Like Tree1Likes
Old 08-02-2012, 04:09 PM   #466
Originally Posted by ewashburnaf View Post
Hey everybody! Anybody have a suggestion to start with for a very hot sealed asphalt track. Ambient temperatures usually 90*+... track temp regularly in the 115-125* range.
The asphalt was sealed so we usually prep with purple soda to get the grip up...
EXP36's with pink inserts will work good. I'm also starting to like the OG's with pink inserts.
For myself and driving style. The 36's like to over heat on the fronts when the track temps get to 110 to 120. I switch to OG's above 120 and that problem goes away. Sweep has awesome products. I like their X1 to clean the tire and then X3 for 10 to 15 minutes. Good traction throughout the run.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 08-02-2012, 06:20 PM   #467
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Thanks Steve
Fishhook
ewashburnaf is offline   Reply With Quote
Old 08-02-2012, 09:23 PM   #468
Trader Rating: 19 (100%+)
Originally Posted by grippgoat View Post
Thanks, Mark. Our surface is very abrasive asphalt. I've been using tire tweak with warmers, wiping off before the run.
My "fast" combination is EXP36 with Medium EXP insert on Yellow nylon wheels. The Medium EXP insert gives me better wear than the premount thin insert, and also a more direct driving feel that I prefer. But they still drop off 2-3 tenths per lap for each of the first two runs, and I can't more than one day out of them.
When track temps come up above about 115*F or so, I switch to the 40's with the medium EXP insert on nylon wheels. All the other (more experienced) drivers say the 40s don't work at that temp, but a few of them also have Sweep sponsorships so wear isn't such an issue for them.
I also find that, especially with the 36's, my tires grain and develop the "groove of death" faster than most people, even people who look like they're pushing really, really hard on their tires. I think a bit of it is driving and some is setup. I haven't gotten to race much this summer, so I'm having to re-learn some of the things I had figured out by the end of last summer, but didn't write down.
I tried the Team Powers 36, and I think they're faster than an EXP40, but more consistent and better-wearing than an EXP36. But I can still grain them on 110*F+ asphalt, and I don't like the ABS plastic wheels.
I want to try the R36, to see where it stands.
-Mike
The nylon wheels will generally wear the tire better.
I dont have to run nearly as much camber as other tires. This will keep the shoulder wear down as well. To run EXP40 in lower heat (110*F) will require more tire warmer time.
Play around with different diameter wheels that have more size with the EXP36 + thin inserts. You will have the direct feel of the EXP36 + medium but fast start tire.
Good luck!
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 08-02-2012, 09:23 PM   #469
who dat!
TEAMORCA.SHOP
Old 08-28-2012, 08:18 AM   #470
BrodieMan's Avatar
Default Sweep X2 Sauce
I have been thinking of switching from Sticky Fingers to Sweep X2 as my clubs traction compound. Can anyone shed some light on the X2 before I order some to trial?
BTW my guys love the Real Blues as a spec tire. I only wish you could get them unmounted because the rims are indestructible
Cheers
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 09-02-2012, 11:21 PM   #471
Hi all, just after some clarification. Im looking at picking up some Sweep EXP-30P premounts. I read earlier that there was a difference between yellow and white rims (yellow for asphalt and white for carpet).
The only ones I can find are white and I need a set for asphalt.
Glarke is offline   Reply With Quote
Old 09-03-2012, 09:10 AM   #472
How does the color of wheel change anything about the road surface? They are both nylon??
Fishhook
Old 09-03-2012, 09:40 AM   #473
Fred Hubbard's Avatar
It used to be the color would designate which surface to use them on because they both had different inserts. White rims had the Carpet insert (LS Blue) while the yellow rims had the Asphalt insert (Aqua). But now when you order then from the site you can specify any insert for the color rim you choose.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 09-03-2012, 11:01 AM   #474
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
I did noticed that the yellow rim are stiffer than yellow rim..which the white rim flex more than yellow...
OVA is offline   Reply With Quote
Old 09-27-2012, 08:17 AM   #475
Company Representative
SweepRacingUSA's Avatar
Default Victor Wilck Joins Team Sweep!
viktor and Jilles together we will have new tires coming soon.
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 09-27-2012, 09:07 AM   #476
Default EXP-EVO
2012 IFMAR Champion Sweep's own Jilles Groskamp made a stunning change on our EXP TC tires
EXP-EVO is here.
The new EXP-EVO have more traction, better lap time. while last much much longer than any tires.
Results?
we also debut it on the US soil.
at 2012 Blue Diamond Race Park Sweep challenge(open tires). EXP-EVO 36PP took 1-2-3 spots in Qualifying and A-main in Open Modified class. a important factor is all top 3 drivers used just 1 set of tires for Practice, 3 rounds of qualifying and the main race.
Results
TQ: Scooby horton
2nd: Irving Cole
3rd: Tom Lane
Available Oct/2012.
Old 09-27-2012, 09:34 AM   #477
B00t13g's Avatar
My local hobby shop switched from jaco blues to the sweep 32s and I could not be happier!
B00t13g is offline   Reply With Quote
Old 09-27-2012, 05:39 PM   #478
whiteflagwar's Avatar
I'm with you on this one!
Cole Liggett
whiteflagwar is offline   Reply With Quote
Old 09-27-2012, 07:02 PM   #479
Odin544's Avatar
Trader Rating: 93 (100%+)
We run sweep 28's or 32's as spec tires. Always great grip!
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 09-30-2012, 08:47 PM   #480
tobyzhang's Avatar
Interesting, when will the exp evo be available?
tobyzhang is offline   Reply With Quote
