Old 02-01-2011, 08:51 AM   #61
tunerjetta29's Avatar
Its strange to me that so many setups show using the 0 degree front caster blocks. The car seems so twitch and edgy with the 0 degree. The 6 and 9 degree blocks really seem to make the car much smoother and easier to drive.
Currently Running:
Serpent Project 4X , 17.5 Motor, Team Orion R10.1 ESC
X-Ray X1 2017, 25.5 Motor, Hobbywing X10 Pro ESC
X-Ray X1 2016, 25.5 Motor, Hobbwing X10 Stock ESC
Ko Propo EX-1 V3
tunerjetta29 is offline   Reply With Quote
Old 02-14-2011, 06:29 PM   #62
avs
avs's Avatar
Originally Posted by Alain Patry View Post
Do you have some pics of the world Gt race at the Snowbirds 2011 ?
Thank you, Alain.
+1.
Tony Shimko
avs is offline   Reply With Quote
Old 02-14-2011, 07:00 PM   #63
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by avs View Post
I see that Markus Mobers is in the Snowbirds WGT Amain. Looking forward to some comments on his setup. One point of interest is 1s battery and electronics layout for weight distribution.
i think the ESC is missing from this picture on Serpent's website?
I have my battery all the way forward almost hitting the servo. It is right at the tape slot in the front, I used the battery holder for the front underneath the top deck posts . I then added 3mm of shims to the rear for the top deck posts. I also redrilled the chassi so I can use a battery holder in the rear but it not needed. My speedo is behind my battery in the center of the car, receiver pack on the right and receiver and transponder on the left. Depending on what electronics you use you might need to add some weight to balance it out but not much. I also moved my center shock to the hole on the bottom of the tower instead of one hole up because of the raised top deck.
Hope this helps. I'd take a picture but Shmyka has my car
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 02-15-2011, 07:22 AM   #64
avs
avs's Avatar
thanks, that is how mine is arranged.
i have seen some other cars at my local track with the battery all forward and the electronics midship. more forward weight bias seems all the rage, so i was curious if anybody had tried a more forward weight distribution.
compared to the competition, my car seems to be a little sluggish to rotate around short tight corners. i guess the question is, do i try to cut a tighter turn faster, or try to roll thru the turn with a longer smoother line. (a consideration is the groove is usually better on the tighter line, so i feel a little stuck on the inside line.)
Tony Shimko
Old 02-16-2011, 04:01 PM   #65
avs
avs's Avatar
M. Mobers posted his race report from the Snowbirds.
interestingly, there is a comment about trying to reduce traction rolls, but the changes resulted in taking away too much steering.
it would be instructive (at least for me) what changes were made, and changes you might have tried next to correct the situation. (this might be obvious to some, but not me)
Tony Shimko
Old 02-16-2011, 04:18 PM   #66
chicky03's Avatar
Some things you can try to get more steering
Crc white side springs with 1-2 turns of preload, you'll need longer set screws
18 lb center spring
Long front wheelbase
When it ran my car with the stiff springs the long wheelbase had too much steering, I want to try softer springs(stiffer than stock but not as stiff as above) and the long wheelbase, I think this might be best.
I'm not sure what markus did at the race, I'll see if he can post something.
Old 02-17-2011, 06:44 AM   #67
avs
avs's Avatar
18 lb center spring
thank you for the insight!
i tried a shortened wheelbase and it seemed worse, i figured that it was an ackerman setting problem and just hadn't sorted it out yet.
somehow i assumed a short wheelbase would increase steering. there is a running joke with fellows i race with, "whatever change you think you need to make, just do the opposite" (pancars are different)
Tony Shimko
Old 02-17-2011, 08:45 AM   #68
I cant say on a pan car I haven't noticed a difference with ackerman as long as I keep it in a similar range, wheelbase, at least as much as this can can be changed I did notice a difference. Even though the car will be shorter you think it would turn more but it puts more weight on the front so it actually turns less.
On-Point Racing info@onpointracing.com
On-Point Racing is offline   Reply With Quote
Old 02-17-2011, 10:42 AM   #69
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
So you could say that moving the front end further forward on the chassis would be similar to moving the battery towards the back of the chassis, correct ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-18-2011, 12:55 PM   #70
avs
avs's Avatar
makes sense. when i tried the short wheelbase i did not make any compensating change to the servo. i will try that next time for a better comparison.
Tony Shimko
Old 02-18-2011, 01:01 PM   #71
avs
avs's Avatar
that is the only rational explanation. so next time maybe i should try moving the battery back as well to get the shorter wheelbase with the same front/rear bias
although compared to the development version 12r5's at snowbirds. it seems like they are looking at even more fwd bias's.
Tony Shimko
Old 03-25-2011, 04:36 PM   #72
RC MARKET's Avatar
this car kit have other brand conversion kit to 235mm ?
RC MARKET is offline   Reply With Quote
Old 01-08-2012, 11:39 AM   #73
Default TUBE CONVERSION
The S100 now has the tube conversion, any one have a set up for this car , tried it with the Markus set up and it was awful, changing the caster blocks to 6 degrees and cell forward every thing else so far is kit.Only changing one thing at a time.
Car was brill round corners but any str8 car was every where under acceleration.
vinster is offline   Reply With Quote
Old 01-22-2012, 09:27 PM   #74
MrChodes's Avatar
Please tell me more. I went to Serpent website looking for tube conversion for S100 but could not find any info. Did you convert yourself or is there a conversion kit?
Serpent S100. Ducati FM1-e bike.
MrChodes is offline   Reply With Quote
Old 01-23-2012, 06:07 AM   #75
orcadigital's Avatar
Trader Rating: 61 (100%+)
On-Point racing has the conversion. Stormer Hobbies carries it.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Gulf Coast RC Track Racers, Porter Texas (Houston) John Stranahan Texas Racing 2692 04-18-2013 09:18 AM
