Schumacher Corner
R/C Tech Elite Member
Had great time at the Winter Carpet Nats in Gathersburg, MD yesterday. Unofficially called the "Mike Kring going away race" it was lots of fun.
Team Shumacher did well with Tim Getchell putting his Mi3 in the Rubber "A" main, with privateer Steve Walter and I running the schuie frieght train in the "B". I ended up "BQ" and lead the race from start to finish. After watching the carnage in the "A", I'm kinda glad I was in the "B"
Wes Lion made the show in foam, but dont know where he ended up.
Big thanks to Mike Herald Jr for the advise and shock tips
I'm off to Hawaii now, but rest assured I'll represemt well over there. I'll try and make Vegas, but no promises
Mike, wish you the best, I am sure you will be in hawii making new racing buddies, thats what you do. You are one of the best guys to hang around for some laughs thats for sure. Take care and I will see you around.
the parts u need to run steel bones in your 1way:
46mm L/W bone #51092
415 axle #53499
kit 1way joint #53590
L/W 1 way joint #53704
415 axle #53499
As Static Kling said we had a great time at Mimis. This was the first time I have ever run rubber tires on carpet on it was great. Mike thanks again for the set up. After rebuilding my car that moring and putting that setup on, I never touched anything else on the car. Have to also thank Steve Walter for suppling my left front end. Bummer when you show up to the track and your missing a whole side of the car . You make make racing enjoyable and that is what is all about.
Adam, You've got PM
I know
Could someone help? I am running Schumacher axis2 and I can`t figure out one thing. I`m racing in local club on carpet, rubber, 19t motor on 5 cells, but i`ts awfully slow on a strech. Could someone suggest what should i do to fix this maybe different gear ratio. Currently i`ts 23 pinion and 86 spur. Electornics seem to bet perfect because this plastic hell Tamiya TT-01 is running better with this set if electronics.
Add 3-5 teeth to each gear for running on these motors on 5 cells.
So whats the hot set up for asphalt racing? I'll be making my asphalt "day butt" this weekend at a race in Missippi and I don't have a clue what I am getting myself into (I have been running foams for the last 3 years) Ive been told the hot tire there is the RP30 and I'll be running mod and 13.5. Thanks y'all!
Links are always good!
thanks adam and yokemad!
will give em a try.
will give em a try.
hey are these the new silver bones or old purple ones?
u3233 drive shaft bones ??
cheers
cheers
The only difference between the purple and silver bones by themselves is the color only!
If you order the bare bones "U3233" you'll receive purple. If you order complete CVD's you'll receive the silver ones.
http://www.racing-cars.com/usa/image...w_reedy_07.pdf
i am looking for a spring rate chart for the schumacher on road touring car springs. does anyone have a chart or know where i can download a copy??
