Old 05-19-2010, 07:35 AM   #181
dameetz's Avatar
Last weekend FEMCA race was with Sweep tyres 32 QTS as a controlled tyres. The grips are very good and lasted to the finals.
So I wanted to try the EXP one for outdoor asphalt. My LHS carry 30 and 36 EXP. My Track temp is usually higher like 40-45deg celsius. But sometimes we race at night too when the track temp is around 20-30 deg celsius. I need advice on which inserts to use if I wanted to use the 30 and 36EXP tyres.
Thanks.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 05-19-2010, 07:52 AM   #182
Company Representative
SweepRacingUSA's Avatar
We re Back in the office, all shipping and email apply will be done, ASAP
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 05-19-2010, 07:56 AM   #183
TeamB&B's Avatar
Thanks.
Selecting the right insert is a major part of your chassis tuning. The best approach is to run the 36EXP and test both the aqua and light blue inserts. Your final selection will depend on the track surface, spring and shock oil, and your driving style.
If time or cost is an issue, then the aqua insert is a safe bet.
RCAmerica / Sweep
TeamB&B is offline   Reply With Quote
Old 05-19-2010, 08:53 AM   #184
dameetz's Avatar
Thanks TeamB&B, will try it out soon.
Old 05-19-2010, 09:54 AM   #185
Kenny L's Avatar
Trader Rating: 16 (100%+)
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 05-19-2010, 05:59 PM   #186
Mike Haynes's Avatar
The ls insert seems to make the car a bite edgier (more steering) at the cost of rear bite, the mediums are more stable, the ls is my preference as it seems to let the tires wear very evenly and run well. My car is pushy by nature so it is the perfect fit, if you have a chassis that steers alot, the medium will likely be better suited.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-19-2010, 10:57 PM   #187
Trader Rating: 23 (100%+)
Just ran my QTS 32's tonight for the first time and noticed I have a groove wearing in the inside of the tire next to the side wall. It is a outdoor asphalt track with sugar water for traction. My camber was 1.5, and track temp was about 65 degrees. What is the cause of this? New to running outdoor asphalt, so any help would be greatly appreciated. Traction was low due to the cool weather.
bmcallister is offline   Reply With Quote
Old 05-20-2010, 01:43 AM   #188
cheehtae's Avatar
Trader Rating: 15 (100%+)
I'ts called THE RING OF DEATH bmac.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 05-20-2010, 02:26 AM   #189
You're cooking the tyres, maybe if you have your setup for warmer temps, it may be too stiff for the lower traction.
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 05-20-2010, 04:42 AM   #190
Default EX, LHS or QTS
What is the difference between the EX, LHS and QTS series of tyres and what would be the most suitable for medium grip carpet racing (Air temps 15 - 20 degrees C)? At the moment I'm using RP24's but find that they don't have that much grip to start off with and then go off even more by the end of the race.
Graham Oliver is offline   Reply With Quote
Old 05-20-2010, 08:18 PM   #191
So how does that groove form in the tires? I would think they would blister if I were getting them to hot? Does it occur from tires sliding across that asphalt? I need some suggestions, these were the first night of racing on the tires. This could get expensive quick!
Old 05-20-2010, 10:41 PM   #192
Skitee's Avatar
You might have too much camber causing the tyre to run on the inside edge through the corner, your -1.5 degrees of static camber shouldn't be too excessive though so I think your setup is giving you some camber gain when you're in the corner, you can check this by simply pressing down one side of the car to check if the top of the wheel moves inward towards the car, if you do have camber gain when the suspension compress then maybe you should set you static camber to -1.0
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 05-21-2010, 06:07 AM   #193
EXP: our Flag ship tires, fastest on most surface, wear last, made for the open tire competitions.
QTS: our most popular tires, consistant tractions on most surfaces, good wear, made for the Spec tires competition.
LHS: discontinued
Old 05-21-2010, 07:42 AM   #194
Kenny L's Avatar
It has come to our attention that some hobby shops are buying on clearance through a big distributor non US branded tires and are selling them as Sweep Racing USA products. These tires do not meet the specs we have placed for the US market in 2009. Those tire sets marketed as "pre-mounted" are not pre-glued like our US version of tires. Sets that Sweep Racing USA imported clearly marked "pre-glued" also only the Sweep USA version come with the Dupont nylon wheels called "EXP" those are the visual difference consumers or dealers can find before make the purchase. Best way to ensure you are getting the right product is buy direct from us or from our retailers on the list http://www.sweepracingusa.com/retailers.php
TeamSweepRacingUSA
Old 05-23-2010, 04:47 PM   #195
TeamB&B's Avatar
Time to do it again. Can't wait to see the Sweep girls in full beach attire.
RCAmerica / Sweep
