Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 05-22-2008, 09:58 AM
  #26101
Originally Posted by yyhayyim
Adam...you have PM sir
oye Yohan. Que lio me meti con Schumacher bro. La mujer me cojio y casi me lo vota chico Tengo que conprarle un regalo a ella primero y despues puedo jugar con los carritos
Xtreme2008 is offline
Old 05-22-2008, 10:00 AM
  #26102
Default MI3 & SMC
SMC 5000 28C packs fit in Mi3 with no modify?
Old 05-22-2008, 10:02 AM
  #26103
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
they may fit as long as they dont swell up like a balloon
Marcos.J is offline
Old 05-22-2008, 10:05 AM
  #26104
Smc 5000 is 24.5mm tall, and dont know how tall is MI3 bulkhed. You know how much is this?
Old 05-22-2008, 10:06 AM
  #26105
Super Moderator
Marcos.J's Avatar
i think the Core 5000 pack is about 24.5mm too
Marcos.J is offline
Old 05-22-2008, 10:08 AM
  #26106
no...core5000 is like 23.5mm
I leave you gift PM
Old 05-22-2008, 10:09 AM
  #26107
Super Moderator
Marcos.J's Avatar
I leave you gift PM
well i guess i was wrong
Marcos.J is offline
Old 05-23-2008, 01:49 AM
  #26108
Trader Rating: 28 (100%+)
I have no rear grip on my MI3, it's setup per the Tarmac Test Day setup. I've removed the antirollbars and am using blue springs on the back, which improved things greatly but the car still spins out.
Is it something as simple as standing the rear shocks up, or something more serious
Ashley Cobb is offline
Old 05-23-2008, 06:00 AM
  #26109
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
I'm running a lot of rear toe to help with the same issue, about 3.75 degree's of toe to be exact, I found that helps a ton.
abailey21 is offline
Old 05-23-2008, 08:44 AM
  #26110
justin lessard's Avatar
Captain awesomes car is dialed regardless of surface,intoxication,or skill level.dialed!
justin lessard is offline
Old 05-23-2008, 09:45 AM
  #26111
Trader Rating: 80 (100%+)
I am currently running the black front and rear belts on my Mi3. I have read about the low-friction grey belts. Are these recommended? What are the part numbers and are they in stock?
cpatel529 is offline
Old 05-23-2008, 09:48 AM
  #26112
abailey21's Avatar
U3012, and U3013 and yes they're in stock
Old 05-23-2008, 09:50 AM
  #26113
Trader Rating: 17 (100%+)
Yes...running those since day 1 (actually, day 2...may be 3)...indoor carpet must have.
Now Adam...get back to work and you are working MONDAY as well...
Solara is offline
Old 05-23-2008, 09:54 AM
  #26114
abailey21's Avatar
The only place you'll see me on Monday is playing GTA4 on XBL!
Old 05-23-2008, 10:08 AM
  #26115
You damn generation X teenager....btw, what stage are you in now..? I just blew up some cars and shot down the LAPD helicoper, my 4 years old daughter is getting good at that....
Solara is offline
