I am loving the Reedy 19 Quad Mag. Great Power, Runs very cool, all around excellent motor. Probably the fastest out there. If you get this, make sure that you gear up about 2 teeth ( 48 pitch ) over what you would with a normal 19 turn motor. You probably can go up alot more.
Originally posted by Cain I am loving the Reedy 19 Quad Mag. Great Power, Runs very cool, all around excellent motor. Probably the fastest out there. If you get this, make sure that you gear up about 2 teeth ( 48 pitch ) over what you would with a normal 19 turn motor. You probably can go up alot more.
the 19t chrome can,still runs faster and efficient.
I run chameleon 2 19 turns, I like them a lot. I gear them as I would a stock motor, and it barely gets to what I would consider too hot. What is everyone running as a hot brush/spring setup?
I am sponsored by banzai their 19t is hand wound in a d5 can much like epic power and torque are awesome on a robitronics dyno my c2 was 172watt power torque 192 rpm 34,000 my d5 power is 185 watt power torque 233 rpm 36000 these motors rock www.banzaimotors.com
