Servo Saver
Kimborough
You can get replacement TAM51000 for the Tamiya Hi-Torque Servo Saver.
If you additional durability just replace the servo horn with aluminium.
What is difference between TAM51000 and Kimborough?
Are there any other servo savers?
There are plenty but th OP asked for something of quality. It is not worth to try and save a few pennies after dishing out for a quality servo. It cancels out the whole quality you pay for (you might as well buy a crappy servo).
the tamiya saver lasts for a little bit then you start having no neutral position as the springs wear the plastic shoulders they rest against. The aluminium saver arm doesn't fix things either as the other half of the saver is still plastic. So if you're after a quality saver just save you money and buy a good one like the Kimborough. With the Tamiya you'll have to buy a new one every few weeks.
Thanks!
I am using Kimborough but to my taste the spring is weak and I do not like the plastic feel.
Here is a test I do. I take my T4 and turn the wheels to one side by hand with the servo in the center. Then I place T4 on the carpet. The servo saver spring is weak to move the wheels completely back to the center.
The servo saver is of a good size and is red in color. Based one the info here: http://www.kimbroughracingproducts.c...vo-savers.html
it is small (the only one made red?).
Which one do you recommend for 1/10 TC, buggy, and truck?
Thanks!
Quality.
Thanks!
Adding to this tamiya servo saver had another problem. if your car got knock sideway to front wheel by other moving car. the original plastic servo horn breaks. anyone got problem with kimborough?
Quality.
after i use the aluminium horn with it, does last me a month longer if I do not have any major crash. i just replace it & throw the plastic horn aside.
is there a real durable servo saver i can change beside kimborough. for other brand, if the plastic won't wear most likely the spring is not strong enuff to return the steering to centre. the tamiya springs are indeed very strong. the setback is it does wear the plastic moving part faster.
I like the Tamiya.
I'm not sure why it is being given a bad rep in here. I've had it in the tourer for 2 years (granted, only running one or twice a month in that time), and although there is a little wear in it now, it is less than a trim click, and I have no problems whatsoever with consistency of straight line running.
I know what a bad servo horn/saver feels like... I returned two perfect servos to KO because a bad fitting HPI servo horn that made me think the servo wasn't centreing correctly, and spent a whole race meeting crashing into the barriers down the straight because of a weak Kawada servo saver... if it takes a stupid mistake to learn something, I've done it!
Tamiya's servos are poorly designed. Plastic is not going to last when the spring tension is held by a sliver of plastic against spring steel and with sharp edges at that. I had a number of them fail and the consistency of their failure convinced me. I have also seen it happen to a lot of other people so I gave it up. I have a pile of brand new ones that came in my kits and I don't intend to use them. The really crappy ones with a plastic spring sector are better in my opinion even thoguh they don't hold much force before the plastic spring is flung out, but at least they don't wear out in such a way that neutral is all over the place.
My personal favourite is the shear saver of the past (as used in Yokomo cars for instance) but most modern cars simply can't accomodate such a setup.
Well, after reading this thread I now have a couple of kimbrough servo savers on order
Just a quick question though - I notice that the servo horn on the kimbrough units are made of plastic. Would these hold up in the longer term, or should they be replaced with alum ones? Generally, how long can these savers be expected to last before they need to be replaced?
Cheers!
Cheers!
