DIMENSIONS OF SANWA M11X ??? ( depth mainly )
I need to order TODAY a radio bag as a present for a pal that has an M11X...
but the radio is pretty awkward in its dimensions, depth especially... Can someone give me the dimensions, including module and antenna ? quickly would be great... Thanks A LOT guys ! |
Originally Posted by heretic
(Post 6933784)
but the radio is pretty awkward in its dimensions, depth especially... Can someone give me the dimensions, including module and antenna ? quickly would be great... Thanks A LOT guys ! The plastic case is sick because you can sticker it up, throw it, stack on top of it.. So on and so forth. Even aluminum cases might work. :cool: |
I could not find anything to measure the radio with. I think its to early for my brain to function in finding tools of measurement.
Anyway, I know this bag will work. There are a lot of different styles of that exact bag, just some different manufactures names on them. You should be abel to get them at any online hobby shop if your local shop does not. |
You're the man ! excellent guess ; that's the bag I'm buying, it appears to be the same...indeed found under many brands.
http://www.rc-plus.com/sac-de-transp...nn-racing.html BTW I called my friend's wife and she measured 130 mm for the depth of his M11X... a million thanks for your quick answer ! I'm ordering.:) |
