Schumacher Corner
MI3 & SMC
SMC 5000 28C packs fit in Mi3 with no modify?
Super Moderator
Super Moderator
Super Moderator
I have no rear grip on my MI3, it's setup per the Tarmac Test Day setup. I've removed the antirollbars and am using blue springs on the back, which improved things greatly but the car still spins out.
Is it something as simple as standing the rear shocks up, or something more serious
R/C Tech Elite Member
I'm running a lot of rear toe to help with the same issue, about 3.75 degree's of toe to be exact, I found that helps a ton.
I am currently running the black front and rear belts on my Mi3. I have read about the low-friction grey belts. Are these recommended? What are the part numbers and are they in stock?
