Old 02-03-2010, 02:33 AM   #16
Another possibility. I have this trouble when running a hot motor with a Spektrum receiver. Here the car shuts down for a second under hard acceleration. The problem is that acceleration causes a voltage drop and the BEC can't but out the 6V the receiver needs. The receiver then goes into Failsafe, full brakes and steering straight ahead. As soon as this happens the voltage comes back up and the receiver comes back on line. It causes a kind of juddering acceleration. If none of the wires are shorting then perhaps this could be a problem, especially if you have the speed control set to some very aggressive setting. The solution for me was to make a voltage protector for the receiver, just a capacitor plugged into an empty slot on the receiver. This stores enough power to keep the receiver powered while the voltage comes back up. Not sure if you can do this with your receiver as it depends how it it wired.
This seems to be becoming more and more of a problem as 6V servos are getting more powerful and there are lots of things (fans, PT's etc) plugged into the receiver.
Just an idea
Rocking Donkey is offline   Reply With Quote
Old 02-03-2010, 06:36 AM   #17
steveonamission's Avatar
Originally Posted by THancock View Post
Knowing Steve as I do, and how the problem occurs mid way through the day, I'd put money on it being your hands getting all sweaty as the pressure starts to build and you're shorting out your transmitter
Or it could be something else completely
Haha.... Well if you didnt keep popping up to the meetings i go too, i wouldnt feel so much pressure
But cheers guys, just found out that saturday practise is cancelled, so hoping for the best on Sunday, have tried a capacitor too, no help, cant wait till outdoors kicks off, so i can rule out carpet fibre statics too
Will let youse know.
steveonamission is offline   Reply With Quote
Rc10ntc3 Taz_S Nitro On-Road 9420 09-03-2016 01:30 PM
Futaba 4pk Atom357 Radio and Electronics 1620 03-05-2016 11:18 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
Neon/ Underglow Kit Tutorial! Blazin~ Painting, Designs, Graphics and Photography 10 04-25-2009 02:08 AM
SEO by vBSEO 3.5.0
