TC5 Diff problems?????
Hello, I think I have a front diff problem with my TC5. I just bought this car used and I'm not sure if this is normal or not. The problem is the front diffs continue to spin in the forward direction even when the brakes are applied? Also I noticed that when I spin one front wheel in any direction the opposit wheel does not turn at all. When on power all 4 wheels work perform as they should. Is this normal or do I need to rebuild the diffs? Thanks in advance
+1 on the oneway, will let the wheels freewheel in one direction only.
Thanks for the reply, I've heard of this one way kit before but was not too sure what it was all about. I'll have to give this a try at the track this weekend and hope all works out . Thanks again.
The only down fall to racing with a oneway is that you lose brakes on that end of the car . Go ahead and get a spool for the front, especiallly if you are running outside on asphalt, One ways are more for foam racing indoors on carpet. They can be hard to control if you do not know much about racing with them. Look at the assoc slipper spool, or an after market one like the titanium racing one. I have the Ti racing one and love it alot!
