Schumacher Corner
No one weighs cars at my local track and I race again some ultra light Team Magic and Losi sedans so I don't add weight to my Mi3. All I do to balance it is shift my Core 5000 pack so it sits ~3mm past the edge of my chassis. Voila, perfect balance and no added weight!
thank adrian but i got bigish meet coming up and i will get weighed so i kinda need a solution. but ill do what u say for club meetings
Well if hes moving it 3 mm past the edge of the chassis it seems like there would be enough room to run some weight pretty close to down the middle. Especially where the belt starts rising to reach the layshaft pully. If its balanced without weight, then you could theoreticaly just add weight to hit minimum . . .right?
awsome idea sorry re thought bout it
does any one know what size turnbuckle turner i need for mi2/mi3?cheers
Super Moderator
Super Moderator
I wonder who has that Ultra Light Team Magic
R/C Tech Elite Member
Super Moderator
Did Dani buy one???
hi dudes
I'm just wondering why some racers cuts teeth from front or rear belts?
also what is the correct part no white frnt belt .does mi2 or ec ones are the same
cheers
cheers
Regional Moderator
cheers
cheers
U3013-Rear Grey belt
*edit* The belts are the same ones from the Mi2EC.
Actually, the front belt for the Mi2 is different. The Mi2 had an extremely long belt that went from the rear pulley to the front pulley.
thanx guys
u3012 is the part number of grey front belt, I've also ordered ea diff grease I hope it is as good as schumacher ones
does anybody tried xray oneway diff halfs on mi3 they r xtremely light....
Regional Moderator
