Old 07-31-2010, 10:37 AM   #241
ChadB.'s Avatar
Trader Rating: 16 (100%+)
Oh ok, thanks Charlie. I'm still kinda new to TC. The reason why I was asking is because mine were getting up to 120-122 last weekend. It is a big track in Washington and the surface is not as abrasive. This is also not using tire warmers, just paragon. So I am just trying figure out what is a normal range and what is to high.
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 07-31-2010, 10:42 AM   #242
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
I hear ya. Most of the time i go by what the car does anyway. When i am by myself at the track and no one to temp the car for me, i have no choice but to go by what the car does. You will know when your tires are at it's breaking point and adjust from there.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 07-31-2010, 10:48 AM   #243
ChadB.'s Avatar
Ok thanks.
Chad Burdick
Old 08-05-2010, 11:36 AM   #244
Default Exp 30
I have problem with exp30 tires, i have try to make Them usable but they are bad on two track i have run them. I have try exp36 and they are working fine, was there bad batch of exp30? I have try varius inserts, lots of sauces, reino ragu tire tweak x1 x3 death greap etc...they have plastic tuch after run. Can someone help me. Thanks
tomislav is offline   Reply With Quote
Old 08-05-2010, 12:11 PM   #245
mine were all really really good , what i did was :-
clean with brake cleaner WELL !!
then soak with Marc Rheinard addive for 30 mins at 60 Degrees C
clean well and drive hard
sidecarphil1 is offline   Reply With Quote
Old 08-05-2010, 05:10 PM   #246
I have wurth brake cleaner and i have clean them 3 times hard but they aren't full shiny, still production leftovers or they are maybe faulty?
Do you have some better stuf to clean them so that they are full shiny?
I have reinhard sauce so i will try it again after i find how to clean them better.
Old 08-09-2010, 03:36 AM   #247
It work on hot day so i finaly got them running, but this is definitly hardest 30 tire i have run, they like very hot track.
When i compare exp36 and exp30 i would use 36 prior to 30 when it's cooler outside.
Can someone confirm this?
Old 08-10-2010, 04:06 PM   #248
Company Representative
SweepRacingUSA's Avatar
our EXP30 in the US has been consistant, please PM us for the email address you need for further help
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 08-13-2010, 12:50 PM   #249
Default Back in stock
Hello racers!
Our long waited EXP40 has been arrived
http://www.sweepracingusa.com/produc...roducts_id=200
and HARD ABS Wheels coming next week.
http://www.sweepracingusa.com/produc...roducts_id=226
and very popular X3 sauce in the bigger bottle coming back with enough quantity. (hopefuly)
http://www.sweepracingusa.com/produc...roducts_id=211
thank you for all your surpport.
Old 08-20-2010, 08:35 PM   #250
shesha's Avatar
Send a message via MSN to shesha
quick question on the inserts whats the main difference between a pink insert and a blue insert on carpet tracks, i know about the weight difference but really whats does it come down to on having the same tire say a 36 and one with a pink insert and the other with the blue what does it do to the tire ?
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 08-20-2010, 09:57 PM   #251
RL.2002's Avatar
Just wanna to know, what is the use for sweep x1?
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 08-21-2010, 12:52 AM   #252
shesha's Avatar
Its a tire cleaner after every run clean ur tires out with x1 and wipe off the liquid with a clean cloth then add x2 or x3 depending what u race on
Old 08-21-2010, 01:06 AM   #253
WildManDriving's Avatar
Trader Rating: 26 (100%+)
X1 can also be used as a traction compound on high grip tracks.
WildManDriving is offline   Reply With Quote
Old 08-21-2010, 01:33 AM   #254
shesha's Avatar
Really??
Old 08-21-2010, 02:02 AM   #255
Korey Harbke's Avatar
X1 is very good on high grip tracks. It's actually just a very "light" traction compound. I like it when it when the track gets very hot. Helps keep the tires a little cooler, and prevents them from overheating.
-Korey
Apex RC - Prospec America - Awesomatix USA - Roche RC USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
SEO by vBSEO 3.5.0
