Old 03-24-2004, 08:28 PM   #1
Send a message via AIM to LancerEVO
Default Pitch
my friend was buying a pinion gear and they asked him how much pitch he wanted what does the pitch mean ?
LancerEVO is offline   Reply With Quote
Old 03-24-2004, 08:35 PM   #2
Send a message via AIM to True R/C Racing
pitch is the spacing between each teeth(correct me if wrong). Theres 48 pitch and 68pitch. 48 is easier to mesh without stripping a spur. On other hand 68pitch is more efficient and quieter IMO. But if your not good at meshing you can easily go through many spurs.
True R/C Racing is offline   Reply With Quote
Old 03-24-2004, 08:40 PM   #3
Speedie's Avatar
One other point is that 4 pitch gears have a bigger selection og gear choices compared to the 48 pitch. The more teeth the more subtle the gear changes you can make. If your a serious racer at all dont waste the money buying 48 pitch gears. Youll switch to 64 eventually so buy gears you will use for a long time. Now if your running offroad then 48 is alot more durable and able to withstand all the abuse moreso than the 64 pitch.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 03-25-2004, 03:30 AM   #4
MrEs's Avatar
Send a message via ICQ to MrEs
stick to 48 pitch. you WILL break 64 pitch unless u are basically a perfect driver. a hard head on collision and youll strip your 64 pitch gears and you have to DNF your race cause u cant go on..
ive seen it happen alot
MrEs is offline   Reply With Quote
48 Pitch, 64 Pitch Alfalfameister Rookie Zone 11 01-29-2008 04:07 AM
Converting TC5 from 48 Pitch to 64 Pitch??? jdob Rookie Zone 3 06-23-2007 10:10 AM
64 or 48 pitch minnesh Electric On-Road 23 05-07-2007 09:34 AM
48 pitch pinions cheap/or trade for 64 pitch pinions Got Xray? Australia For Sale/Trade 2 05-26-2006 10:04 PM
48 Pitch or 64 Pitch Mossie Australian Racing 4 01-21-2004 01:33 AM
SEO by vBSEO 3.5.0
