Schumacher Corner
I've set 5mm front and 4.5mm rear Ride Height do you think 4.5mm too Low...
Or Lower is Better
Or Lower is Better
R/C Tech Elite Member
Happy Turkey to the Team Schumacher Drivers, Privateers, and everyone else that reads this thread on a daily basis
Yoke I have your email, i'll get back to you on that in a few days
Marcos, good seeing you last night actually working and not faking a leg injury like usual
ok Thanx Adam
Super Moderator
Now to get some bodies painted...McGoo, where are you when I need you!
Looking on pg. 29 of the manual it's great to see how Schumacher describes the action of the steering response via ball centers. What's puzzling to me though is the lengths of the track rods AND ball stud positions on the hub carriers. How do these work together w/ the track rod? Any general rules to follow/remember?
Super Moderator
here it is.....I have found its pretty versatile. You might need to adjust rear toe and droop to fit your likings, but it should be about 90% money for ya.....
http://rctech.net/forum/attachment.p...1&d=1191596955
Super Moderator
thanks!! Ill try it this weekend!! if my buddy brings the foams
I dont know yet....I'm becoming more and more booked up by the minute
Minreg
Are you guys sure there will be a foam stock class? If so, that sounds like a plan.
However, whats up with schumacherpitspace? I cant get to it. Can someone shoot me wylens setup?
Thanks,
R
Thanks,
R
Shoot me your email and I can send you Weylins setup.
quick question. When building a one way, does the male outdrive go into the deep side of the gear, or does it go on the shallow side?
