Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 06-08-2008, 05:08 PM
  #26236
How do you measure droop from chassis to floor?
sf85 is offline
Old 06-08-2008, 05:13 PM
  #26237
Trader Rating: 28 (100%+)
measure the ride height, then lift the car up at the end your measuring and just as the tyres come off the ground measure again
subtract the 2 numbers and thats droop
Ashley Cobb is offline
Old 06-08-2008, 05:55 PM
  #26238
PW
PW's Avatar
Sup boys & girls! Just stoppin by to see whats up!
Seaball keepin the man love strong in here....
PW is offline
Old 06-08-2008, 06:18 PM
  #26239
Cesar's Avatar
PW we gonna see you this coming weekend???
I got some ?????
Cesar is offline
Old 06-08-2008, 06:31 PM
  #26240
So you would have to check your droop every run as your tires would change in size when they get worn? Seems like an inaccurate way to do it
sf85 is offline
Old 06-08-2008, 08:12 PM
  #26241
PW
PW's Avatar
I got some ?????
That's the plan.
PW is offline
Old 06-08-2008, 08:30 PM
  #26242
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Yeah pretty much. With rubber tires they don't wear to bad. With foams, depending on how where you start with tire size and how much you run them, you will have to consistantly monitor droop. I will say this though, just because you set it at a number on the droop gauge it doesn't take into account for your tire size.
I run rubber tires and still set my droop by subtracting the two numbers.
Kraig is offline
Old 06-08-2008, 08:32 PM
  #26243
Originally Posted by Marcos.J
hey JayBee here is my foam car ( with McGoo set up)
Hey are they powerpole connectors on the motor? i thought they were only good for like 25amps?
Old 06-08-2008, 08:59 PM
  #26244
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
they are deans,and i had them on all my motors for over a year with no problems at all
Marcos.J is offline
Old 06-08-2008, 09:01 PM
  #26245
Super Moderator
Marcos.J's Avatar
Originally Posted by mickrcarver
hey marcos the original setup on that car was jim beans snowbirds setup i still have it somewhere but trying to find it by the way the car was ultra smooth on our carpet track
P.S. notice the steering setup for lower ackerman
what springs did he have in the front??
and yes i did noticed the lower steering set up
Marcos.J is offline
Old 06-09-2008, 12:05 AM
  #26246
dfiantii's Avatar
Trader Rating: 18 (100%+)
I just ordered my Losi Type R this weekend and was thinking of buying the SpeedPassion ESC. Now I am not a what ever is the hottest thing going this weekend type purchaser. I went to my track and was told I would be better off getting an LRP and was also told none of the TOP drivers for the Reedy Race ran the SP esc so can someone give me the good, bad or indifferent on this esc. Why you think it would be or would not be a good purchase. I will be running stock since I am a novice. Thanks in advance.
dfiantii is offline
Old 06-09-2008, 06:14 AM
  #26247
mickrcarver's Avatar
Trader Rating: 101 (100%+)
those are x ray springs from the new batch I think they were 30's they are marked with a # i think
mickrcarver is offline
Old 06-09-2008, 06:16 AM
  #26248
Super Moderator
Marcos.J's Avatar
thanks!
Marcos.J is offline
Old 06-10-2008, 02:13 PM
  #26249
Hello
i´m writing because i´ve got a problem with drive shafts of MI-3
i know everybody says that the silver ones (u3020) are better than purple one, for me are just the same (broke as glass)and that´s my only complain about the car.
i´m going to put the steel ones (U2151) but a guy told that i have to put a spacer.
anyone of you are using the steel drive shafts and how you tighten the hex´s against the Hub ball bearing, cause i want to wear that ones but i don´t know what kind of spacer do i have to use.
please help me in this issue
thanks
Joao Martinho
jopor is offline
Old 06-10-2008, 02:15 PM
  #26250
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
Try U3267's for CVD's
Originally Posted by jopor
Hello
thanks
Joao Martinho
abailey21 is offline
