Like Tree7Likes
Old 04-14-2014, 08:12 AM   #646
Company Representative
SweepRacingUSA's Avatar
Originally Posted by Evo 13 View Post
SweepracingUSA,
Do you have any 26mm 30mm and 35mm wide 1/10 onroad rubber tires? IF so, whats the part #. I'd like to purchase the tires separate from the wheels if you have. Thanks in advance.
Hello
we only make 24mm width TC tires at this moment.
Originally Posted by DBM View Post
The new body looks great! I like the rounded edges..... should make for less drag.
I have a question about tires. I've been running the exp-qts "rug racer" tires, but will be switching to the qts32 WCICS spec tires soon. We are running on what I believe to be medium grip carpet. How much can I expect my lap times to be affected? Might I require any setup changes with the new tires?
Rug racers have more traction than QTS32, but QTS32 last longer with more consistnat lap times over diffrent temps. with a right set up machine not much diffrence in lap times, generally speaking, QTS32 need set up with more steering.
Originally Posted by alexrgz View Post
Hi Sweep guys I would like to know what do you recommed for the following conditions:
Car: serpent s411 TE
Track: concrete very low grip.
Details: night racing indoor. Temperature around 60-70 F.
We are using sorex 36R with schumacher yellow foam inserts and works well, I know we can have a better tire grip but don't know what else to try.
If you can give me a sugestion with sweep option (tyre, insert and wheel) I will apreciate.
Regards.
Alex
Please try a set of our all new EXP Evo-R which debuting this weekend.
http://www.sweepracingusa.com/110-TC...set_p_481.html
Originally Posted by mystique13 View Post
Sweep released so many series of tyre that made me a bit of confused.
SWP-EXP-36P = EXP-36EVO?
What is EVO-R?
The Original EXP tires (EXP-36P) has been discontinued since 2012, than EXP36EVO ran in 2013 but now discontinued as of March/2014. for the 2014 season, we are debuting our latest EXP EVO-R.
Thank you.
SweepRacingUSA is offline   Reply With Quote
Old 04-14-2014, 01:10 PM   #647
DBM
Thank you for your reply! I ended up buying a set of QTS32 WCICS spec tires from a competitor at yesterday's race, and was very surprised to find that I ran nearly identical lap times to my EXP28 rug racers. I initially started out a tad slower, but once I adjusted my driving to them, i ran faster on them than the rugracers. I made no other changes to the car.
Are the QTS32 tires available unmounted/without wheels? I'd like to continue to use the qts32's, but I want to use different wheels (black spoked nylon wheels).
DBM is offline   Reply With Quote
Old 04-14-2014, 02:59 PM   #648
The Evicerator
Thank you.
How different are the EXP36EVO and the EXP36-EVO-R? What kind of differences can we expect on the track?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 04-14-2014, 06:33 PM   #649
Thank you.
For EXP-36P, the "P" stand for Pre-mounted AFAIK, but which tyre is used in the set? EXP or EXP-EVO or both in the same product code?
mystique13 is offline   Reply With Quote
Old 04-14-2014, 07:21 PM   #650
Thanks, there is no tires set available on QTS series, thats to keep the spec teching easy.
EXP EVO was mainly made for longer life, EVO-R is created in newest mould with enhanced rubber. more traction, faster cornering speed.
I guess this is a question regarding the RROC race tire, RROC tires are based on EXP EVO-R 36 tires.
FYI the Original EXP and EXP-EVO, both are now discontinued. EXP EVO-R is the successor of those 2 EXPs.
Thank you all.
Old 04-14-2014, 08:32 PM   #651
Thank you when you will have it in stock. They are in waiting list...
alexrgz is offline   Reply With Quote
Old 04-15-2014, 02:15 PM   #652
The new body looks and works great. Sweep "rug racers" took it all at the Utah state champs race on the 13th.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 04-20-2014, 07:46 AM   #653
Originally Posted by davidl View Post
Please help me with this. I was told that the Sweep 30 tire has been discontinued. Is there any truth to that and if so, what do you make in place of the 30 tire?
I have yet to get an answer to this question. It relates to 1/10 scale 17.5 touring car on carpet surfaces. Anyone know if the 30 compound has been discontinued?
davidl is offline   Reply With Quote
Old 04-24-2014, 06:09 PM   #654
tobyzhang's Avatar
Any plan to make spoked wheels with EXP nylon materials? Really looking for a good impact resistant spoked wheel for GT10 class racing. Ride spoked was good till they changed material.... EXP dish was my favorite wheel to use due to durability. I wish Sweep would consider going into spoked wheel offerings.
tobyzhang is offline   Reply With Quote
Old 04-24-2014, 10:06 PM   #655
Trader Rating: 21 (100%+)
When are the EXP-30Q tires with EXP-LS inserts going to be avalible again?
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 04-26-2014, 11:46 AM   #656
DBM
Is the ver. 2 Roar approved TC body the same as the non roar body, with the exception of having a roar number stamped on it?
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
Old 04-26-2014, 01:36 PM   #657
spring71's Avatar
Smile
New EXP36 EVO-R premount tires are available at TQ.
http://www.tqrcracing.com/shop/produ....asp?p_id=7825
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 04-29-2014, 03:02 PM   #658
Sorry for the delay, we are debuting all new EXP tires call EXP EVo-R. 36 compounds already having great results. selected as Reedy Race spec tires this year as well. please stay tuned for 30 shore arriving.
Thanks for the prop on our EXP wheels. we had plans for that few years ago but never went forward yet. I will escalate this again. please stay tuned.
thanks.
The Approved body have a V2 on top of part # SD0016, molded on the body
Thank you.
Old 04-29-2014, 07:27 PM   #659
Sorry for the delay, we are debuting all new EXP tires call EXP EVo-R. 36 compounds already having great results. selected as Reedy Race spec tires this year as well. please stay tuned for 30 shore arriving. .............
Thx for your reply. You really didn't answer my question, but it appears the 30's have been discontinued and you will have a replacement soon. So that brings me to a follow-on question. I have seen some 28 marked tires in packages with a 30 label. Which tire is actually in the bag?
And related to your answer above, is the EXP EVo-R 36 compound going to run as well on our carpet as the old 30? I am sure there will be some difference, so what would the difference be?
Old 04-30-2014, 06:59 AM   #660
DBM
This happened to me. I bought what I thought was exp 30's, and found out after a couple of races that the tires had 28 marked on them. I ended up switching to qts32's expecting to go a bunch slower, but ended up running the same speed.
