Schumacher Corner
dude doesnt germany have a no drinking age?
come to aus when yr 18 thats our age limit lol i turned 18 in july thank god havnt found my choice of poison yet i tried corona and a few aussie beers but the dont do it for me the clossest ive come to liking a drink is southern comfort and thats a pretty sweet drink so its soft
Maybe I over simplfied what I was trying to say, I was trying not to get to technical. The angle of your shocks directly reflects how quickly wieght is transfered. Example: Standing the rear shocks all the way up on the towers with make the rear of the car react quickly to steering inputs. This will cause the car to rotate quicker and provide more initial steering. Laying the rear shocks inward will slow the reaction and make that end of the car feel lazy, and follow the front end less agressivley.
Because the car isnt so reactive, and is suspension rate is softer to car "Feels" like it has more grip
That makes it to simple. Back to the drawing board.
Wes
R/C Tech Elite Member
mmmmm Oktoberfest!!!!
With all the iiC rubber set-ups being posted, I haven't seen any hint of the tire choice. Or was there a spec rubber tire used?
I think it was spec
If your car has that much tweak it could be a bent bulkhead.
Before I put a car on the track I check it to make sure it's perfectly flat on the chassis, droop is perfect, and tweak is perfect. Knowing what your car is going to do on the first lap is sometimes hard, but knowing your car is set perfectly will definately help your confidence going into the first turn.
So the new Jaco Rubberz (green) were the spec.....interesting
On the tweak issue--
I've found that the lower deck can tweak between the four screws for each bulkhead. Just loosen each of the four (w/o load on the chassis) and re-tighten. The shock towers can do the same. With the chassis on blocks, loosen both screws and re-tighten, making sure the shock mounts are equidistant from the set up board (use calipers).
'bout time
I want to come but the guy I was going to ride with backed out so, I will know later if my GF has to work Sat so we can come up!
where do the jaco tires for vegas fall within the sorex/rp lines. 30's, 32's??
thanks.
and is there anywhere i can find a choice of Mi3 avatars without stealing one from you guys?
thanks.
