warehouse inventories.
NYC's Local racer, John Themelise switched to STC-6 Light weight to set all new track record at 360 raceway ( 2017 Carpet nats host)
Old 02-10-2017, 09:26 AM
  #711
DBM
Good to see you stocking these in North America now. I won't have to order them out of Asia anymore. The 0.5mm STC-6 body is my favourite body for 17.5 stock touring. Balanced and responsive. Out of all of the bodies that i have, the STC-6 is the most versatile, too.
DBM is offline
Old 03-02-2017, 05:36 AM
  #712
Default FTG
FTG. Front Tire Glue, made for today's hard working front tires. on or offroad, rubber or foam.
This glue stays intact, the perfect viscosity for the job and dries clear, comes with metal glue tips for precise diameter control of "Glue Ring" to create perfect handling machine.
Available at the US warehouse Mar/6/2017. Just in time for the Carpet ROAR NATS!
Old 03-02-2017, 06:24 AM
  #713
Timbulb's Avatar
I enjoy using our sweep spec tires here at our local series but they sure don't last very long on the new black carpet.
Timbulb is offline
Old 04-14-2017, 09:27 PM
  #714
5th wheel's Avatar
What would be a good tire
Asphalt track large in Florida hot track out side for racing or practice tire long life and insert?
Stock class 21.5 tc.like to try your tires out for the first time.
Thanks Jerry
5th wheel is offline
Old 04-15-2017, 10:44 AM
  #715
WE have the Black CArpet Special QTS32 ready. let us know if you need them, which needs less side wall gluing, long lasting blend.
thanks
Old 04-15-2017, 10:45 AM
  #716
Thanks Jerry
R40 should do it. for casual racing
Sweep Racing Tires TC SPEC TIRES BEST PRICE BEST TRACTION FREE SAME DAY SHIPPING.
for an serious compensation . EXP36
Sweep Racing TIres EXP36 EVO-R TC Tire
thanks
Old 04-15-2017, 10:47 AM
  #717
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by SweepRacingUSA
WE have the Black CArpet Special QTS32 ready. let us know if you need them. thanks which needs less side wall gluing, long lasting blend.
thanks
John.. are these the tires Donny had at the beginning of the season? Or is this something new??
hanulec is offline
Old 04-15-2017, 01:10 PM
  #718
miller tyme's Avatar
the Black are the ones we used at Champs
miller tyme is offline
Old 04-15-2017, 07:05 PM
  #719
5th wheel's Avatar
thanks
guess I ordered the wrong tire than I got the 36r and med insert from you.
Old 04-18-2017, 08:11 PM
  #720
Hello,
I'm joining the TCS this May and August is a class where we are free to use any tire inserts. Only thing is we are required to use Tamiya 26mm tires. Are there any Sweep Racing tire inserts I can purchase/use for this size tires? Can the EXP-S, EXP-M, EXP-C series of insert/s be used for 26mm tires being that they are slightly wider/thicker?
Thanks for all your help! =)
kokoyang is offline
