Schumacher Corner
darkseide ide wrap your bulk head in electrical tape. just piece of mind sure the aluminium is annodized but it doesnt take much to scratch it off then u have a short.
just an idea
just an idea
question, when i run brushless with 5 cell, the car is amazing, i don't add weight to make up for the missing cell or imbalance of the chassis. when running lipo, if not mandated by the track why would you add weight. is it that much of difference that if effect handling in a different way? thanks in advance
Regional Moderator
Believe me, I went over it with a fine tooth comb. I spend almost as much time wiring as I do building my cars(and unfortunately...I'm not exaggerating ), so once I settle on a layout, you can be sure that everything is safe.
R/C Tech Elite Member
Regional Moderator
Regional Moderator
Hey, I think I found it...for once I had some luck with the SchuUSA search engine.
Part#G315
So hopefully next time I take a pic of my Mi3, I'll have the proper towel so that Randy will be a little more at ease.
Part#G315
my next order will start with that. save one for seattle adam.
i will have a list of what is left of Tamale's c-hubs tomorrow....I will be shooting a pm to those that have contacted me already....
mm
mm
1. I thought I saw some IIC pics and guys had red Schumacher pit towels? I know about the blue but is there a red?
2. Running a spool...if the back end is a bit loose midcorner then on power what would you change. I realize you don't have the full setup but just wondering what some of you might do.
Ran the car finally on carpet w/spool, 13.5 BL, rubbers tires. It's super smooth but wanders out a little when driving hard midcorner. It was fast and in the main I had the fastest lap. Just want to clean up the midcorner drifting...
Thanks in advance.
Thanks in advance.
haha, that was Numan that noticed it, just figured I had to post his remark lol
