Power supply question?
Generally you want it to put out a few more amps than you will draw off it. For example if you want to run 2 chargers and you charge at 5.5 amp each then they will pull 11 amp. Get a PS that will put out like 15 amp and you should have no problem. I personally went ahead and got a 25 amp PS so I knew I would not have any problems with 2 chargers.
I run two chargers at 6 amps each off of one of the Ebay Cosel 13amp power supplys. Been doing so for almost 6 months without a single problem.
