Old 01-23-2010, 10:23 PM   #1
Default screws washers shims
does anyone know where to get a nice hardware kit for like a gen x or just 12th in general. something that would have screws nuts shims washers any kind of hardware you may need
Team CRC Gen X
Tekin RS
Power Push
xxx-s is offline   Reply With Quote
Old 01-24-2010, 07:57 AM   #2
wingracer's Avatar
Trader Rating: 21 (100%+)
Check this out, you can make your own assortments.
Sean. Certified speed crazed mowron.
Team Shepherd USA
wingracer is offline   Reply With Quote
Old 01-24-2010, 08:44 AM   #3
avs's Avatar
Tony's Screws has good quality steel fasteners. no kit for a genx but he does have a rc12l4 kit.
there aren't that many different fasteners on a 1/12 scale so buying packs of 5 or 20 wouldn't be so bad. maybe if someone sent in a enough documentation to define a genx kit, he might add it to the catalog?
Tony Shimko
avs is offline   Reply With Quote
Old 01-24-2010, 09:51 AM   #4
Regional Moderator
CarbonJoe's Avatar
I'm still not a fan of stainless hardware, since it isn't as strong as most of the black oxide steel stuff like Tony's Screws sells. I'd place it in between aluminum and black oxide steel for strength.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
4 stroke Revo prototype testers wanted DP-buggyboy Northwest Racers 33 09-12-2006 04:09 PM
Place to buy metric drill bits, shims, screws, etc.? performula Nitro On-Road 6 05-17-2006 03:02 PM
SEO by vBSEO 3.5.0
