Like Tree14Likes
Old 08-21-2010, 04:49 AM   #256
RL.2002's Avatar
Originally Posted by shesha View Post
Its a tire cleaner after every run clean ur tires out with x1 and wipe off the liquid with a clean cloth then add x2 or x3 depending what u race on
Thankz for the info mate. Gonna to have its soon.
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 08-21-2010, 05:01 AM   #257
WildManDriving's Avatar
Trader Rating: 29 (100%+)
Really??
Originally Posted by Korey Harbke View Post
X1 is very good on high grip tracks. It's actually just a very "light" traction compound. I like it when it when the track gets very hot. Helps keep the tires a little cooler, and prevents them from overheating.
-Korey
I've found the same. When a controlled tyre event has the weather conditions close to the tyres rating I find it's that little tweak you need.
WildManDriving is offline   Reply With Quote
Old 08-21-2010, 05:56 AM   #258
KniteWulfe's Avatar
I bought a set of the sweep Exp tires and 5 minutes into my first run on them the tire ripped apart. The belt tore cleanly like it wasn't bonded properly, and tore right along the belt almost all the way around the tire, the sidewalls stayed glued to the wheels. Was it a defective tire? Or was it some kind of bad luck or error on my part? Is there any kind of recourse if I contact the company?
--Team JBRC-- My Cars: Mini Revo VXL, SCX10, RS4 Rally, TC3 FT, Losi Micro High Roller, Venom Creeper, MP9e, MBX5R-E, SC8E, JQ THE car, and TC3 100% Ti/ Alum Shelf Queen
Helis: SP II, 4G6S- HP-07, HM1#A, HK450GT
http://www.youtube.com/KniteWulfe
KniteWulfe is offline   Reply With Quote
Old 08-21-2010, 09:07 AM   #259
shesha's Avatar
Send a message via MSN to shesha
Well according to sweep aslong as you were not free reving the tires then you are covered i guess.
I have had a couple of them with a bad finish, they look like they have chicken pox on them or something, ran just fine no issues.
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 08-21-2010, 09:14 AM   #260
shesha's Avatar
I am assuming you guys are referring this to running the compound on asphalt and not carpet.
Old 08-21-2010, 10:24 AM   #261
Company Representative
SweepRacingUSA's Avatar
If you are in the Korea, please contact Korea office direct, www.sweepracing.com could be a glue job or a weak belt.
yes, a free revving with a Tekin is most dangerous maneuver for any rubber tires.
chicken pox: yes those are from dust ona CA nozzle time to time, we will clean the CA nozzle more often. thank you have a good weekend
SweepRacingUSA is offline   Reply With Quote
Old 08-21-2010, 12:18 PM   #262
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
All the sets of sweeps we have purchased in the past have ALL torn in a run or two.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-21-2010, 01:19 PM   #263
cheehtae's Avatar
Trader Rating: 15 (100%+)
cmon, mine lasted for three. now I'm using sorex or muchmore.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 08-21-2010, 01:50 PM   #264
we had one batch in that area that we exchanged for who have a proof of purchase. if you still have set that torn down, please contact local team drivers or [email protected] direct.
thanks
Old 08-21-2010, 05:47 PM   #265
KniteWulfe's Avatar
I didn't free rev them at all, I know better
I'll contact sweep tomorrow, I have proof of purchase. Thanks.
Old 08-21-2010, 05:53 PM   #266
Super Moderator
thanks
I did exchange them.. you guys sent me two replacement sets. One set looked pretty good, and I got a grand total of 4 runs out of them before they were basically useless.. and the other set had 1 tire with a bad seam... after 1 run practice run, there was a 1 to 1.5 inch split in the tire right down the seam.. it didn't seperate completely, but I certainly wasn't going to race with it.
So while I apprecaite the service in replacing my 2 bad sets... in all, I got about 5 total runs for $80. The math speaks for itself.
- RCSpecialties -
Old 08-22-2010, 12:41 AM   #267
I am
Old 08-22-2010, 05:11 AM   #268
cheehtae's Avatar
thanks
sent you a pm
Old 08-23-2010, 07:28 AM   #269
sent you a pm
back at you. hmm. that s something we never heard of it yet, perhaps we want to take a look at them to prevent to happens again.
thanks
Old 08-24-2010, 09:30 AM   #270
so a normal set lasted you 4 runs, is that in Mod or Stock racing? how many runs do you normally get from a set of other tires? just curious to know.
also a 1inch split? hmmm...we had that in a single batch in very ealry tires, and we took all those back. if you have can have a tires back for us to look at them, we will much apreciated.
