Sweep Racing Tires 1/10th Sedan thread
#661
Thx for your reply. You really didn't answer my question, but it appears the 30's have been discontinued and you will have a replacement soon. So that brings me to a follow-on question. I have seen some 28 marked tires in packages with a 30 label. Which tire is actually in the bag?
And related to your answer above, is the EXP EVo-R 36 compound going to run as well on our carpet as the old 30? I am sure there will be some difference, so what would the difference be?
EXP36 Evo-R, it should work if the carpet is grooved. but if track have less than mega gripz, you will need to wait for 30. we are going to have EXP30 Evo-r coming next week. please stay tuned.
Thanks.
Thanks I guess, on High to Mega bite tracks, 30-32 wont make so much difference.
#664
So now I see all QTS32 and QTS28 at our local HS. All are on white wheels, so they are for carpet. Is that part correct?
And all of these have the C-medium insert. Is it possible a different insert would work better at our track?
#665
Thanks again for your reply. So that means you have never made a mold for the 30 shore low profile tire. The split then is 28 to 32 to 36, or 4 points between tire hardness.
QTS 28 and 32 have all Med inserts, either Aqua or Black in color. it is possible some tracks runs better with different inserts, but QTS tires are designed for Spec racing. as long as everyone all have same tire/inserts/wheels, at least tire part is equal.
thanks
#668
Yes we are,
Until early of 2013, we were not the most favorite for GTE, then we went to work on our Tire compounds/inserts combo for a while to suit GTE better. feedback has been very positive from California drivers this year, where GTe are very popular over GTi
Please visit our GT8 dedicated forum for more information
Sweep Racing Tires 1/8th GT thread
#669
tire regimen
What's a good regimen(sauce, saucing technique) for these tires?
#670
These are specifically for asphalt?
#672
I do as Kody mentioned, then use simple green to clean them between runs. Great bite.
#673
#674
I purchased a Sweep STC4 lw body from TQRC and have put a few hundred laps on it so far. Compared to my lw GX body and lw LTCR body, the Sweep body seems to have a lot more steering. It feels (and looks) very much like the ltcr. I was hoping for more stability like the GX, but the rear felt more like the ltcr. Moving the wing back as far as I could helped a lot, but still not quite as planted in the rear as the GX. Since most people seem to find the rear of the GX too locked in, I think that most will like the ltcr will be very happy with the stc4.
My only complaint about the sweep body is of the quality of polcarbonate. It bends/creases and stays permanently deformed. ...it doesn't flex back like protoform bodies. I hope Sweep will consider changing to a different polycarbonate that doesn't permanently deform so easily.
#675
I've now used gravity tires, jaco blues, sweep rug racers, and sweep qts32's on our tight high traction carpet track. My fast lap is the same with all four tires, but I really prefer the sweep tires over the others. I'm WAY more consistent with the sweep this than the others. The jacos are floaty and vague, and the gravity tires are fast, but if you ever get a bit off line, they get covered in a huge amount of junk/fuzz, and are hard to get back. They also seem to have a much narrower temperature band than the sweeps. I think very good/experienced drivers (possibly with tire warmers) could get a lot more out of the gravity tires than me, though.
For now, I'm sticking with the sweep qts32's. I really REALLY like them.
