Old 11-08-2011, 01:10 PM   #361
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Originally Posted by JamesL_71 View Post
I understand some people do that...
My question is more... How much does the diameter change over the life of the tire?
To be honest, I have never seen anybody measure the diameter of a rubber tire. Most people swap them out when they feel bad and they still usually have some life in them for practicing. I usually go by the number of rounds I race a set with. Also, you can see the wear on the tires and tell if it is getting bad. I don't think that going off the amount of actual rubber wear is standard practice...
Fishhook
ewashburnaf is offline   Reply With Quote
Old 11-08-2011, 02:39 PM   #362
Buckaroo's Avatar
Tire size is a nominal 63mm, although various brands and specs range from 62-65mm. Overall wear is at most a millimeter until cords show for most slicks. More for hard compound spec tires like the X patterns used in RCGT or the treaded tires for VTA.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 11-08-2011, 03:03 PM   #363
Thanks for the replies fellas.
Im actually not trying to judge tire condition/wear based on diameter... Im trying to find out the change in rollout that will occur from moving to a brand-spankin-new tire from a 3-week-old-pretty-damn-worn tire...
Again, it is hard to get a truly accurate measurement with calipers... But I measured brand new Solaris Hards at 63.4-63.6mm. I measured my 3 week old tires at 61.5-61.8mm(depending on which corner of the car they were on).
JamesL_71 is offline   Reply With Quote
Old 11-08-2011, 04:07 PM   #364
stiltskin's Avatar
Trader Rating: 102 (100%+)
Unlike foams, rubber tires will expand under acceleration. I don't have any formulas to show you how much, but I would bet that a worn out set would probably expand more than fresh rubber. Just a thought.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-11-2011, 07:32 AM   #365
Default GR-F Inserts & GR-M Inserts??
hi guys,
i am thinking to get a set of rubber tire but i am not sure the difference between these two...
Solaris 1/10 Touring Tire Set Hard GR-F Inserts &
Solaris 1/10 Touring Tire Set Hard GR-M Inserts
i hope to get some of of your expert opinion .. million thanks
ceong is offline   Reply With Quote
Old 11-11-2011, 08:28 AM   #366
Chaz955i's Avatar
Originally Posted by ceong View Post
hi guys,
One has a firm insert and one a medium insert.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 11-29-2011, 07:48 PM   #367
theatriks's Avatar
hey guys i wanna try solaris tires what the difference between the hard/medium solaris and the temped ones like 35 and 40 ?
theatriks is offline   Reply With Quote
Old 12-25-2011, 11:58 AM   #368
Trader Rating: 30 (97%+)
i have only used tamiya tires, so if someone can help me out, which solaris tire is the same or close to tamiya type a tire, and which solaris tire is the same as or close to type b tire thanks
zaraz is offline   Reply With Quote
Old 12-25-2011, 04:08 PM   #369
anyone
Old 12-26-2011, 06:58 AM   #370
theatriks's Avatar
Originally Posted by zaraz View Post
anyone
as you can see i asked about these tires on the 29th of november and still didnt get an answer apparently a lot of people are running these but without any info from here or there website i dont see why i would buy these tires if they dont even put info out there for the customer....anyways i buy lots of tires and since i cant get info from solaris or here i just buy sorex and beleive sorex are good and at least the company takes the time to explain there tires!!!!!
Old 12-26-2011, 07:14 AM   #371
TimPotter's Avatar
Send a message via AIM to TimPotter
Whenever I do not get a reply on forums, I look to see if they replied at all ..in the timeframe... If not, I call or email them directly.
http://topracingusa.com/contact.htm
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 12-26-2011, 08:19 AM   #372
jag88's Avatar
I emailed them 2 weeks ago about their ' Premium ' tires and as of yet have not got a reply.
jag88 is offline   Reply With Quote
Old 05-23-2012, 11:45 AM   #373
Rockin G's Avatar
Sorry to bring back an old thread, but these things are getting hard to find. I am looking for Solaris (Hard), Tires only. I googled them without much luck. Anyone know of a place that sells them? The Solaris website looks like you have to email to order, but it looks like you have to be a track to order. I also found Misfit, Speedtech and Timezone have pre-mounts but most are out of stock. Muchhobby in Cananda has them premounted as well. Would like to find some tires only though. Any ideas?
Rockin G is offline   Reply With Quote
Old 05-23-2012, 11:50 AM   #374
stitchy's Avatar
1 set of hards on white left:
http://www.speedtechrc.com/store/ebp...id=856&id=9373
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 05-23-2012, 09:03 PM   #375
www.corrc.org (Colorado On-Road)
bdbachus is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Defective Jaco Blue Tires billjacobs Electric On-Road 123 02-06-2011 12:26 PM
